time-nuts@lists.febo.com
Re: [time-nuts] 10 MHz Distribution Amp
E
EWKehren@aol.com
Thu, Nov 12, 2009 8:45 PM
Take a look at the LT 6551 it makes a good four channel distribution  amp.
Bert Kehren
In a message dated 11/12/2009 3:36:04 P.M. Eastern Standard Time,
robert8rpi@yahoo.co.uk writes:
Hi,
The cheap alternative is to use a video distribution amp.  Even the cheap
ones are reasonable. VGA distribution units can also be used,  you get three
channels.
Robert G8RPI.
--- On Thu,  12/11/09, Richard W. Solomon w1ksz@earthlink.net  wrote:
Subject: [time-nuts] 10 MHz Distribution  Amp
To: time-nuts@febo.com
Date: Thursday, 12 November, 2009,  18:20
A friend of mine is looking for an inexpensive way to  distribute
his 10 MHz T-Bolt signal to other instruments. The TAPR unit,  while
very nice, is a tad on the pricey side when you add in the  enclosure.
Any ideas what he could use that is not so expensive  ?
Thanks, Dick,  W1KSZ
time-nuts  mailing list -- time-nuts@febo.com
To unsubscribe, go to
and follow the  instructions there.
Take a look at the LT 6551 it makes a good four channel distribution amp. Bert Kehren In a message dated 11/12/2009 3:36:04 P.M. Eastern Standard Time, robert8rpi@yahoo.co.uk writes: Hi, The cheap alternative is to use a video distribution amp. Even the cheap ones are reasonable. VGA distribution units can also be used, you get three channels. Robert G8RPI. --- On Thu, 12/11/09, Richard W. Solomon <w1ksz@earthlink.net> wrote: From: Richard W. Solomon <w1ksz@earthlink.net> Subject: [time-nuts] 10 MHz Distribution Amp To: time-nuts@febo.com Date: Thursday, 12 November, 2009, 18:20 A friend of mine is looking for an inexpensive way to distribute his 10 MHz T-Bolt signal to other instruments. The TAPR unit, while very nice, is a tad on the pricey side when you add in the enclosure. Any ideas what he could use that is not so expensive ? Thanks, Dick, W1KSZ _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there. _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
