trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: T&T: Bilge cleaning recipe - Warning!
MB
Milt Baker
Sun, Oct 31, 2010 6:53 PM
THANKS, RON!
I've used the mixture in the Southern Boating receipe at least a half dozen times since it first appeared without the reaction you got, but based on what you say I cannot in good conscience recommend it now.  My recommendation to everyone:
DO NOT TRY THE SOUTHERN BOATING BILGE CLEANING RECIPE I POSTED ON OCT. 26.
--Milt Baker, Nordhavn 47 Bluewater, Fort Lauderdale
-----Original Message-----
Sent: Oct 31, 2010 2:21 PM
To: 'Milt Baker' miltbaker@mindspring.com, 'Trawlers and Trawlering List' trawlers-and-trawlering@lists.samurai.com
Subject: RE: Bilge cleaning recipe - Warning!
You are recreating WWI in your bilge! I know because I just made a similar
mistake in my toilet bowl by adding too much Clorox to what was probably
uric acid. The chlorine gas liberated caused me to choke and run to turn on
a forward hatch exhaust fan - fast. Lemon juice is citric acid which, if
added to sodium hypochlorite liberates chlorine gas. Chlorine or phosgene
gas in sufficient concentrations can kill you or cripple your lungs. As a
child, I encountered two WWI gas survivors - not swell. To confirm my
experience, I just confirmed this chemical reaction via Google. Avoid this
powerful, albeit effective, mixture.
Ron Rogers
Sent: Tuesday, October 26, 2010 9:29 PM
Southern Boating magazine ran this recipe for bilge cleaner in Oct. 1998 and
I've used it with success many times on my Grand Bankses and once or twice
on the Nordhavn. This chemical brew does a terrific job of cleaning bilges
and getting rid of oily residue. If it doesn't do the job the first time
around, wait a week and do it all over again.  Your bilges will be so white
you won't recognize them!
Into a five-gallon bucket, pour one quart of ERA concentrated liquid or
similar laundry detergent. Add one gallon of Clorox or other chlorine bleach
and eight ounces of bottled lemon juice concentrate. Top off with water to
make four to five gallons. Turn off your bilge pumps, pour the mixture into
the bilge, and allow it to stand overnight if the boat rocks constantly or
longer if the boat does not rock much. A light rinse with a hose may be
needed to complete the job.
Suck the mixture up with a portable bilge pump and dispose of it properly,
then turn your bilge pump switches back on.
One caution: the chlorine odor is very strong, so don't plan to spend much
time on the boat while the mixture is in the bilge!
Good luck!
THANKS, RON! I've used the mixture in the Southern Boating receipe at least a half dozen times since it first appeared without the reaction you got, but based on what you say I cannot in good conscience recommend it now. My recommendation to everyone: DO NOT TRY THE SOUTHERN BOATING BILGE CLEANING RECIPE I POSTED ON OCT. 26. --Milt Baker, Nordhavn 47 Bluewater, Fort Lauderdale -----Original Message----- >From: Ron Rogers <rcrogers6@gmail.com> >Sent: Oct 31, 2010 2:21 PM >To: 'Milt Baker' <miltbaker@mindspring.com>, 'Trawlers and Trawlering List' <trawlers-and-trawlering@lists.samurai.com> >Subject: RE: Bilge cleaning recipe - Warning! > >You are recreating WWI in your bilge! I know because I just made a similar >mistake in my toilet bowl by adding too much Clorox to what was probably >uric acid. The chlorine gas liberated caused me to choke and run to turn on >a forward hatch exhaust fan - fast. Lemon juice is citric acid which, if >added to sodium hypochlorite liberates chlorine gas. Chlorine or phosgene >gas in sufficient concentrations can kill you or cripple your lungs. As a >child, I encountered two WWI gas survivors - not swell. To confirm my >experience, I just confirmed this chemical reaction via Google. Avoid this >powerful, albeit effective, mixture. > >Ron Rogers > >-----Original Message----- >From: Milt Baker >Sent: Tuesday, October 26, 2010 9:29 PM > >Southern Boating magazine ran this recipe for bilge cleaner in Oct. 1998 and >I've used it with success many times on my Grand Bankses and once or twice >on the Nordhavn. This chemical brew does a terrific job of cleaning bilges >and getting rid of oily residue. If it doesn't do the job the first time >around, wait a week and do it all over again. Your bilges will be so white >you won't recognize them! > >Into a five-gallon bucket, pour one quart of ERA concentrated liquid or >similar laundry detergent. Add one gallon of Clorox or other chlorine bleach >and eight ounces of bottled lemon juice concentrate. Top off with water to >make four to five gallons. Turn off your bilge pumps, pour the mixture into >the bilge, and allow it to stand overnight if the boat rocks constantly or >longer if the boat does not rock much. A light rinse with a hose may be >needed to complete the job. > >Suck the mixture up with a portable bilge pump and dispose of it properly, >then turn your bilge pump switches back on. > >One caution: the chlorine odor is very strong, so don't plan to spend much >time on the boat while the mixture is in the bilge! > >Good luck!
