View all threadsHi,
Does anyone know what the input requirements are for the rear-panel external 10 MHz reference input and the 1 PPS input?
I am using an OctoClock-G and will need to connect it to USRPs that may be as far away as 50 ft. I'm trying to determine if the signal level at the USRP input will be sufficient. The OctoClock-G output specs are typ. ~1.4 Vpp square wave for the 10 MHz output (50 ohm output impedance), and a 5V logic-level pulse for the 1 PPS output, according to the data sheet.
Thanks,
Liz
For the PPS in, 5V and 50 ohms (non-DC). See page 12 of the schematic which shows the 49.9 ohm resistor and a 1k/2k voltage divider.
http://files.ettus.com/schematics/x300/x3xx.pdf
Depending on the Vin min of the SN74AUP1T17 Schmitt trigger, you might be able to get away with something less than 5 V.
Regards,
Andy
On September 23, 2014 5:28:32 PM EDT, "Kemp, Elizabeth - 1008 - MITLL via USRP-users" usrp-users@lists.ettus.com wrote:
Hi,
to the data sheet.
Thanks,
Liz
USRP-users mailing list
USRP-users@lists.ettus.com
50 feet should not be a problem unless you were to use some really horrible
cable.
Matt
On Tue, Sep 23, 2014 at 2:28 PM, Kemp, Elizabeth - 1008 - MITLL via
USRP-users usrp-users@lists.ettus.com wrote:
Hi,
as far away as 50 ft. I’m trying to determine if the signal level at the
Thanks,
Liz
horrible cable.
Matt
Even RG-174 (about the most-awful cable I'd consider for a 50ft run) has
only 3.3dB/100ft at 10MHz, so should be fine.
Marcus Leech
Principal Investigator
Shirleys Bay Radio Astronomy Consortium
http://www.sbrac.org
