trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Cold molded versus steel
BE
bob england
Sun, Apr 22, 2007 2:41 PM
I agree that "veneered" would better describe the cold molded method. It seems
as if a lot of builders are using the term "cold molded" to describe any
fiberglass over wood construction. The real benifit of cold molding is that
the wood is encapsulated in epoxy, which "supposedly" prevents rot. And the
fact that wood is about the strongest material available at a decent price for
boat building. I am a proponent of cold molded boat building, but I have it on
good authority that some of the top builders use a LOT of plywood in there
hulls, at any large semi flat areas that it could be used in, veneered inside
and out. I'm told that this cuts down labor costs on an otherwise very labor
intensive endeavor. I've seen the results of encapsulated plywood, and for the
most part I'm not impressed, but maybe coldmolded over ply is better than
fiberglass over ply. They say if it doesn't get wet it's never a problem,
after all it's "encapsulated". Yeah right, this is a boat we're talking about
isn't it ? For my money, steel would be hard to beat, (disclaimer: I don't
have and have never owned a steel boat) mostly because I'm comfortable working
with that material and I have the most cofidence in it's strength.
Invite your mail contacts to join your friends list with Windows Live Spaces.
It's easy!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&m
kt=en-us
I agree that "veneered" would better describe the cold molded method. It seems as if a lot of builders are using the term "cold molded" to describe any fiberglass over wood construction. The real benifit of cold molding is that the wood is encapsulated in epoxy, which "supposedly" prevents rot. And the fact that wood is about the strongest material available at a decent price for boat building. I am a proponent of cold molded boat building, but I have it on good authority that some of the top builders use a LOT of plywood in there hulls, at any large semi flat areas that it could be used in, veneered inside and out. I'm told that this cuts down labor costs on an otherwise very labor intensive endeavor. I've seen the results of encapsulated plywood, and for the most part I'm not impressed, but maybe coldmolded over ply is better than fiberglass over ply. They say if it doesn't get wet it's never a problem, after all it's "encapsulated". Yeah right, this is a boat we're talking about isn't it ? For my money, steel would be hard to beat, (disclaimer: I don't have and have never owned a steel boat) mostly because I'm comfortable working with that material and I have the most cofidence in it's strength. _________________________________________________________________ Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy! http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&m kt=en-us
AJ
Arild Jensen
Sun, Apr 22, 2007 2:55 PM
-----Original Message-----
to describe any
REPLY
True cold molded construction uses wood strips that are much thicker than
veneers. Typically the stips are cut as thick as they can be while still
allowing flexibility to conform to the curves of the hull. 1/4 - 3/8"
thickness is more likely than a 0.030" veneer.
Using veneer would raise the ratio of resin to cellulose to an unacceptable
level ane effectively negate much of the benefits of using wood.  Cold
molded construction uses the superior strenght and structural advantage of
the wood cell arrangement.
Arild
> -----Original Message----- > From: bob england > I agree that "veneered" would better describe the cold molded > method. It seems as if a lot of builders are using the term "cold molded" to describe any > fiberglass over wood construction. REPLY True cold molded construction uses wood strips that are much thicker than veneers. Typically the stips are cut as thick as they can be while still allowing flexibility to conform to the curves of the hull. 1/4 - 3/8" thickness is more likely than a 0.030" veneer. Using veneer would raise the ratio of resin to cellulose to an unacceptable level ane effectively negate much of the benefits of using wood. Cold molded construction uses the superior strenght and structural advantage of the wood cell arrangement. Arild
MT
Mark Tilden
Sun, Apr 22, 2007 8:22 PM
There's a builder in my old home town (Portland, OR) that has a great
reputation for building cold-molded boats--both power and sail. I've sailed
a couple of their boats, including one of his early projects, a 42'
sailboat, built in 1982. We sailed the boat to Hawaii in 1996 in the West
Marine Pacific Cup. The boat is now 25 years old and is extremely solid. It
has done at least five (I actually think more, but don't remember) races to
Hawaii and back and been sailed hard. I've done some maintenance work on the
boat and been impressed with how solid it is after 25 years of
well-above-average use.
Here's a link to their web site that has some discussion about the build
process they use:
http://www.schoonercreek.com/const_process/construction_process1.htm
Incidentally, this is also the company (and process) that built "Ocean
Planet", Bruce Schwab's round-the-world open-60' racing sailboat.
I would definitely consider cold molded construction as one option for a
custom boat.
Mark Tilden
Selene 50 "Koinonia"
From: trawlers-and-trawlering-bounces@lists.samurai.com
[mailto:trawlers-and-trawlering-bounces@lists.samurai.com] On Behalf Of bob
england
Sent: Sunday, April 22, 2007 7:41 AM
To: trawlers-and-trawlering@lists.samurai.com
Subject: T&T: Cold molded versus steel
seems
for
on
inside
the
about
working
Spaces.
