trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
GPS and Computer Failure
Y
yourcaptain@earthlink.net
Sat, Aug 14, 1999 2:34 AM
Did you know that a lot of our GP'Sare going to quit next month. If you are
concerned like I am check this site
http://www.navcen.uscg.mil/gps/geninfo/y2k/default.htm
Surprise--Suprise
If you want a quick fix for your computer for Y2K Bug do the following test.
If Georgs gives me hell again please defend me. I am only trying to help my
fellow listees over the bumps.
If you want this type of information to continue please let it be known.
Now the test.
I received this and checked my computer and found it to be set up to fail.
I recommend  you check and fix your computers.
If you are running Windows, this is a fix for a small Y2K problem almost
everyone should do.
After running this quick little test, much to my surprise, I learned that
my  computer would have failed on 01-01-2000 due to a computer clock glitch.
Fortunately, a quick fix is provided, should your computer fail the test.
I submit the following for your consideration:
TEST
  1. Double click on "My Computer".
  2. Double click on "Control Panel".
  3. Double click on "Regional Settings" icon.
  4. Click on the "Date" tab at the top of the page.
  5. Where it says, "Short Date Sample", look and see if it shows a "two
    digit" year.
    Of course it does. That's the default setting for Windows 95, Windows 98
    and NT. This date RIGHT HERE is the date that feeds application software and
    WILL  NOT rollover in the year 2000. It will roll over to 00.
    NOW TO FIX IT :
  6. Click the drop-down arrow to the right of "Short Date Style"
  7. Select the option mm/dd/yyyy.  (Be sure your selection has four Y's,
    not two)
  8. Click "OK"
    Easy enough to fix. However, every single installation of Windows
    worldwide  is defaulted to fail Y2K rollover. Makes you wonder.
Good Luck AL
Captain Al Pilvinis
"M/V Driftwood"--Prairie 47
2630 N.E. 41st Street
Lighthouse Point, Fl 33064-8064
Voice 954-941-2556 Fax 954 788-2666
Email - CaptainAl@Juno.com
Website http://home.earthlink.net/~yourcaptain
Did you know that a lot of our GP'Sare going to quit next month. If you are concerned like I am check this site http://www.navcen.uscg.mil/gps/geninfo/y2k/default.htm Surprise--Suprise If you want a quick fix for your computer for Y2K Bug do the following test. If Georgs gives me hell again please defend me. I am only trying to help my fellow listees over the bumps. If you want this type of information to continue please let it be known. Now the test. I received this and checked my computer and found it to be set up to fail. I recommend you check and fix your computers. If you are running Windows, this is a fix for a small Y2K problem almost everyone should do. After running this quick little test, much to my surprise, I learned that my computer would have failed on 01-01-2000 due to a computer clock glitch. Fortunately, a quick fix is provided, should your computer fail the test. I submit the following for your consideration: TEST 1. Double click on "My Computer". 2. Double click on "Control Panel". 3. Double click on "Regional Settings" icon. 4. Click on the "Date" tab at the top of the page. 5. Where it says, "Short Date Sample", look and see if it shows a "two digit" year. Of course it does. That's the default setting for Windows 95, Windows 98 and NT. This date RIGHT HERE is the date that feeds application software and WILL NOT rollover in the year 2000. It will roll over to 00. NOW TO FIX IT : 6. Click the drop-down arrow to the right of "Short Date Style" 7. Select the option mm/dd/yyyy. (Be sure your selection has four Y's, not two) 8. Click "OK" Easy enough to fix. However, every single installation of Windows worldwide is defaulted to fail Y2K rollover. Makes you wonder. Good Luck AL . Captain Al Pilvinis "M/V Driftwood"--Prairie 47 2630 N.E. 41st Street Lighthouse Point, Fl 33064-8064 Voice 954-941-2556 Fax 954 788-2666 Email - CaptainAl@Juno.com Website http://home.earthlink.net/~yourcaptain
JD
jim_donohue@computer.org
Sat, Aug 14, 1999 3:01 AM
Al - Aw comeon.  Let's here your documentation for why this is a problem.
Otherwise maybe Georg should lay you one up the side if the head.  The
Chicken was wrong Al.
Jim
-----Original Message-----
[mailto:owner-trawler-world-list@samurai.com]On Behalf Of Al Pilvinis
Sent: August 13, 1999 7:35 PM
To: trawler-world-list@samurai.com
Subject: GPS and Computer Failure
Surprise--Suprise
Now the test.
everyone should do.
TEST
    digit" year.
    NOW TO FIX IT :
    not two)
  8. Click "OK"
Good Luck AL
Captain Al Pilvinis
Al - Aw comeon. Let's here your documentation for why this is a problem. Otherwise maybe Georg should lay you one up the side if the head. The Chicken was wrong Al. Jim -----Original Message----- From: owner-trawler-world-list@samurai.com [mailto:owner-trawler-world-list@samurai.com]On Behalf Of Al Pilvinis Sent: August 13, 1999 7:35 PM To: trawler-world-list@samurai.com Subject: GPS and Computer Failure Did you know that a lot of our GP'Sare going to quit next month. If you are concerned like I am check this site http://www.navcen.uscg.mil/gps/geninfo/y2k/default.htm Surprise--Suprise If you want a quick fix for your computer for Y2K Bug do the following test. If Georgs gives me hell again please defend me. I am only trying to help my fellow listees over the bumps. If you want this type of information to continue please let it be known. Now the test. I received this and checked my computer and found it to be set up to fail. I recommend you check and fix your computers. If you are running Windows, this is a fix for a small Y2K problem almost everyone should do. After running this quick little test, much to my surprise, I learned that my computer would have failed on 01-01-2000 due to a computer clock glitch. Fortunately, a quick fix is provided, should your computer fail the test. I submit the following for your consideration: TEST 1. Double click on "My Computer". 2. Double click on "Control Panel". 3. Double click on "Regional Settings" icon. 4. Click on the "Date" tab at the top of the page. 5. Where it says, "Short Date Sample", look and see if it shows a "two digit" year. Of course it does. That's the default setting for Windows 95, Windows 98 and NT. This date RIGHT HERE is the date that feeds application software and WILL NOT rollover in the year 2000. It will roll over to 00. NOW TO FIX IT : 6. Click the drop-down arrow to the right of "Short Date Style" 7. Select the option mm/dd/yyyy. (Be sure your selection has four Y's, not two) 8. Click "OK" Easy enough to fix. However, every single installation of Windows worldwide is defaulted to fail Y2K rollover. Makes you wonder. Good Luck AL . Captain Al Pilvinis "M/V Driftwood"--Prairie 47 2630 N.E. 41st Street Lighthouse Point, Fl 33064-8064 Voice 954-941-2556 Fax 954 788-2666 Email - CaptainAl@Juno.com Website http://home.earthlink.net/~yourcaptain
Y
Sat, Aug 14, 1999 3:10 AM
Jim
Jim-------Check the site then you to will realize there is a problem. But
then you probably don't own a GPS. So--no problem.
AL
Captain Al Pilvinis
At 08:01 PM 08/13/1999 -0700, you wrote: >Al - Aw comeon. Let's here your documentation for why this is a problem. >Otherwise maybe Georg should lay you one up the side if the head. The >Chicken was wrong Al. > >Jim ======================================================== Jim-------Check the site then you to will realize there is a problem. But then you probably don't own a GPS. So--no problem. AL . Captain Al Pilvinis "M/V Driftwood"--Prairie 47 2630 N.E. 41st Street Lighthouse Point, Fl 33064-8064 Voice 954-941-2556 Fax 954 788-2666 Email - CaptainAl@Juno.com Website http://home.earthlink.net/~yourcaptain
