A PRS10 with a long shelf life will need more than 10 months (not days !) to get its final drift. Its dépends of the homogeneity of the gas mixture (Rb85,87 and krypton) in the cell and a long non running time affects the mixture. After the end of this warm up period, adjustement is time consuming as the drift is parabolic and the top of the parabole tends to flatten with the successive adjustements. You can get 1 or 2 x 10^-11 and the retrace is in order of this magnitude after a couple of days without power. At this magnitude of adjustement you have to look at the barometric pressure to avoid false adjustements but the effect is little compared with the 5065A whose tube is much bigger (and with less noise...). The 5065A is a very good barometer but a little bit costly..
On Fri, 3/8/19, Attila Kinali attila@kinali.ch wrote:
Subject: Re: [time-nuts] PRS-10 Warm-up Time, Calibrating/Adjusting, and long-term poweron
To: "Discussion of precise time and frequency measurement" time-nuts@lists.febo.com
Date: Friday, March 8, 2019, 4:45 PM
On Fri, 8 Mar 2019 06:31:48
-0600
Dana Whitlow k8yumdoober@gmail.com
wrote:
is that there are apparently a number of warm up drift
mechanisms operating, some of which take
days to sensibly settle down.
Longer. I know of one measurement, where the Rb
had a kind of stable
drift until it suddenly
switched to another slope quite suddenly
(within a few days) about half a year after
power up.
The aging
mechanisms of Rb vapor cell standards are many and not
all of them are well understood, much less
controlled. Compared
to that, an OCXO has
"only" thermal stability of the oven, strain
relaxation of the holder/crystal and
deposition/removal of contaminants
on the
crystal surface. Ok, there are a couple more, but these
three
are the main contributors for most
OCXO out there. While for the
Rb vapor cell
standard I could name you half a dozen just like that
and I am far from being an expert on these.
For those interested, John Vig
wrote a couple of papers on the aging
of
OCXO in the 80s and 90s. The topic of Rb vapor cell aging is
a lot
more messy and I don't know
whether there is any good paper that reviews
the main contributors.
Attila Kinali
It is upon moral qualities
that a society is ultimately founded. All
the prosperity and technological sophistication
in the world is of no
use without that
foundation.
-- Miss
Matheson, The Diamond Age, Neal Stephenson
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
To: "Discussion of precise time and frequency measurement" <time-nuts@lists.febo.com>
-0600
Dana Whitlow <k8yumdoober@gmail.com>
wrote:
> The point here
power up.
The aging
on the
three
Rb vapor cell
of
a lot
Attila Kinali
use without that
foundation.
-- Miss
