This is a multi-part message in MIME format.
------=_NextPart_000_004D_01BDBA63.B3CB0F80
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
This is an idea that some of y'all on the list may like to discuss. Me =
thinks it may work...
Why not use a electric motor coupled to the drive shaft for a 'get home' =
drive system? In the smaller trawlers, like my own, we have smaller =
gen-sets that do not allow for hyd. pumps and the like but, they produce =
electricity. Another advantage that I could see with this setup is that =
when under weigh on the main engine, the electric motor would be driven =
by the turning prop shaft and be able to produce electricity to run the =
A/C and other things w/o running the gen-set. This system would not need =
to be overly expensive ( usually common problem for us smaller trawler =
owners) and short of fabricating the mounting bracket, a fairly simple =
install.
What do you think?
Morley MV Tortuga
35' Tia Chaio
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD W3 HTML//EN">
<HTML>
<HEAD>
<META content=3Dtext/html;charset=3Diso-8859-1 =
http-equiv=3DContent-Type>
<META content=3D'"MSHTML 4.71.2016.0"' name=3DGENERATOR>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT color=3D#000000 size=3D2>This is an idea that some of y'all =
on the list=20
may like to discuss. Me thinks it may work...</FONT></DIV>
<DIV><FONT color=3D#000000 size=3D2></FONT> </DIV>
<DIV><FONT color=3D#000000 size=3D2>Why not use a electric motor coupled =
to the=20
drive shaft for a 'get home' drive system? In the smaller =
trawlers, like=20
my own, we have smaller gen-sets that do not allow for hyd. pumps and =
the like=20
but, they produce electricity. Another advantage that I could see with =
this=20
setup is that when under weigh on the main engine, the electric motor =
would be=20
driven by the turning prop shaft and be able to produce electricity to =
run=20
the A/C and other things w/o running the gen-set. This system =
would not=20
need to be overly expensive ( usually common problem for us smaller =
trawler=20
owners) and short of fabricating the mounting bracket, a fairly simple=20
install.</FONT></DIV>
<DIV><FONT color=3D#000000 size=3D2>What do you think?</FONT></DIV>
<DIV><FONT color=3D#000000 size=3D2>Morley =
MV=20
Tortuga</FONT></DIV>
<DIV><FONT color=3D#000000 size=3D2>35' Tia =
Chaio</FONT></DIV></BODY></HTML>
------=_NextPart_000_004D_01BDBA63.B3CB0F80--
install.
What do you think?
Morley MV Tortuga
35' Tia Chaio
<HTML>
<HEAD>
</HEAD>
on the list=20
to the=20
trawlers, like=20
the like=20
this=20
would be=20
run=20
would not=20
trawler=20
MV=20