It's easy!
m
kt=en-us
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe send email to
trawlers-and-trawlering-request@lists.samurai.com with the word
UNSUBSCRIBE and nothing else in the subject or body of the message.
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
There's a builder in my old home town (Portland, OR) that has a great reputation for building cold-molded boats--both power and sail. I've sailed a couple of their boats, including one of his early projects, a 42' sailboat, built in 1982. We sailed the boat to Hawaii in 1996 in the West Marine Pacific Cup. The boat is now 25 years old and is extremely solid. It has done at least five (I actually think more, but don't remember) races to Hawaii and back and been sailed hard. I've done some maintenance work on the boat and been impressed with how solid it is after 25 years of well-above-average use. Here's a link to their web site that has some discussion about the build process they use: http://www.schoonercreek.com/const_process/construction_process1.htm Incidentally, this is also the company (and process) that built "Ocean Planet", Bruce Schwab's round-the-world open-60' racing sailboat. I would definitely consider cold molded construction as one option for a custom boat. Mark Tilden Selene 50 "Koinonia" -----Original Message----- From: trawlers-and-trawlering-bounces@lists.samurai.com [mailto:trawlers-and-trawlering-bounces@lists.samurai.com] On Behalf Of bob england Sent: Sunday, April 22, 2007 7:41 AM To: trawlers-and-trawlering@lists.samurai.com Subject: T&T: Cold molded versus steel I agree that "veneered" would better describe the cold molded method. It seems as if a lot of builders are using the term "cold molded" to describe any fiberglass over wood construction. The real benifit of cold molding is that the wood is encapsulated in epoxy, which "supposedly" prevents rot. And the fact that wood is about the strongest material available at a decent price for boat building. I am a proponent of cold molded boat building, but I have it on good authority that some of the top builders use a LOT of plywood in there hulls, at any large semi flat areas that it could be used in, veneered inside and out. I'm told that this cuts down labor costs on an otherwise very labor intensive endeavor. I've seen the results of encapsulated plywood, and for the most part I'm not impressed, but maybe coldmolded over ply is better than fiberglass over ply. They say if it doesn't get wet it's never a problem, after all it's "encapsulated". Yeah right, this is a boat we're talking about isn't it ? For my money, steel would be hard to beat, (disclaimer: I don't have and have never owned a steel boat) mostly because I'm comfortable working with that material and I have the most cofidence in it's strength. _________________________________________________________________ Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy! http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx& m kt=en-us _______________________________________________ http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering To unsubscribe send email to trawlers-and-trawlering-request@lists.samurai.com with the word UNSUBSCRIBE and nothing else in the subject or body of the message. Trawlers & Trawlering and T&T are trademarks of Water World Productions. Unauthorized use is prohibited.
JW
John Walsh
Mon, Apr 23, 2007 1:02 PM
Although I can appreciate that a new cold-molded hull would have the best of
fiberglass and wood, what about old boats?  It is usually considered bad
technique to core fiberglass below the waterline.  There is a 30 year old
Gilliken trawler listed for sale on the web with great looking pictures, but
doesn't water eventually penetrate into the wood?  How can you repair soft
spots in this complex integration of wood and resin?
John
S/F Profishent
sailed
It
to
the
process they use:
custom boat.
Mark Tilden
bob
england
seems
that
the
for
it
on
inside
labor
the
about
working
Spaces.
It's easy!
