discuss@lists.openscad.org
OpenSCAD general discussion Mailing-list
Hose Adapter for table saw
KE
Karl Exler
Wed, Aug 16, 2023 7:11 AM
Dear all
I found the enclosed adapter on Thingiverse. Unfortunately nearly all
diameters are not in that size I need it. Did anyone of you created such
an (similar) object in Openscad? Is it possible to get that file?
Or- if not- how would an expert start with that projects?
Until now I only use Openscad functions and some of the BOSL libraries.
Many thanks in advance
Karl
Dear all I found the enclosed adapter on Thingiverse. Unfortunately nearly all diameters are not in that size I need it. Did anyone of you created such an (similar) object in Openscad? Is it possible to get that file? Or- if not- how would an expert start with that projects? Until now I only use Openscad functions and some of the BOSL libraries. Many thanks in advance Karl
SP
Sanjeev Prabhakar
Wed, Aug 16, 2023 8:59 AM
This seems to me as quite a simple case although haven't tried it yet.
As per my understanding it should be easy to do with BOSL library. May be
Adrian can comment.
If you want,  I can make it through my python approach.
It is mainly 2 tubes which needs to be fused together and some easy
filleting.
Threads parts maybe a little tricky, but not too difficult for sure.
On Wed, 16 Aug, 2023, 12:42 pm Karl Exler, karl.exler@meinklang.cc wrote:
Dear all
Karl
OpenSCAD mailing list
To unsubscribe send an email to discuss-leave@lists.openscad.org
This seems to me as quite a simple case although haven't tried it yet. As per my understanding it should be easy to do with BOSL library. May be Adrian can comment. If you want, I can make it through my python approach. It is mainly 2 tubes which needs to be fused together and some easy filleting. Threads parts maybe a little tricky, but not too difficult for sure. On Wed, 16 Aug, 2023, 12:42 pm Karl Exler, <karl.exler@meinklang.cc> wrote: > Dear all > I found the enclosed adapter on Thingiverse. Unfortunately nearly all > diameters are not in that size I need it. Did anyone of you created such > an (similar) object in Openscad? Is it possible to get that file? > Or- if not- how would an expert start with that projects? > > Until now I only use Openscad functions and some of the BOSL libraries. > > Many thanks in advance > Karl > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
MH
Matthieu Hendriks
Wed, Aug 16, 2023 9:07 AM
I would split it up at least 4 or 5 cilinders, bottom and top straight,
middle  with different r1 and r2, and two cilnders for the left side.
The top with a tread inside from BOSSL or another treads library.
Should be do-able in openscad without the need for python.
Sanjeev Prabhakar schreef op 2023-08-16 10:59:
filleting.
wrote:
Dear all
such
libraries.
Karl
I would split it up at least 4 or 5 cilinders, bottom and top straight, middle with different r1 and r2, and two cilnders for the left side. The top with a tread inside from BOSSL or another treads library. Should be do-able in openscad without the need for python. ------------------------- Sanjeev Prabhakar schreef op 2023-08-16 10:59: > This seems to me as quite a simple case although haven't tried it yet. > > As per my understanding it should be easy to do with BOSL library. May > be Adrian can comment. > > If you want, I can make it through my python approach. > > It is mainly 2 tubes which needs to be fused together and some easy > filleting. > > Threads parts maybe a little tricky, but not too difficult for sure. > > On Wed, 16 Aug, 2023, 12:42 pm Karl Exler, <karl.exler@meinklang.cc> > wrote: > >> Dear all >> I found the enclosed adapter on Thingiverse. Unfortunately nearly all >> diameters are not in that size I need it. Did anyone of you created >> such >> an (similar) object in Openscad? Is it possible to get that file? >> Or- if not- how would an expert start with that projects? >> >> Until now I only use Openscad functions and some of the BOSL >> libraries. >> >> Many thanks in advance >> Karl >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
P
poppele (at) posteo.de
Wed, Aug 16, 2023 9:57 AM
Have a look at the osVAC-website and the pages on ThingiVerse
Absaugung für DeWALT 7492 & 7485 (STL Download zum selber Drucken) – Homewerken
https://homewerken.de/produkt/absaugung-dewalt-7492-stl-download/
No OpenSCAD-File
osVAC – osSso
https://ossso.de/osvac/
osvac-things - Search - Thingiverse
https://www.thingiverse.com/search?q=osvac&page=1&type=things&sort=relevant
Thingiverse - Digital Designs for Physical Objects
https://www.thingiverse.com/groups/osvac-dust-system
Have a look at the osVAC-website and the pages on ThingiVerse Absaugung für DeWALT 7492 & 7485 (STL Download zum selber Drucken) – Homewerken https://homewerken.de/produkt/absaugung-dewalt-7492-stl-download/ No OpenSCAD-File osVAC – osSso https://ossso.de/osvac/ osvac-things - Search - Thingiverse https://www.thingiverse.com/search?q=osvac&page=1&type=things&sort=relevant Thingiverse - Digital Designs for Physical Objects https://www.thingiverse.com/groups/osvac-dust-system
KE
karl.exler (at) meinklang.cc
Wed, Aug 16, 2023 10:33 AM
STLs downzuloaden ist ein bisschen wir Onanie....
