trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
anchor chain rattle
J
janice142
Fri, Apr 18, 2008 6:36 PM
The chain rattles. Specifically, just aft of the anchor locker is a 50
gallon water tank. The rattle of chain reverberating through the tank seems
to magnify the sound.
I can put a hose into the chain locker and the rinse water does go under the
water tank and thru the bilge into that forward compartment with the bilge
pump.
Of course access is miserable to the chain locker (a 10" square panel on the
forward bulkhead of the stateroom) -- any ideas on abating the rattle?
J (and Frank) ashore for the doctor visits routine. Ugh.
The chain rattles. Specifically, just aft of the anchor locker is a 50 gallon water tank. The rattle of chain reverberating through the tank seems to magnify the sound. I can put a hose into the chain locker and the rinse water does go under the water tank and thru the bilge into that forward compartment with the bilge pump. Of course access is miserable to the chain locker (a 10" square panel on the forward bulkhead of the stateroom) -- any ideas on abating the rattle? J (and Frank) ashore for the doctor visits routine. Ugh.
LL
LA Licata
Fri, Apr 18, 2008 7:54 PM
You can take out all of the chain and put the plastic tiles that
clamp together down there, and then that should stop most of the noise.
You could try blowing up a beach ball, old car inner tube or
something akin to that and stuffing it on top of the chain.
Or, if the area is fiberglass, some old fluffy towels for the chain
to rest on might also work...
Lee
You can take out all of the chain and put the plastic tiles that clamp together down there, and then that should stop most of the noise. You could try blowing up a beach ball, old car inner tube or something akin to that and stuffing it on top of the chain. Or, if the area is fiberglass, some old fluffy towels for the chain to rest on might also work... Lee On Apr 18, 2008, at 2136, janice142 wrote: The chain rattles. Specifically, just aft of the anchor locker is a 50 gallon water tank. The rattle of chain reverberating through the tank seems to magnify the sound.
