patch ffmpeg_vid_codecs.c, support ffmpeg 1.0
WC
Warun C.
Wed, Nov 14, 2012 10:43 AM
Eclipse Workspace Patch 1.0
#P PJproject
Index: pjmedia/src/pjmedia-codec/ffmpeg_vid_codecs.c
--- pjmedia/src/pjmedia-codec/ffmpeg_vid_codecs.c (revision 4296)
+++ pjmedia/src/pjmedia-codec/ffmpeg_vid_codecs.c (working copy)
@@ -70,7 +70,7 @@
* libavcodec 53.61 where some codecs actually still use AVCodec::encode
* (e.g: H263, H264).
-#      define AVCODEC_HAS_ENCODE(c) (c->encode || c->encode2)
+#      define AVCODEC_HAS_ENCODE(c) (c->encode_sub || c->encode2)
endif
define AV_OPT_SET(obj,name,val,opt) (av_opt_set(obj,name,val,opt)==0)
define AV_OPT_SET_INT(obj,name,val) (av_opt_set_int(obj,name,val,0)==0)
Best Regards,
Warun
Email: pureroot@gmail.com
### Eclipse Workspace Patch 1.0 #P PJproject Index: pjmedia/src/pjmedia-codec/ffmpeg_vid_codecs.c =================================================================== --- pjmedia/src/pjmedia-codec/ffmpeg_vid_codecs.c (revision 4296) +++ pjmedia/src/pjmedia-codec/ffmpeg_vid_codecs.c (working copy) @@ -70,7 +70,7 @@ * libavcodec 53.61 where some codecs actually still use AVCodec::encode * (e.g: H263, H264). */ -# define AVCODEC_HAS_ENCODE(c) (c->encode || c->encode2) +# define AVCODEC_HAS_ENCODE(c) (c->encode_sub || c->encode2) # endif # define AV_OPT_SET(obj,name,val,opt) (av_opt_set(obj,name,val,opt)==0) # define AV_OPT_SET_INT(obj,name,val) (av_opt_set_int(obj,name,val,0)==0) -- Best Regards, Warun -------------------- Email: pureroot@gmail.com