Ich würde es gerne aus eigener Kraft schaffen ;-)
lG
Karl
Am 16. August 2023 11:57:23 MESZ schrieb poppele@posteo.de:
No OpenSCAD-File
osVAC – osSso
Diese Nachricht wurde von unterwegs gesendet...
STLs downzuloaden ist ein bisschen wir Onanie.... Ich würde es gerne aus eigener Kraft schaffen ;-) lG Karl Am 16. August 2023 11:57:23 MESZ schrieb poppele@posteo.de: >Have a look at the osVAC-website and the pages on ThingiVerse > >Absaugung für DeWALT 7492 & 7485 (STL Download zum selber Drucken) – Homewerken > >https://homewerken.de/produkt/absaugung-dewalt-7492-stl-download/ > >No OpenSCAD-File > >osVAC – osSso > >https://ossso.de/osvac/ > >osvac-things - Search - Thingiverse > >https://www.thingiverse.com/search?q=osvac&page=1&type=things&sort=relevant > >Thingiverse - Digital Designs for Physical Objects > >https://www.thingiverse.com/groups/osvac-dust-system -- Diese Nachricht wurde von unterwegs gesendet...
SP
Sanjeev Prabhakar
Wed, Aug 16, 2023 4:22 PM
openscad version
[image: Screenshot 2023-08-16 at 9.44.44 PM.png]
#python code to create this:
from openscad1 import *
sec=circle(25)
path=cr(pts1([[0,0,0],[0,15,1],[-6,50,1],[0,18,0]]),10)
sol=prism(sec,path)
sol1=prism(circle(24),path)
sol0=swp_prism_h(sol,sol1)
sec2=circle(15)
path2=cr_3d([[0,0,15,0],[-60,0,40,20],[0,0,30,0]],10)
sol2=path_extrude_open(sec2,path2)
sol3=path_extrude_open(offset(sec2,-1),path2)
sol02=swp_prism_h(sol2,sol3)
fillet1=ip_fillet(sol,sol2,3,3)
sec3=cr(pts1([[0,0],[-2,1,.2],[2,1]]),10)
path3=helix(14,2.5,6,5)
sol4=path_extrude_open(sec3,path3)
sol4=sol2vector([0,0,1,],sol4,[-60,0,70])
with open('/Users/sanjeevprabhakar/iCloud Drive
(Archive)/Documents/Download/openscad/trial.scad','w+') as f:
f.write(f'''
difference(){{
{swp_c(sol0)}
{swp(sol3)}
difference(){{
{swp_c(sol02)}
{swp(sol)}
{swp_c(fillet1)}
intersection(){{
color("blue"){swp(sol4)}
{swp(sol3)}
#for this code to work you would need  file openscad1.py
On Wed, 16 Aug 2023 at 14:29, Sanjeev Prabhakar sprabhakar2006@gmail.com
Adrian can comment.
filleting.
wrote:
Dear all
Karl
openscad version [image: Screenshot 2023-08-16 at 9.44.44 PM.png] #python code to create this: from openscad1 import * sec=circle(25) path=cr(pts1([[0,0,0],[0,15,1],[-6,50,1],[0,18,0]]),10) sol=prism(sec,path) sol1=prism(circle(24),path) sol0=swp_prism_h(sol,sol1) sec2=circle(15) path2=cr_3d([[0,0,15,0],[-60,0,40,20],[0,0,30,0]],10) sol2=path_extrude_open(sec2,path2) sol3=path_extrude_open(offset(sec2,-1),path2) sol02=swp_prism_h(sol2,sol3) fillet1=ip_fillet(sol,sol2,3,3) sec3=cr(pts1([[0,0],[-2,1,.2],[2,1]]),10) path3=helix(14,2.5,6,5) sol4=path_extrude_open(sec3,path3) sol4=sol2vector([0,0,1,],sol4,[-60,0,70]) with open('/Users/sanjeevprabhakar/iCloud Drive (Archive)/Documents/Download/openscad/trial.scad','w+') as f: f.write(f''' difference(){{ {swp_c(sol0)} {swp(sol3)} }} difference(){{ {swp_c(sol02)} {swp(sol)} }} {swp_c(fillet1)} intersection(){{ color("blue"){swp(sol4)} {swp(sol3)} }} ''') #for this code to work you would need file openscad1.py On Wed, 16 Aug 2023 at 14:29, Sanjeev Prabhakar <sprabhakar2006@gmail.com> wrote: > This seems to me as quite a simple case although haven't tried it yet. > > As per my understanding it should be easy to do with BOSL library. May be > Adrian can comment. > > If you want, I can make it through my python approach. > > It is mainly 2 tubes which needs to be fused together and some easy > filleting. > > Threads parts maybe a little tricky, but not too difficult for sure. > > > > > On Wed, 16 Aug, 2023, 12:42 pm Karl Exler, <karl.exler@meinklang.cc> > wrote: > >> Dear all >> I found the enclosed adapter on Thingiverse. Unfortunately nearly all >> diameters are not in that size I need it. Did anyone of you created such >> an (similar) object in Openscad? Is it possible to get that file? >> Or- if not- how would an expert start with that projects? >> >> Until now I only use Openscad functions and some of the BOSL libraries. >> >> Many thanks in advance >> Karl >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> >
J
jon
Wed, Aug 16, 2023 4:51 PM
How do the forum members feel about postings like this, which have more
to do with python than with OpenSCAD?  I personally find it to be
unnecessary and distracting, but I will defer to the feelings of the group.
Jon
On 8/16/2023 12:22 PM, Sanjeev Prabhakar wrote:
openscad version
sec=circle(25)
sol=prism(sec,path)
sec2=circle(15)
    f.write(f'''
difference(){{
{swp_c(sol0)}
{swp(sol3)}
difference(){{
{swp_c(sol02)}
{swp(sol)}
{swp_c(fillet1)}
intersection(){{
{swp(sol3)}
 yet.
 easy filleting.
     Dear all
     nearly all
     created such
     libraries.
     Karl
To unsubscribe send an email todiscuss-leave@lists.openscad.org
How do the forum members feel about postings like this, which have more to do with python than with OpenSCAD?  I personally find it to be unnecessary and distracting, but I will defer to the feelings of the group. Jon On 8/16/2023 12:22 PM, Sanjeev Prabhakar wrote: > openscad version > Screenshot 2023-08-16 at 9.44.44 PM.png > > #python code to create this: > > from openscad1 import * > sec=circle(25) > path=cr(pts1([[0,0,0],[0,15,1],[-6,50,1],[0,18,0]]),10) > sol=prism(sec,path) > sol1=prism(circle(24),path) > sol0=swp_prism_h(sol,sol1) > sec2=circle(15) > path2=cr_3d([[0,0,15,0],[-60,0,40,20],[0,0,30,0]],10) > sol2=path_extrude_open(sec2,path2) > sol3=path_extrude_open(offset(sec2,-1),path2) > sol02=swp_prism_h(sol2,sol3) > fillet1=ip_fillet(sol,sol2,3,3) > > sec3=cr(pts1([[0,0],[-2,1,.2],[2,1]]),10) > path3=helix(14,2.5,6,5) > sol4=path_extrude_open(sec3,path3) > > sol4=sol2vector([0,0,1,],sol4,[-60,0,70]) > with open('/Users/sanjeevprabhakar/iCloud Drive > (Archive)/Documents/Download/openscad/trial.scad','w+') as f: >     f.write(f''' > difference(){{ > {swp_c(sol0)} > {swp(sol3)} > }} > difference(){{ > {swp_c(sol02)} > {swp(sol)} > }} > {swp_c(fillet1)} > intersection(){{ > color("blue"){swp(sol4)} > {swp(sol3)} > }} > > ''') > > #for this code to work you would need  file openscad1.py > > On Wed, 16 Aug 2023 at 14:29, Sanjeev Prabhakar > <sprabhakar2006@gmail.com> wrote: > > This seems to me as quite a simple case although haven't tried it > yet. > > As per my understanding it should be easy to do with BOSL library. > May be Adrian can comment. > > If you want,  I can make it through my python approach. > > It is mainly 2 tubes which needs to be fused together and some > easy filleting. > > Threads parts maybe a little tricky, but not too difficult for sure. > > > > > On Wed, 16 Aug, 2023, 12:42 pm Karl Exler, > <karl.exler@meinklang.cc> wrote: > > Dear all > I found the enclosed adapter on Thingiverse. Unfortunately > nearly all > diameters are not in that size I need it. Did anyone of you > created such > an (similar) object in Openscad? Is it possible to get that file? > Or- if not- how would an expert start with that projects? > > Until now I only use Openscad functions and some of the BOSL > libraries. > > Many thanks in advance > Karl > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
MM
Michael Möller
Wed, Aug 16, 2023 5:44 PM
Well, that question should be debated in its own thread/subj:-line.
I feel we have 3 subject areas:
  1. The "pure" OpenSCAD usage questions: syntax, funktion, getting data
    in&out, versions, bugs ...
  2. The "add ons" - BOSL2 and Sanjeev's python frontend.
  3. Hardware related- ie on how to get a physical implementation of a model.
    The list could be subdivided a bit further.
IMHO the list should restrict itself to 1.  The occasional hardware
question is not a problem, but it gets a bit strained in that many OpenSCAD
questions are answered with "use this instead". Admittedly, pure (and
simple) OpenSCAD can not solve all 3D model desires, but should that be a
problem?
I found it nice to hear about BOSL2, but find longer problems irrelevant.
BOSL2 is bigger than OpenSCAD in the number of features and functions, i.e.
it is like  a new language (perhaps like C++ is "just" an extension of C ?)
Sanjeev's python work is also a new language which only uses OpenSCAD as a
render, as it produces one large polyhedra. Fantastic, but has almost
nothing to do with OpenSCAD.
Msquare
Jon
openscad version
sec=circle(25)
sol=prism(sec,path)
sec2=circle(15)
f.write(f'''
difference(){{
{swp_c(sol0)}
{swp(sol3)}
difference(){{
{swp_c(sol02)}
{swp(sol)}
{swp_c(fillet1)}
intersection(){{
{swp(sol3)}
Adrian can comment.
filleting.
wrote:
Dear all
Karl
Well, that question should be debated in its own thread/subj:-line. I feel we have 3 subject areas: 1) The "pure" OpenSCAD usage questions: syntax, funktion, getting data in&out, versions, bugs ... 2) The "add ons" - BOSL2 and Sanjeev's python frontend. 3) Hardware related- ie on how to get a physical implementation of a model. The list could be subdivided a bit further. IMHO the list should restrict itself to 1. The occasional hardware question is not a problem, but it gets a bit strained in that many OpenSCAD questions are answered with "use this instead". Admittedly, pure (and simple) OpenSCAD can not solve all 3D model desires, but should that be a problem? I found it nice to hear about BOSL2, but find longer problems irrelevant. BOSL2 is bigger than OpenSCAD in the number of features and functions, i.e. it is like a new language (perhaps like C++ is "just" an extension of C ?) Sanjeev's python work is also a new language which only uses OpenSCAD as a render, as it produces one large polyhedra. Fantastic, but has almost nothing to do with OpenSCAD. Msquare On Wed, 16 Aug 2023 at 18:52, jon <jon@jonbondy.com> wrote: > How do the forum members feel about postings like this, which have more to > do with python than with OpenSCAD? I personally find it to be unnecessary > and distracting, but I will defer to the feelings of the group. > > Jon > > > On 8/16/2023 12:22 PM, Sanjeev Prabhakar wrote: > > openscad version > [image: Screenshot 2023-08-16 at 9.44.44 PM.png] > > #python code to create this: > > from openscad1 import * > sec=circle(25) > path=cr(pts1([[0,0,0],[0,15,1],[-6,50,1],[0,18,0]]),10) > sol=prism(sec,path) > sol1=prism(circle(24),path) > sol0=swp_prism_h(sol,sol1) > sec2=circle(15) > path2=cr_3d([[0,0,15,0],[-60,0,40,20],[0,0,30,0]],10) > sol2=path_extrude_open(sec2,path2) > sol3=path_extrude_open(offset(sec2,-1),path2) > sol02=swp_prism_h(sol2,sol3) > fillet1=ip_fillet(sol,sol2,3,3) > > sec3=cr(pts1([[0,0],[-2,1,.2],[2,1]]),10) > path3=helix(14,2.5,6,5) > sol4=path_extrude_open(sec3,path3) > > sol4=sol2vector([0,0,1,],sol4,[-60,0,70]) > with open('/Users/sanjeevprabhakar/iCloud Drive > (Archive)/Documents/Download/openscad/trial.scad','w+') as f: > f.write(f''' > difference(){{ > {swp_c(sol0)} > {swp(sol3)} > }} > difference(){{ > {swp_c(sol02)} > {swp(sol)} > }} > {swp_c(fillet1)} > intersection(){{ > color("blue"){swp(sol4)} > {swp(sol3)} > }} > > ''') > > #for this code to work you would need file openscad1.py > > On Wed, 16 Aug 2023 at 14:29, Sanjeev Prabhakar <sprabhakar2006@gmail.com> > wrote: > >> This seems to me as quite a simple case although haven't tried it yet. >> >> As per my understanding it should be easy to do with BOSL library. May be >> Adrian can comment. >> >> If you want, I can make it through my python approach. >> >> It is mainly 2 tubes which needs to be fused together and some easy >> filleting. >> >> Threads parts maybe a little tricky, but not too difficult for sure. >> >> >> >> >> On Wed, 16 Aug, 2023, 12:42 pm Karl Exler, <karl.exler@meinklang.cc> >> wrote: >> >>> Dear all >>> I found the enclosed adapter on Thingiverse. Unfortunately nearly all >>> diameters are not in that size I need it. Did anyone of you created such >>> an (similar) object in Openscad? Is it possible to get that file? >>> Or- if not- how would an expert start with that projects? >>> >>> Until now I only use Openscad functions and some of the BOSL libraries. >>> >>> Many thanks in advance >>> Karl >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
J
jon
Wed, Aug 16, 2023 6:46 PM
I agree that this should be separate.  Thanks for pointing this out.
Jon
    model.
Msquare
 Jon
 openscad version
 sec=circle(25)
 sol=prism(sec,path)
 sec2=circle(15)
     f.write(f'''
 difference(){{
 {swp_c(sol0)}
 {swp(sol3)}
 difference(){{
 {swp_c(sol02)}
 {swp(sol)}
 {swp_c(fillet1)}
 intersection(){{
 {swp(sol3)}
I agree that this should be separate.  Thanks for pointing this out. Jon On 8/16/2023 1:44 PM, Michael Möller wrote: > Well, that question should be debated in its own thread/subj:-line. > > I feel we have 3 subject areas: > 1) The "pure" OpenSCAD usage questions: syntax, funktion, getting data > in&out, versions, bugs ... > 2) The "add ons" - BOSL2 and Sanjeev's python frontend. > 3) Hardware related- ie on how to get a physical implementation of a > model. > The list could be subdivided a bit further. > > IMHO the list should restrict itself to 1.  The occasional hardware > question is not a problem, but it gets a bit strained in that many > OpenSCAD questions are answered with "use this instead". Admittedly, > pure (and simple) OpenSCAD can not solve all 3D model desires, but > should that be a problem? > > I found it nice to hear about BOSL2, but find longer problems > irrelevant. BOSL2 is bigger than OpenSCAD in the number of features > and functions, i.e. it is like  a new language (perhaps like C++ is > "just" an extension of C ?) Sanjeev's python work is also a new > language which only uses OpenSCAD as a render, as it produces one > large polyhedra. Fantastic, but has almost nothing to do with OpenSCAD. > > Msquare > > > > > On Wed, 16 Aug 2023 at 18:52, jon <jon@jonbondy.com> wrote: > > How do the forum members feel about postings like this, which have > more to do with python than with OpenSCAD?  I personally find it > to be unnecessary and distracting, but I will defer to the > feelings of the group. > > Jon > > > On 8/16/2023 12:22 PM, Sanjeev Prabhakar wrote: >> openscad version >> Screenshot 2023-08-16 at 9.44.44 PM.png >> >> #python code to create this: >> >> from openscad1 import * >> sec=circle(25) >> path=cr(pts1([[0,0,0],[0,15,1],[-6,50,1],[0,18,0]]),10) >> sol=prism(sec,path) >> sol1=prism(circle(24),path) >> sol0=swp_prism_h(sol,sol1) >> sec2=circle(15) >> path2=cr_3d([[0,0,15,0],[-60,0,40,20],[0,0,30,0]],10) >> sol2=path_extrude_open(sec2,path2) >> sol3=path_extrude_open(offset(sec2,-1),path2) >> sol02=swp_prism_h(sol2,sol3) >> fillet1=ip_fillet(sol,sol2,3,3) >> >> sec3=cr(pts1([[0,0],[-2,1,.2],[2,1]]),10) >> path3=helix(14,2.5,6,5) >> sol4=path_extrude_open(sec3,path3) >> >> sol4=sol2vector([0,0,1,],sol4,[-60,0,70]) >> with open('/Users/sanjeevprabhakar/iCloud Drive >> (Archive)/Documents/Download/openscad/trial.scad','w+') as f: >>     f.write(f''' >> difference(){{ >> {swp_c(sol0)} >> {swp(sol3)} >> }} >> difference(){{ >> {swp_c(sol02)} >> {swp(sol)} >> }} >> {swp_c(fillet1)} >> intersection(){{ >> color("blue"){swp(sol4)} >> {swp(sol3)} >> }} >> >> ''') >> >> #for this code to work you would need  file openscad1.py >> >>
TP
Torsten Paul
Wed, Aug 16, 2023 7:14 PM
There is simple way of subdividing the mailing list, reasonable
mail clients should be able to suppress unwanted threads though.
I'm still trying to figure out if there's anything we could self-
host that could bring back the combined forum/mail usage we had
earlier. Maybe the new fediverse apps (Lemmy/Kbin...) bring some
new options to the table...
Declaring a strict "pure OpenSCAD" policy seems both too limited
and also difficult to enforce anyway.
Declaring BOSL2 or any library off-topic is just wrong in my
personal opinion. It does not get more OpenSCAD related than that.
The python topic is debatable, especially in it's current form,
but considering there's going to be some native Python support
it could become much more integrated / native soon.
In summary, I'm seeing all 3 topics in the on-topic category,
maybe with the hope the hardware topics would not take a too
big percentage.
ciao,
Torsten.
There is simple way of subdividing the mailing list, reasonable mail clients should be able to suppress unwanted threads though. I'm still trying to figure out if there's anything we could self- host that could bring back the combined forum/mail usage we had earlier. Maybe the new fediverse apps (Lemmy/Kbin...) bring some new options to the table... Declaring a strict "pure OpenSCAD" policy seems both too limited and also difficult to enforce anyway. Declaring BOSL2 or any library off-topic is just wrong in my personal opinion. It does not get more OpenSCAD related than that. The python topic is debatable, especially in it's current form, but considering there's going to be some native Python support it could become much more integrated / native soon. In summary, I'm seeing all 3 topics in the on-topic category, maybe with the hope the hardware topics would not take a too big percentage. ciao, Torsten.
DP
Dan Perry
Wed, Aug 16, 2023 7:16 PM
I'm OK with the python stuff, because it shows a different way to solve a
problem.
Dan
Jon
problem?
Msquare
Jon
openscad version
sec=circle(25)
sol=prism(sec,path)
sec2=circle(15)
f.write(f'''
difference(){{
{swp_c(sol0)}
{swp(sol3)}
difference(){{
{swp_c(sol02)}
{swp(sol)}
{swp_c(fillet1)}
intersection(){{
{swp(sol3)}
I'm OK with the python stuff, because it shows a different way to solve a problem. Dan On Wed, Aug 16, 2023 at 7:46 PM jon <jon@jonbondy.com> wrote: > I agree that this should be separate. Thanks for pointing this out. > > Jon > On 8/16/2023 1:44 PM, Michael Möller wrote: > > Well, that question should be debated in its own thread/subj:-line. > > I feel we have 3 subject areas: > 1) The "pure" OpenSCAD usage questions: syntax, funktion, getting data > in&out, versions, bugs ... > 2) The "add ons" - BOSL2 and Sanjeev's python frontend. > 3) Hardware related- ie on how to get a physical implementation of a model. > The list could be subdivided a bit further. > > IMHO the list should restrict itself to 1. The occasional hardware > question is not a problem, but it gets a bit strained in that many OpenSCAD > questions are answered with "use this instead". Admittedly, pure (and > simple) OpenSCAD can not solve all 3D model desires, but should that be a > problem? > > I found it nice to hear about BOSL2, but find longer problems irrelevant. > BOSL2 is bigger than OpenSCAD in the number of features and functions, i.e. > it is like a new language (perhaps like C++ is "just" an extension of C ?) > Sanjeev's python work is also a new language which only uses OpenSCAD as a > render, as it produces one large polyhedra. Fantastic, but has almost > nothing to do with OpenSCAD. > > Msquare > > > > > On Wed, 16 Aug 2023 at 18:52, jon <jon@jonbondy.com> wrote: > >> How do the forum members feel about postings like this, which have more >> to do with python than with OpenSCAD? I personally find it to be >> unnecessary and distracting, but I will defer to the feelings of the group. >> >> Jon >> >> >> On 8/16/2023 12:22 PM, Sanjeev Prabhakar wrote: >> >> openscad version >> [image: Screenshot 2023-08-16 at 9.44.44 PM.png] >> >> #python code to create this: >> >> from openscad1 import * >> sec=circle(25) >> path=cr(pts1([[0,0,0],[0,15,1],[-6,50,1],[0,18,0]]),10) >> sol=prism(sec,path) >> sol1=prism(circle(24),path) >> sol0=swp_prism_h(sol,sol1) >> sec2=circle(15) >> path2=cr_3d([[0,0,15,0],[-60,0,40,20],[0,0,30,0]],10) >> sol2=path_extrude_open(sec2,path2) >> sol3=path_extrude_open(offset(sec2,-1),path2) >> sol02=swp_prism_h(sol2,sol3) >> fillet1=ip_fillet(sol,sol2,3,3) >> >> sec3=cr(pts1([[0,0],[-2,1,.2],[2,1]]),10) >> path3=helix(14,2.5,6,5) >> sol4=path_extrude_open(sec3,path3) >> >> sol4=sol2vector([0,0,1,],sol4,[-60,0,70]) >> with open('/Users/sanjeevprabhakar/iCloud Drive >> (Archive)/Documents/Download/openscad/trial.scad','w+') as f: >> f.write(f''' >> difference(){{ >> {swp_c(sol0)} >> {swp(sol3)} >> }} >> difference(){{ >> {swp_c(sol02)} >> {swp(sol)} >> }} >> {swp_c(fillet1)} >> intersection(){{ >> color("blue"){swp(sol4)} >> {swp(sol3)} >> }} >> >> ''') >> >> #for this code to work you would need file openscad1.py >> >> >> _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
J
jon
Wed, Aug 16, 2023 7:26 PM
Torsten:
Can you elaborate on "there's going to be some native Python support"
please?  Could we also add support for Modula 2 and Algol?
I'm trying to understand where the lines are being drawn, and why.
Jon
big percentage.
ciao,
  Torsten.
Torsten: Can you elaborate on "there's going to be some native Python support" please?  Could we also add support for Modula 2 and Algol? I'm trying to understand where the lines are being drawn, and why. Jon On 8/16/2023 3:14 PM, Torsten Paul wrote: > There is simple way of subdividing the mailing list, reasonable > mail clients should be able to suppress unwanted threads though. > > I'm still trying to figure out if there's anything we could self- > host that could bring back the combined forum/mail usage we had > earlier. Maybe the new fediverse apps (Lemmy/Kbin...) bring some > new options to the table... > > Declaring a strict "pure OpenSCAD" policy seems both too limited > and also difficult to enforce anyway. > > Declaring BOSL2 or any library off-topic is just wrong in my > personal opinion. It does not get more OpenSCAD related than that. > > The python topic is debatable, especially in it's current form, > but considering there's going to be some native Python support > it could become much more integrated / native soon. > > In summary, I'm seeing all 3 topics in the on-topic category, > maybe with the hope the hardware topics would not take a too > big percentage. > > ciao, >   Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
TP
Torsten Paul
Wed, Aug 16, 2023 7:51 PM
support" please?
  • Language widely in demand
  • Someone (else) doing the actual work (Thanks Günther!)
  • Language supports "easy" integration into a C++ application
So without much analysis, my judgement would look something like:
Modula 2 - no
Algol - no
Tcl - no
Lua - probably not
Lisp/Scheme - maybe?
JavaScript - well...?
Also it's extremely unlikely now while the python support is
still moving towards integration.
It's going to be another option, in addition to the "normal"
SCAD. The code changes implementing the python support are
surprisingly small as it's using all the geometry infrastructure
that exists for SCAD. The bigger challenge are more the build,
deployment and release topics.
For further discussion, lets maybe create a new dedicated topic /
mail thread ;-). Or use the one from a couple of days ago, where
Sanjeev was asking for "python support for openscad".
ciao,
Torsten.
On 16.08.23 21:26, jon wrote: > Can you elaborate on "there's going to be some native Python > support" please? I'd point to http://www.guenther-sohler.net/openscad/ for that. > Could we also add support for Modula 2 and Algol? > I'm trying to understand where the lines are being drawn, and why. - Language widely in demand - Someone (else) doing the actual work (Thanks Günther!) - Language supports "easy" integration into a C++ application So without much analysis, my judgement would look something like: Modula 2 - no Algol - no Tcl - no Lua - probably not Lisp/Scheme - maybe? JavaScript - well...? Also it's extremely unlikely *now* while the python support is still moving towards integration. It's going to be another option, in addition to the "normal" SCAD. The code changes implementing the python support are surprisingly small as it's using all the geometry infrastructure that exists for SCAD. The bigger challenge are more the build, deployment and release topics. For further discussion, lets maybe create a new dedicated topic / mail thread ;-). Or use the one from a couple of days ago, where Sanjeev was asking for "python support for openscad". ciao, Torsten.
NH
nop head
Wed, Aug 16, 2023 8:04 PM
Personally I don't care what gets discussed on the list as long as it is
related to OpenSCAD or 3D printing in some way. I have a fully functional
delete key so anything that doesn't interest me is gone very quickly.
support" please?
Modula 2 - no
Algol - no
Tcl - no
Lua - probably not
ciao,
Torsten.
