working with the N200 with a laptop with a 10/100 eth chip
IG
iftah giladi
Sun, Feb 9, 2014 1:42 PM
Hi,
Is it possible to work with the N200 with a laptop that has a RTL8103
Ethernet controller (not a 1Gb Ethernet.. Just 10/100 Mb Ethernet)?
Thanks,
iftah
Hi, Is it possible to work with the N200 with a laptop that has a RTL8103 Ethernet controller (not a 1Gb Ethernet.. Just 10/100 Mb Ethernet)? Thanks, iftah
MD
Marcus D. Leech
Mon, Feb 10, 2014 5:28 PM
On 02/09/2014 08:42 AM, iftah giladi wrote:
Hi,
Ethernet controller (not a 1Gb Ethernet.... Just 10/100 Mb Ethernet)?
Thanks,
iftah
USRP-users mailing list
USRP-users@lists.ettus.com
You'll need to use an intermediate 1GiGe switch--plug your laptop into
one port, and the N200 into the other.  You'll be limited to fairly-low
sample rates--about 2Msps.
Marcus Leech
Principal Investigator
Shirleys Bay Radio Astronomy Consortium
http://www.sbrac.org
On 02/09/2014 08:42 AM, iftah giladi wrote: > > Hi, > > Is it possible to work with the N200 with a laptop that has a RTL8103 > Ethernet controller (not a 1Gb Ethernet.... Just 10/100 Mb Ethernet)? > > Thanks, > > iftah > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com You'll need to use an intermediate 1GiGe switch--plug your laptop into one port, and the N200 into the other. You'll be limited to fairly-low sample rates--about 2Msps. -- Marcus Leech Principal Investigator Shirleys Bay Radio Astronomy Consortium http://www.sbrac.org
MM
Marcus Müller
Mon, Feb 10, 2014 8:31 PM
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Also, business notebooks have been shipping Gigabit ports for about a
decade now, and RTL8103 was introduced as a moderately integrated
ethernet solution in 2008, pointing to a very low-budget notebook... I
suspect your notebook might be a bit weak to do much with the samples,
even if you just intend to get 2Msps, which is a quite wasteful if you
intend to get a N200.
Since your question was whether you could "work with the N200 with a
laptop that has a RTL8103", I'd say: depends on your application. Most
probably you won't be very happy. Generally, it makes a lot of sense
to get a decent computer for signal processing.
Greetings,
Marcus
Hi,
RTL8103 Ethernet controller (not a 1Gb Ethernet.... Just 10/100
Mb Ethernet)?
Thanks,
iftah
_______________________________________________ USRP-users
mailing list USRP-users@lists.ettus.com
_______________________________________________ USRP-users mailing
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJS+TcaAAoJEAFxB7BbsDrLrgAH/j5wpuGStzu7aENuWmsGrIG6
jda/hW/yLCknsU3fMzUWxDasL0mPx+Dy1qAJ7HhXbRL2Z2a4N7WzmWmyF5E/CvkJ
CaUcRKM6QOc8lMCnGxf5CJFDSdF2htUb367cNqxp0/aG20R69a/I6CFRjVa3MCdo
Un7LM9ljMV1NAwibXVb8qJQBsGN/doowMxh5IByoqC9VfSp7WhPrNk7Z3fiKuvE1
P6/insUk6wS0CDB7j0QbH8iR4iCFwNLccsPFT4FWf8C0riteGq4uTums7v4tSYz5
UF0Jz4V3XM+2vv9H4CU72CIrI9xN5Zpib02lOsZ0Oa2fDhSst0zv+gTiwToDqDw=
=Us0v
-----END PGP SIGNATURE-----
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 Also, business notebooks have been shipping Gigabit ports for about a decade now, and RTL8103 was introduced as a moderately integrated ethernet solution in 2008, pointing to a very low-budget notebook... I suspect your notebook might be a bit weak to do much with the samples, even if you just intend to get 2Msps, which is a quite wasteful if you intend to get a N200. Since your question was whether you could "work with the N200 with a laptop that has a RTL8103", I'd say: depends on your application. Most probably you won't be very happy. Generally, it makes a lot of sense to get a decent computer for signal processing. Greetings, Marcus On 10.02.2014 18:28, Marcus D. Leech wrote: > On 02/09/2014 08:42 AM, iftah giladi wrote: >> >> Hi, >> >> Is it possible to work with the N200 with a laptop that has a >> RTL8103 Ethernet controller (not a 1Gb Ethernet.... Just 10/100 >> Mb Ethernet)? >> >> Thanks, >> >> iftah >> >> >> _______________________________________________ USRP-users >> mailing list USRP-users@lists.ettus.com >> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com > >> You'll need to use an intermediate 1GiGe switch--plug your laptop into > one port, and the N200 into the other. You'll be limited to > fairly-low sample rates--about 2Msps. > > > > > > _______________________________________________ USRP-users mailing > list USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com > -----BEGIN PGP SIGNATURE----- Version: GnuPG v1 Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/ iQEcBAEBAgAGBQJS+TcaAAoJEAFxB7BbsDrLrgAH/j5wpuGStzu7aENuWmsGrIG6 jda/hW/yLCknsU3fMzUWxDasL0mPx+Dy1qAJ7HhXbRL2Z2a4N7WzmWmyF5E/CvkJ CaUcRKM6QOc8lMCnGxf5CJFDSdF2htUb367cNqxp0/aG20R69a/I6CFRjVa3MCdo Un7LM9ljMV1NAwibXVb8qJQBsGN/doowMxh5IByoqC9VfSp7WhPrNk7Z3fiKuvE1 P6/insUk6wS0CDB7j0QbH8iR4iCFwNLccsPFT4FWf8C0riteGq4uTums7v4tSYz5 UF0Jz4V3XM+2vv9H4CU72CIrI9xN5Zpib02lOsZ0Oa2fDhSst0zv+gTiwToDqDw= =Us0v -----END PGP SIGNATURE-----
