Implementing RIL for windows mobile device
JM
John Mervin
Thu, Dec 11, 2008 1:23 PM
Hi Experts,
I think i found a solution for the earpiece in windows mobile device like
HTC, Samsung and others.
The solution is to use the ril dll in the mobile device system like msdn
said.
The structure for the audio device that we can found in ril.h from
microsoft:
HRESULT RIL_GetAudioDevices(
HRIL hRil                          // @parm handle to RIL instance
returned by <f RIL_Initialize>
HRESULT RIL_SetAudioDevices(
HRIL hRil,                                  // @parm handle to RIL
instance returned by <f RIL_Initialize>
const RILAUDIODEVICEINFO* lpAudioDeviceInfo // @parm audio devices to
set
#define RIL_AUDIO_NONE                              (0x00000000)      //
@constdefine No audio devices
#define RIL_AUDIO_HANDSET                          (0x00000001)      //
@constdefine Handset
#define RIL_AUDIO_SPEAKERPHONE                      (0x00000002)      //
@constdefine Speakerphone
#define RIL_AUDIO_HEADSET                          (0x00000003)      //
@constdefine Headset
#define RIL_AUDIO_CARKIT                            (0x00000004)      //
@constdefine Carkit
Ok but how to implement this in PJSIP ?
It's just to solve this issue that many users have with this mobile system,
the sound is in the rearpiece and not to the earpiece like we can see with
Skype.
So you have echo, it's not a private call because every people around you
can listen what you hear ...
In Symbian, it's different they already have the solution with PJSIP and in
internal code to route the speech.
Anybody's interrested by this implementation ? May be by Nanang or Benny ?
I'm waiting your posts.
Hi Experts, I think i found a solution for the earpiece in windows mobile device like HTC, Samsung and others. The solution is to use the ril dll in the mobile device system like msdn said. The structure for the audio device that we can found in ril.h from microsoft: HRESULT RIL_GetAudioDevices( HRIL hRil // @parm handle to RIL instance returned by <f RIL_Initialize> ); HRESULT RIL_SetAudioDevices( HRIL hRil, // @parm handle to RIL instance returned by <f RIL_Initialize> const RILAUDIODEVICEINFO* lpAudioDeviceInfo // @parm audio devices to set ); #define RIL_AUDIO_NONE (0x00000000) // @constdefine No audio devices #define RIL_AUDIO_HANDSET (0x00000001) // @constdefine Handset #define RIL_AUDIO_SPEAKERPHONE (0x00000002) // @constdefine Speakerphone #define RIL_AUDIO_HEADSET (0x00000003) // @constdefine Headset #define RIL_AUDIO_CARKIT (0x00000004) // @constdefine Carkit Ok but how to implement this in PJSIP ? It's just to solve this issue that many users have with this mobile system, the sound is in the rearpiece and not to the earpiece like we can see with Skype. So you have echo, it's not a private call because every people around you can listen what you hear ... In Symbian, it's different they already have the solution with PJSIP and in internal code to route the speech. Anybody's interrested by this implementation ? May be by Nanang or Benny ? I'm waiting your posts.
BP
Benny Prijono
Tue, Jan 20, 2009 8:10 AM
Hi John,
sorry for the late reply!
This is very useful indeed. Unfortunately the current sound device API
doesn't support audio routing, but I have plan to revamp that and by then I
will incorporate this to the new API. In the meantime, I guess people will
have to use this code in the application space.
Thanks again,
Benny
On Thu, Dec 11, 2008 at 1:23 PM, John Mervin johnmervin83@gmail.com wrote:
Hi Experts,
said.
microsoft:
set
@constdefine Carkit
Skype.
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Hi John, sorry for the late reply! This is very useful indeed. Unfortunately the current sound device API doesn't support audio routing, but I have plan to revamp that and by then I will incorporate this to the new API. In the meantime, I guess people will have to use this code in the application space. Thanks again, Benny On Thu, Dec 11, 2008 at 1:23 PM, John Mervin <johnmervin83@gmail.com> wrote: > Hi Experts, > > I think i found a solution for the earpiece in windows mobile device like > HTC, Samsung and others. > The solution is to use the ril dll in the mobile device system like msdn > said. > > The structure for the audio device that we can found in ril.h from > microsoft: > > HRESULT RIL_GetAudioDevices( > HRIL hRil // @parm handle to RIL instance > returned by <f RIL_Initialize> > ); > > HRESULT RIL_SetAudioDevices( > HRIL hRil, // @parm handle to RIL > instance returned by <f RIL_Initialize> > const RILAUDIODEVICEINFO* lpAudioDeviceInfo // @parm audio devices to > set > ); > > #define RIL_AUDIO_NONE (0x00000000) // > @constdefine No audio devices > #define RIL_AUDIO_HANDSET (0x00000001) // > @constdefine Handset > #define RIL_AUDIO_SPEAKERPHONE (0x00000002) // > @constdefine Speakerphone > #define RIL_AUDIO_HEADSET (0x00000003) // > @constdefine Headset > #define RIL_AUDIO_CARKIT (0x00000004) // > @constdefine Carkit > > Ok but how to implement this in PJSIP ? > It's just to solve this issue that many users have with this mobile system, > the sound is in the rearpiece and not to the earpiece like we can see with > Skype. > So you have echo, it's not a private call because every people around you > can listen what you hear ... > In Symbian, it's different they already have the solution with PJSIP and in > internal code to route the speech. > > Anybody's interrested by this implementation ? May be by Nanang or Benny ? > > I'm waiting your posts. > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > >
