Yes, these radiant electric cook tops are amazing! You
cannot compare them with the old coiled-element designs.
The thermostats are so quick and sensitive that you have much
better heat control than with gas!
The all glass cooking surface makes clean up effortless.
Now to find an RV size cooktop to replace the crude
burners on my old Princess Stove!
Princess Model 2243 has two 1000 watt 120 volt radiant elements in a glass
top unit.
Not sure if they have a 3 burner available so you may have to buy a pair if
you need more burners.
It is in the Post Marine Supply catalog but special order from Defender or
West.
Don
top unit.
West.
Don
