I installed a vacuum gauge marketed by Racor, it works fine and can be
remote mounted following their guidelines. I have also seen a similar gauge which
has a pointer which stays at the highest vacuum the gauge sees until you
reset it to zero by hand, similar to some dial thermometers, This way you can
check it while the engine is not running and still see what the max vacuum was.
I don't recall now the name of the manufacturer but I saw it on display at
the Stuart FL boat show last year. An online search will probably find it.
Good luck,
Steve Willett
Camano 31
Thibodaux, Louisiana
**************************************See AOL's top rated recipes
(http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004)
A good source for more reasonable priced vacuum gauges that replace the Racor
T-Handle is:
http://designatedengineer.com/http://designatedengineer.com/
I have bought from them with good results.
Ron Nelson
Port Orchard, WA
----- Original Message -----
To:
trawlers-and-trawlering@lists.samurai.com<mailto:trawlers-and-trawlering@list
s.samurai.com>
Sent: Wednesday, January 02, 2008 12:17 PM
Subject: T&T: vacuum gauges
which
can
was.
Good luck,
Steve Willett
Camano 31
(http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004<http://foo
d.aol.com/top-rated-recipes?NCID=aoltop00030000000004>)
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering<http://li
sts.samurai.com/mailman/listinfo/trawlers-and-trawlering>
To unsubscribe or modify your subscription options (get password, change
email address, etc) go to:
http://lists.samurai.com/mailman/options/trawlers-and-trawlering<http://lists
.samurai.com/mailman/options/trawlers-and-trawlering>
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
