time-nuts@lists.febo.com
Trimble Thunderbolt, any easy way to create 500 MHz reference from one?
CW
Chris Wilson
Wed, May 15, 2013 12:14 PM
15/05/2013 13:13
Is there any fairly easy way to multiply the output of a Thunderbolt to
have a 500MHz reference at about 4dBm? Thanks.
Best Regards,
Chris Wilson.
mailto: chris@chriswilson.tv
15/05/2013 13:13 Is there any fairly easy way to multiply the output of a Thunderbolt to have a 500MHz reference at about 4dBm? Thanks. -- Best Regards, Chris Wilson. mailto: chris@chriswilson.tv
PS
paul swed
Wed, May 15, 2013 1:14 PM
I would have to say one of the modern clock/pll chips as easy as its going
to get. otherwise its the conventional multiply and filter. Now with some
humor it depends on what you think easy is.
There are other aspects that you have not shared with respect to the
quality of the signal and its use case. These could make a very large
difference in the direction you want to take.
Regards
Paul
WB8TSL
On Wed, May 15, 2013 at 8:14 AM, Chris Wilson chris@chriswilson.tv wrote:
15/05/2013 13:13
Best Regards,
Chris Wilson.
To unsubscribe, go to
I would have to say one of the modern clock/pll chips as easy as its going to get. otherwise its the conventional multiply and filter. Now with some humor it depends on what you think easy is. There are other aspects that you have not shared with respect to the quality of the signal and its use case. These could make a very large difference in the direction you want to take. Regards Paul WB8TSL On Wed, May 15, 2013 at 8:14 AM, Chris Wilson <chris@chriswilson.tv> wrote: > > > 15/05/2013 13:13 > > Is there any fairly easy way to multiply the output of a Thunderbolt to > have a 500MHz reference at about 4dBm? Thanks. > > -- > Best Regards, > Chris Wilson. > mailto: chris@chriswilson.tv > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
RL
Robert LaJeunesse
Wed, May 15, 2013 2:17 PM
If easy means a temporary lashup, takes but one piece of gear. The Ballantine
6130A time mark generator takes in 10 MHz, produces from it a synchronous 1Hz to
500MHz selectable in 1-2-5 steps. I've not tested mine for phase noise, probably
not the best performer... but for $35 not a big concern, given my needs.
Shameless plug: I'll have another one for sale at the Dayton Hamvention, flea
market space 1901. There will be other Time Nuts in residence at 1901 as well.
Bob LaJeunesse
To: Discussion of precise time and frequency measurement time-nuts@febo.com
Sent: Wed, May 15, 2013 8:15:15 AM
Subject: [time-nuts] Trimble Thunderbolt, any easy way to create 500 MHz
reference from one?
15/05/2013 13:13
Best Regards,
Chris Wilson.
If easy means a temporary lashup, takes but one piece of gear. The Ballantine 6130A time mark generator takes in 10 MHz, produces from it a synchronous 1Hz to 500MHz selectable in 1-2-5 steps. I've not tested mine for phase noise, probably not the best performer... but for $35 not a big concern, given my needs. Shameless plug: I'll have another one for sale at the Dayton Hamvention, flea market space 1901. There will be other Time Nuts in residence at 1901 as well. Bob LaJeunesse ________________________________ From: Chris Wilson <chris@chriswilson.tv> To: Discussion of precise time and frequency measurement <time-nuts@febo.com> Sent: Wed, May 15, 2013 8:15:15 AM Subject: [time-nuts] Trimble Thunderbolt, any easy way to create 500 MHz reference from one? 15/05/2013 13:13 Is there any fairly easy way to multiply the output of a Thunderbolt to have a 500MHz reference at about 4dBm? Thanks. -- Best Regards, Chris Wilson. mailto: chris@chriswilson.tv _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
RS
Richard Solomon
Wed, May 15, 2013 3:16 PM
There are a number of phase-locked oscillators over on the "evil empire"
that might do,
but if you need exactly 500 MHz, you might not find that one so easily.
I found one that had outputs of 72.5, 725 and 7,975 MHz that locks to my
GPSDO. Very
useful for checking Frequency Counters, Service Monitors and the like.
73, Dick, W1KSZ
On 5/15/2013 5:14 AM, Chris Wilson wrote:
15/05/2013 13:13
There are a number of phase-locked oscillators over on the "evil empire" that might do, but if you need exactly 500 MHz, you might not find that one so easily. I found one that had outputs of 72.5, 725 and 7,975 MHz that locks to my GPSDO. Very useful for checking Frequency Counters, Service Monitors and the like. 73, Dick, W1KSZ On 5/15/2013 5:14 AM, Chris Wilson wrote: > > 15/05/2013 13:13 > > Is there any fairly easy way to multiply the output of a Thunderbolt to > have a 500MHz reference at about 4dBm? Thanks. >
TV
Tom Van Baak
Sun, May 19, 2013 12:27 AM
Chris,
If you already have or are planning to make a standalone 500 MHz local oscillator, you could divide this by 50 and replace the TBolt 10 MHz OCXO similar to what John did (http://www.ke5fx.com/tbolt.htm). That way the TBolt does all the phase locking and disciplining for you, for free.
/tvb
> Is there any fairly easy way to multiply the output of a Thunderbolt to > have a 500MHz reference at about 4dBm? Thanks. Chris, If you already have or are planning to make a standalone 500 MHz local oscillator, you could divide this by 50 and *replace* the TBolt 10 MHz OCXO similar to what John did (http://www.ke5fx.com/tbolt.htm). That way the TBolt does all the phase locking and disciplining for you, for free. /tvb
