trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
REMOVING WASTE HOSES
JL
jim laudermilch
Fri, Oct 30, 2009 11:57 AM
Hello all,
Does anyone have a simple solutions to removing the semi rigid white waste
hose from the barb to which it has been clamped for a number of years?  How
about simplifying sliding new hose in place? Thanks!
Jim Laudermilch
Hello all, Does anyone have a simple solutions to removing the semi rigid white waste hose from the barb to which it has been clamped for a number of years? How about simplifying sliding new hose in place? Thanks! Jim Laudermilch
SH
Scott H.E. Welch
Fri, Oct 30, 2009 12:03 PM
jim laudermilch jj.calendar@gmail.com writes:
Use a knife and split the hose back about 1 inch.
How
A heat gun set on medium and KY jelley. The KY jelley is glycerine based and
hardens up when it dries, adding a bit of sealing.
I learned both of these tricks from a professional marine pipefitter, and
they really work.
Scott Welch
Chief Evangelist, Open Text Social Media Group
www.opentext.com
905 762 6101
"Things turn out best for people who make the best of the way things turn
out." - John Wooden
jim laudermilch <jj.calendar@gmail.com> writes: >Does anyone have a simple solutions to removing the semi rigid white waste >hose from the barb to which it has been clamped for a number of years? Use a knife and split the hose back about 1 inch. >How >about simplifying sliding new hose in place? A heat gun set on medium and KY jelley. The KY jelley is glycerine based and hardens up when it dries, adding a bit of sealing. I learned both of these tricks from a professional marine pipefitter, and they really work. Scott Welch Chief Evangelist, Open Text Social Media Group www.opentext.com 905 762 6101 "Things turn out best for people who make the best of the way things turn out." - John Wooden
RA
Rudy and Jill
Fri, Oct 30, 2009 12:49 PM
rigid white waste
number of years?
Jim, you can heat the hose (heat gun/hair drier), but if its that old, chances
are you'll want to be replacing it, so just cut it off.
When I replace hose, if I cannot get to the entire run to guide it through, I
drill holes in the end of each length (old piece and new piece), tie or wire
them together and pull the new piece through with the old piece.
Or I'll tie a string to the old hose, pull the old hose through and then tie
the other end of the string to the new hose and pull it through. If it will
required a considerable amount of persuasion to get the new hose through, I'll
use wire instead of string.
Coating the outside of the hose with a lubricant will help in sliding the hose
through friction-prone areas. Checking with the hose manufacturer can alert
you to which products not to use for a lubricant, but generally speaking,
water based products (liquid soap) are safe to use.
Also, running hose is quite often a two person job, with the person on each
end requiring a sensitive touch as to when to pull or push and how much. Team
work and communication, coupled with alot of yelling and swearing usually sees
the new hose in place. Except to have sore muscles the next day. Sanitation
hose is often physically challenging stuff to get in place; I suspect their
chemists are sitting in their labs chuckling every time they come up with a
new formulation??
I would suggest that you replace the white hose with a black hose, such as
Shields 101. I find that this type of hose does not need to be heated to slide
over the fittings and clamps well. My philosophy towards sanitation hose is
that it needs replacing every x number of years anyways, so in spite of the
manufacturers long-life guarantee, I'd prefer easy installation, than a
questionable lifetime installation.
No need to remind you to wash your hands when done, the odor on them will be
sufficient reminder. Have fun with it.
Rudy
Briney Bug, Panama City, Fl
> Does anyone have a simple solutions to removing the semi > rigid white waste > hose from the barb to which it has been clamped for a > number of years? Jim, you can heat the hose (heat gun/hair drier), but if its that old, chances are you'll want to be replacing it, so just cut it off. > How about simplifying sliding new hose in place? When I replace hose, if I cannot get to the entire run to guide it through, I drill holes in the end of each length (old piece and new piece), tie or wire them together and pull the new piece through with the old piece. Or I'll tie a string to the old hose, pull the old hose through and then tie the other end of the string to the new hose and pull it through. If it will required a considerable amount of persuasion to get the new hose through, I'll use wire instead of string. Coating the outside of the hose with a lubricant will help in sliding the hose through friction-prone areas. Checking with the hose manufacturer can alert you to which products not to use for a lubricant, but generally speaking, water based products (liquid soap) are safe to use. Also, running hose is quite often a two person job, with the person on each end requiring a sensitive touch as to when to pull or push and how much. Team work and communication, coupled with alot of yelling and swearing usually sees the new hose in place. Except to have sore muscles the next day. Sanitation hose is often physically challenging stuff to get in place; I suspect their chemists are sitting in their labs chuckling every time they come up with a new formulation?? I would suggest that you replace the white hose with a black hose, such as Shields 101. I find that this type of hose does not need to be heated to slide over the fittings and clamps well. My philosophy towards sanitation hose is that it needs replacing every x number of years anyways, so in spite of the manufacturers long-life guarantee, I'd prefer easy installation, than a questionable lifetime installation. No need to remind you to wash your hands when done, the odor on them will be sufficient reminder. Have fun with it. Rudy Briney Bug, Panama City, Fl
RC
R C Smith Jr
Fri, Oct 30, 2009 1:24 PM
I like these tools...
http://www.quinntoolsonline.com/servlet/the-106474/General-Merchandise-,,Hos
e-Removal/Detail
Bob
Robert Calhoun Smith, Jr.
MV MARY KATHRYN
1977 Hatteras 58 LRC
Morehead City, NC
To track our progress by satellite, click here:
http://tinyurl.com/Yacht-MARY-KATHRYN-SPOT
On 10/30/09 7:57 AM, "jim laudermilch" <jj.calendar@gmail.com> wrote: > Does anyone have a simple solutions to removing the semi rigid white waste > hose from the barb to which it has been clamped for a number of years? I like these tools... http://www.quinntoolsonline.com/servlet/the-106474/General-Merchandise-,,Hos e-Removal/Detail Bob _________________________ Robert Calhoun Smith, Jr. MV MARY KATHRYN 1977 Hatteras 58 LRC Morehead City, NC To track our progress by satellite, click here: http://tinyurl.com/Yacht-MARY-KATHRYN-SPOT