m
kt=en-us
Although I can appreciate that a new cold-molded hull would have the best of fiberglass and wood, what about old boats? It is usually considered bad technique to core fiberglass below the waterline. There is a 30 year old Gilliken trawler listed for sale on the web with great looking pictures, but doesn't water eventually penetrate into the wood? How can you repair soft spots in this complex integration of wood and resin? John S/F Profishent On 4/22/07, Mark Tilden <mark@mdt-consulting.com> wrote: > > There's a builder in my old home town (Portland, OR) that has a great > reputation for building cold-molded boats--both power and sail. I've > sailed > a couple of their boats, including one of his early projects, a 42' > sailboat, built in 1982. We sailed the boat to Hawaii in 1996 in the West > Marine Pacific Cup. The boat is now 25 years old and is extremely solid. > It > has done at least five (I actually think more, but don't remember) races > to > Hawaii and back and been sailed hard. I've done some maintenance work on > the > boat and been impressed with how solid it is after 25 years of > well-above-average use. > > Here's a link to their web site that has some discussion about the build > process they use: > > http://www.schoonercreek.com/const_process/construction_process1.htm > > Incidentally, this is also the company (and process) that built "Ocean > Planet", Bruce Schwab's round-the-world open-60' racing sailboat. > > I would definitely consider cold molded construction as one option for a > custom boat. > > Mark Tilden > Selene 50 "Koinonia" > > > > -----Original Message----- > From: trawlers-and-trawlering-bounces@lists.samurai.com > [mailto:trawlers-and-trawlering-bounces@lists.samurai.com] On Behalf Of > bob > england > Sent: Sunday, April 22, 2007 7:41 AM > To: trawlers-and-trawlering@lists.samurai.com > Subject: T&T: Cold molded versus steel > > I agree that "veneered" would better describe the cold molded method. It > seems > as if a lot of builders are using the term "cold molded" to describe any > fiberglass over wood construction. The real benifit of cold molding is > that > the wood is encapsulated in epoxy, which "supposedly" prevents rot. And > the > fact that wood is about the strongest material available at a decent price > for > boat building. I am a proponent of cold molded boat building, but I have > it > on > good authority that some of the top builders use a LOT of plywood in there > hulls, at any large semi flat areas that it could be used in, veneered > inside > and out. I'm told that this cuts down labor costs on an otherwise very > labor > intensive endeavor. I've seen the results of encapsulated plywood, and for > the > most part I'm not impressed, but maybe coldmolded over ply is better than > fiberglass over ply. They say if it doesn't get wet it's never a problem, > after all it's "encapsulated". Yeah right, this is a boat we're talking > about > isn't it ? For my money, steel would be hard to beat, (disclaimer: I don't > have and have never owned a steel boat) mostly because I'm comfortable > working > with that material and I have the most cofidence in it's strength. > _________________________________________________________________ > Invite your mail contacts to join your friends list with Windows Live > Spaces. > It's easy! > > http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx& > m > kt=en-us > _______________________________________________ > http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering > > To unsubscribe send email to > trawlers-and-trawlering-request@lists.samurai.com with the word > UNSUBSCRIBE and nothing else in the subject or body of the message. > > Trawlers & Trawlering and T&T are trademarks of Water World > Productions. Unauthorized use is prohibited. > _______________________________________________ > http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering > > To unsubscribe send email to > trawlers-and-trawlering-request@lists.samurai.com with the word > UNSUBSCRIBE and nothing else in the subject or body of the message. > > Trawlers & Trawlering and T&T are trademarks of Water World > Productions. Unauthorized use is prohibited.
MT
Mark Tilden
Mon, Apr 23, 2007 2:42 PM
I'm certainly no expert on cold molded construction. I'll just give you a
couple of observations from my experience:
  1. If the core material is closed-cell foam and properly installed, and
    the planks are properly sealed and bedded in epoxy, even if the hull is
    damaged, water can't migrate along the core. While coring below the
    waterline is not common in trawlers, it's quite common in performance
    sailboats (i.e. all J-Boats are cored below the waterline). This is not
    considered "bad technique" - it simply requires more care in construction
    and maintenance.
  2. A few years back (2002), "Rage" a 70 racing sailboat built by the
    same company was grounded hard on a rock near Victoria BC going at least 8
    knots. There was substantial damage to the hull, though with some temporary
    repairs, the boat was sailed back down the Washington coast to the Schooner
    Creek yard in Portland. The crew there removed the keel and repaired the
    hull by cutting out an area surrounding the keel and building it back up
    using a similar technique (with some added carbon fiber for extra strength).
    Again, I don't claim to be an expert in cold molded construction or repair,
    but I watched through the entire process (as my J/130 was out of the water
    in the Schooner Creek yard at the time) and I've been told by their crew
    that repairing the cold-molded hull is no more difficult than repairing any
    cored fiberglass hull.
  3. As I mentioned in the original post, "Magic Carpet" is 25 years old
    and there is no evidence that I've seen that the hull has been compromised
    by water. Remember that epoxy is much more impervious to water than
    polyester resin.
If you have specific questions about this, you might want give Steve Rander
at Schooner Creek a call and talk to them about the technique.
Mark
From: John Walsh [mailto:john.j.walsh.jr@gmail.com]
Sent: Monday, April 23, 2007 6:02 AM
To: mark@mdt-consulting.com
Cc: trawlers-and-trawlering@lists.samurai.com
Subject: Re: T&T: Cold molded versus steel
John
S/F Profishent
process they use:
custom boat.
Mark Tilden
england
seems
for
on
inside
the
about
working
Spaces.
It's easy!
