trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Drinking water
KB
Ken Bloomfield
Mon, Apr 6, 2009 1:59 AM
Richard wrote:
"The above contains a common misunderstanding that chlorination is a
lasting treatment. The effect of chlorination is dissipated within
days...even hours."
Richard,
I think that you will find that this may not necessarily be applicable.
However, let me first say that as usual we are way off what I was trying
to get at, namely:  Be careful where and how you filter your drinking
water or you may add problems rather than solve them, such as eating up
your tanks with deionized water to save a little nearly non-existent
chlorine embrittlement problem.  I just addressed my way of getting rid
of chlorine, hose, and other taste from water AFTER the tank, and all of
a sudden we are debating the life-span of chlorine.  Good grief.
The following clip is from the Centers for Disease Control government
website:
"Public water systems generally are disinfected with chlorine. Bottled
water is commonly disinfected by ozone treatment. Ozone is a
high-strength oxygen that quickly reverts to normal oxygen. It is a
strong oxidant, like chlorine, but does not add taste like chlorine
does. The length of time chlorine and ozone remain active in water
depends on many factors [especially the form of chlorine --Ken],
including temperature. Chlorine usually provides residual disinfection
throughout the public-water distribution system. Ozone provides a
residual disinfection for a limited time."
For some reasons having to do with a phenomena called "pinhole leaks" in
our neighborhood, I have done some research on chlorine and more
specifically chloramines.  The latter are now commonly used for their
ability to last in the water system.  I don't want to load the site up
with cut-and-past stuff, but if you want more, go to
*http://tinyurl.com/cewxnx *which is the EPA site to read about them.
They certainly can and will arrive at your dockside water spigot.  My
whole point is that in the process of getting them out using a filter
like Chuck has on his website, you can cause more damage than you save,
and -- potentially reduce the protection of your water.  I don't debate
that water tanks will remain safe/bug-free if they started that way and
no new bugs were added, but that is pretty difficult to achieve.  If
that were not the case, there would never have been the effort to have
longer lasting chlorine in the municipal water systems.
OK -- I last on this from me.  Need to get on to easy topics like
religion and politics. (;-)
Cheers,
Ken Bloomfield
Tellico Lady, 50' Marine Trader
Maryville, TN
Richard wrote: "The above contains a common misunderstanding that chlorination is a lasting treatment. The effect of chlorination is dissipated within days...even hours." Richard, I think that you will find that this may not necessarily be applicable. However, let me first say that as usual we are way off what I was trying to get at, namely: Be careful where and how you filter your drinking water or you may add problems rather than solve them, such as eating up your tanks with deionized water to save a little nearly non-existent chlorine embrittlement problem. I just addressed my way of getting rid of chlorine, hose, and other taste from water AFTER the tank, and all of a sudden we are debating the life-span of chlorine. Good grief. The following clip is from the Centers for Disease Control government website: "Public water systems generally are disinfected with chlorine. Bottled water is commonly disinfected by ozone treatment. Ozone is a high-strength oxygen that quickly reverts to normal oxygen. It is a strong oxidant, like chlorine, but does not add taste like chlorine does. The length of time chlorine and ozone remain active in water depends on many factors [especially the form of chlorine --Ken], including temperature. Chlorine usually provides residual disinfection throughout the public-water distribution system. Ozone provides a residual disinfection for a limited time." For some reasons having to do with a phenomena called "pinhole leaks" in our neighborhood, I have done some research on chlorine and more specifically chloramines. The latter are now commonly used for their ability to last in the water system. I don't want to load the site up with cut-and-past stuff, but if you want more, go to *http://tinyurl.com/cewxnx *which is the EPA site to read about them. They certainly can and will arrive at your dockside water spigot. My whole point is that in the process of getting them out using a filter like Chuck has on his website, you can cause more damage than you save, and -- potentially reduce the protection of your water. I don't debate that water tanks will remain safe/bug-free if they started that way and no new bugs were added, but that is pretty difficult to achieve. If that were not the case, there would never have been the effort to have longer lasting chlorine in the municipal water systems. OK -- I last on this from me. Need to get on to easy topics like religion and politics. (;-) Cheers, Ken Bloomfield Tellico Lady, 50' Marine Trader Maryville, TN
