Being visually impaired I HATE slotted screws.
Your position makes sense given your eyesight situation. However, there
are some advantages to slotted head screws that I've learned over the
last nine years of working on our 1973 Grand Banks. The slots are easy
to clean decades of layers of paint and varnish out of. A Philips head
screw can be a real pain in this respect. Being able to clean the slot
out completely makes it that much easier to remove the screw without the
driver slipping or damaging the slot(s).
Also, I've found that older slotted head stainless screws like American
Marine used to screw down our teak decking have slightly wider heads
than the same number size screw sold today. Which means that the head
of the original screws get a slightly better purchase on the wood than
new screws of the same size. So when resetting decks screws and plugs,
I always clean and re-use the original, slotted head screw.
One trick I read about recently when setting screws, slotted or
particularly Philips, in holes that will be filled with plugs and glue,
is to stick one of those adhesive paper "dots" on top of the screw head
when it's seated home. Then glue in the plug. The "dot" keeps the glue
from getting down into and filling the slots in the screw head.
C. Marin Faure
GB36-403 "La Perouse"
Bellingham, Washington