<http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx
&> &wx_url=/friends.aspx&
m
kt=en-us
I'm certainly no expert on cold molded construction. I'll just give you a couple of observations from my experience: 1. If the core material is closed-cell foam and properly installed, and the planks are properly sealed and bedded in epoxy, even if the hull is damaged, water can't migrate along the core. While coring below the waterline is not common in trawlers, it's quite common in performance sailboats (i.e. all J-Boats are cored below the waterline). This is not considered "bad technique" - it simply requires more care in construction and maintenance. 2. A few years back (2002), "Rage" a 70 racing sailboat built by the same company was grounded hard on a rock near Victoria BC going at least 8 knots. There was substantial damage to the hull, though with some temporary repairs, the boat was sailed back down the Washington coast to the Schooner Creek yard in Portland. The crew there removed the keel and repaired the hull by cutting out an area surrounding the keel and building it back up using a similar technique (with some added carbon fiber for extra strength). Again, I don't claim to be an expert in cold molded construction or repair, but I watched through the entire process (as my J/130 was out of the water in the Schooner Creek yard at the time) and I've been told by their crew that repairing the cold-molded hull is no more difficult than repairing any cored fiberglass hull. 3. As I mentioned in the original post, "Magic Carpet" is 25 years old and there is no evidence that I've seen that the hull has been compromised by water. Remember that epoxy is much more impervious to water than polyester resin. If you have specific questions about this, you might want give Steve Rander at Schooner Creek a call and talk to them about the technique. Mark _____ From: John Walsh [mailto:john.j.walsh.jr@gmail.com] Sent: Monday, April 23, 2007 6:02 AM To: mark@mdt-consulting.com Cc: trawlers-and-trawlering@lists.samurai.com Subject: Re: T&T: Cold molded versus steel Although I can appreciate that a new cold-molded hull would have the best of fiberglass and wood, what about old boats? It is usually considered bad technique to core fiberglass below the waterline. There is a 30 year old Gilliken trawler listed for sale on the web with great looking pictures, but doesn't water eventually penetrate into the wood? How can you repair soft spots in this complex integration of wood and resin? John S/F Profishent On 4/22/07, Mark Tilden <mark@mdt-consulting.com> wrote: There's a builder in my old home town (Portland, OR) that has a great reputation for building cold-molded boats--both power and sail. I've sailed a couple of their boats, including one of his early projects, a 42' sailboat, built in 1982. We sailed the boat to Hawaii in 1996 in the West Marine Pacific Cup. The boat is now 25 years old and is extremely solid. It has done at least five (I actually think more, but don't remember) races to Hawaii and back and been sailed hard. I've done some maintenance work on the boat and been impressed with how solid it is after 25 years of well-above-average use. Here's a link to their web site that has some discussion about the build process they use: http://www.schoonercreek.com/const_process/construction_process1.htm Incidentally, this is also the company (and process) that built "Ocean Planet", Bruce Schwab's round-the-world open-60' racing sailboat. I would definitely consider cold molded construction as one option for a custom boat. Mark Tilden Selene 50 "Koinonia" -----Original Message----- From: trawlers-and-trawlering-bounces@lists.samurai.com [mailto:trawlers-and-trawlering-bounces@lists.samurai.com] On Behalf Of bob england Sent: Sunday, April 22, 2007 7:41 AM To: trawlers-and-trawlering@lists.samurai.com Subject: T&T: Cold molded versus steel I agree that "veneered" would better describe the cold molded method. It seems as if a lot of builders are using the term "cold molded" to describe any fiberglass over wood construction. The real benifit of cold molding is that the wood is encapsulated in epoxy, which "supposedly" prevents rot. And the fact that wood is about the strongest material available at a decent price for boat building. I am a proponent of cold molded boat building, but I have it on good authority that some of the top builders use a LOT of plywood in there hulls, at any large semi flat areas that it could be used in, veneered inside and out. I'm told that this cuts down labor costs on an otherwise very labor intensive endeavor. I've seen the results of encapsulated plywood, and for the most part I'm not impressed, but maybe coldmolded over ply is better than fiberglass over ply. They say if it doesn't get wet it's never a problem, after all it's "encapsulated". Yeah right, this is a boat we're talking about isn't it ? For my money, steel would be hard to beat, (disclaimer: I don't have and have never owned a steel boat) mostly because I'm comfortable working with that material and I have the most cofidence in it's strength. _________________________________________________________________ Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy! http://spaces.live.com/spacesapi.aspx?wx_action=create <http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx &> &wx_url=/friends.aspx& m kt=en-us _______________________________________________ http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering To unsubscribe send email to trawlers-and-trawlering-request@lists.samurai.com with the word UNSUBSCRIBE and nothing else in the subject or body of the message. Trawlers & Trawlering and T&T are trademarks of Water World Productions. Unauthorized use is prohibited. _______________________________________________ http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering To unsubscribe send email to trawlers-and-trawlering-request@lists.samurai.com with the word UNSUBSCRIBE and nothing else in the subject or body of the message. Trawlers & Trawlering and T&T are trademarks of Water World Productions. Unauthorized use is prohibited.
