time-nuts@lists.febo.com
Re: [time-nuts] 5 MHZ PIC PPS Divider?
SR
Stanley Reynolds
Tue, Apr 15, 2008 11:24 PM
More thinking out loud ... if the 1Ghz-2 Ghz oscillator is phase locked too the 10 Mhz signal then we reduce the error ?
----- Original Message ----
To: Discussion of precise time and frequency measurement time-nuts@febo.com
Sent: Tuesday, April 15, 2008 6:11:35 PM
Subject: Re: [time-nuts] 5 MHZ PIC PPS Divider?
Not sure any calibration is needed as the measurement is + or - one count at 1Ghz and if we measure only the time to the next 10 Mhz pulse we have the rest of the 1/2 or whole second to transfer data and reset the counter if we don't allow for overflow. We could skip every other pulse if more time is needed for things to settle or the PIC to dump data. The output of the ring counter (1Ghz/256=38.4Mhz) could feed a counter in the PIC for more resolution if we wanted to count several PPS cycles, that is if the jitter was not huge.
Sent: Tuesday, April 15, 2008 4:42:53 PM
a ECL 8-Bit Ripple Counter. And a 1Ghz oscillator make the measurement
of  differences. This should get me to the 1ns level ?
Or try a FPGA...
They run at 250 MHz so all you need is 4 clock phases.
The other approach would be to make a delay line that's longer than a single
clock and has many FFs along the way.  I'm not sure how to calibrate that and
keep it calibrated as power/temp change.
These are my opinions, not necessarily my employer's.  I hate spam.
  ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
More thinking out loud ... if the 1Ghz-2 Ghz oscillator is phase locked too the 10 Mhz signal then we reduce the error ? ----- Original Message ---- From: Stanley Reynolds <stanley_reynolds@yahoo.com> To: Discussion of precise time and frequency measurement <time-nuts@febo.com> Sent: Tuesday, April 15, 2008 6:11:35 PM Subject: Re: [time-nuts] 5 MHZ PIC PPS Divider? Not sure any calibration is needed as the measurement is + or - one count at 1Ghz and if we measure only the time to the next 10 Mhz pulse we have the rest of the 1/2 or whole second to transfer data and reset the counter if we don't allow for overflow. We could skip every other pulse if more time is needed for things to settle or the PIC to dump data. The output of the ring counter (1Ghz/256=38.4Mhz) could feed a counter in the PIC for more resolution if we wanted to count several PPS cycles, that is if the jitter was not huge. ----- Original Message ---- From: Hal Murray <hmurray@megapathdsl.net> To: Discussion of precise time and frequency measurement <time-nuts@febo.com> Sent: Tuesday, April 15, 2008 4:42:53 PM Subject: Re: [time-nuts] 5 MHZ PIC PPS Divider? > a ECL 8-Bit Ripple Counter. And a 1Ghz oscillator make the measurement > of differences. This should get me to the 1ns level ? Or try a FPGA... They run at 250 MHz so all you need is 4 clock phases. The other approach would be to make a delay line that's longer than a single clock and has many FFs along the way. I'm not sure how to calibrate that and keep it calibrated as power/temp change. -- These are my opinions, not necessarily my employer's. I hate spam. _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there. ____________________________________________________________________________________ Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there. ____________________________________________________________________________________ Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
