Are there any tricks to getting a HP 117A to lock to the current WWVB
transmissions.
I have read the thread for the Spectracom receivers.
Will this work with the 117A?
Thanks
73
Glenn
WB4UIV
When WWVB changed to BPSK, the phase-tracking receivers were rendered
inoperative.
Paul Swed has a tested design for a Costas Loop receiver front end and
demod that properly tracks the BPSK carrier phase and routes it to a 117A
or similar receiver.
There are also some hacks that, knowing the time, invert the WWVB signal
phase, in sync with the data, but no product that I know of.
-John
transmissions.
Thanks
73
Glenn
WB4UIV
To unsubscribe, go to
Johns
Right the costas loop is specifically for phase tracking rcvrs like the
117. Its a general purpose solution that keeps you out of the insides. But
that said you can take just the costas loop and integrate it into a 117. I
strongly belive that statement doesn't really address how things may work.
I will say the 117 with good tubes is pretty darn hot so it may work quite
well.
No intent to hack my 117s.
Regards
Paul
WB8TSL
inoperative.
-John
transmissions.
Thanks
73
Glenn
WB4UIV