Personally I don't care what gets discussed on the list as long as it is related to OpenSCAD or 3D printing in some way. I have a fully functional delete key so anything that doesn't interest me is gone very quickly. On Wed, 16 Aug 2023 at 20:51, Torsten Paul <Torsten.Paul@gmx.de> wrote: > On 16.08.23 21:26, jon wrote: > > Can you elaborate on "there's going to be some native Python > > support" please? > > I'd point to http://www.guenther-sohler.net/openscad/ for that. > > > Could we also add support for Modula 2 and Algol? > > I'm trying to understand where the lines are being drawn, and why. > > - Language widely in demand > - Someone (else) doing the actual work (Thanks Günther!) > - Language supports "easy" integration into a C++ application > > So without much analysis, my judgement would look something like: > > Modula 2 - no > Algol - no > Tcl - no > Lua - probably not > Lisp/Scheme - maybe? > JavaScript - well...? > > Also it's extremely unlikely *now* while the python support is > still moving towards integration. > > It's going to be another option, in addition to the "normal" > SCAD. The code changes implementing the python support are > surprisingly small as it's using all the geometry infrastructure > that exists for SCAD. The bigger challenge are more the build, > deployment and release topics. > > For further discussion, lets maybe create a new dedicated topic / > mail thread ;-). Or use the one from a couple of days ago, where > Sanjeev was asking for "python support for openscad". > > ciao, > Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
FH
Father Horton
Wed, Aug 16, 2023 8:17 PM
Turbo Pascal?
Turbo Pascal?
RD
Revar Desmera
Wed, Aug 16, 2023 8:51 PM
The main difficult part of this is the fillet between the tubes.  That should be doable with join_prism() (see example 12) in rounding.scad.  The curve of the smaller tube can be done either with turtle3d, or with path_sweep() in skin.scad. The threading, of course, is available in threading.scad.
I am unsure if join_prism() can use a cone as a base, though.  Adrian, is there a way to do that?
  • Revar
On Aug 16, 2023, at 12:11 AM, Karl Exler karl.exler@meinklang.cc wrote:
Dear all
Karl
<dewalt.png>_______________________________________________
The main difficult part of this is the fillet between the tubes. That should be doable with `join_prism()` (see example 12) in rounding.scad. The curve of the smaller tube can be done either with turtle3d, or with `path_sweep()` in skin.scad. The threading, of course, is available in threading.scad. - https://github.com/BelfrySCAD/BOSL2/wiki/rounding.scad#functionmodule-join_prism - https://github.com/BelfrySCAD/BOSL2/wiki/skin.scad#functionmodule-path_sweep - https://github.com/BelfrySCAD/BOSL2/wiki/threading.scad#module-threaded_rod I am unsure if `join_prism()` can use a cone as a base, though. Adrian, is there a way to do that? - Revar > On Aug 16, 2023, at 12:11 AM, Karl Exler <karl.exler@meinklang.cc> wrote: > > Dear all > I found the enclosed adapter on Thingiverse. Unfortunately nearly all diameters are not in that size I need it. Did anyone of you created such an (similar) object in Openscad? Is it possible to get that file? > Or- if not- how would an expert start with that projects? > > Until now I only use Openscad functions and some of the BOSL libraries. > > Many thanks in advance > Karl > <dewalt.png>_______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
WF
William F. Adams
Wed, Aug 16, 2023 10:19 PM
On Wednesday, August 16, 2023 at 03:51:47 PM EDT, Torsten Paul torsten.paul@gmx.de wrote:
Okay, trying to get that running, I installed:
http://www.guenther-sohler.net/openscad/downloads/OpenSCAD-2023.04.25-x86-64-Installer.exe
and edited my Windows System Environment variables to include:
PYTHONHOME
pointing at:
C:\Users\willa\AppData\Local\Programs\Python\Python310
which contains:
"C:\Users\willa\AppData\Local\Programs\Python\Python310\python310.dll"
and rebooted.
but when I try to run it I get:
The code execution cannot proceed because libpython3.10.dll was not found. Reinstalling the program may fix this problem."
Unfortunately the similar question:
https://superuser.com/questions/1422878/how-can-i-install-libpython-in-windows
is unanswered.
Apparently the recommendation is msys2 and a package in there --- which one? Why won't an extant Python 3.10 install serve? Why can't the DLL just be included?
William
On Wednesday, August 16, 2023 at 03:51:47 PM EDT, Torsten Paul <torsten.paul@gmx.de> wrote: >I'd point to http://www.guenther-sohler.net/openscad/ for that. Okay, trying to get that running, I installed: http://www.guenther-sohler.net/openscad/downloads/OpenSCAD-2023.04.25-x86-64-Installer.exe and edited my Windows System Environment variables to include: PYTHONHOME pointing at: C:\Users\willa\AppData\Local\Programs\Python\Python310 which contains: "C:\Users\willa\AppData\Local\Programs\Python\Python310\python310.dll" and rebooted. but when I try to run it I get: >The code execution cannot proceed because libpython3.10.dll was not found. Reinstalling the program may fix this problem." Unfortunately the similar question: https://superuser.com/questions/1422878/how-can-i-install-libpython-in-windows is unanswered. Apparently the recommendation is msys2 and a package in there --- which one? Why won't an extant Python 3.10 install serve? Why can't the DLL just be included? William
ER
edmund ronald
Wed, Aug 16, 2023 10:57 PM
Forums let people pose questions which are sidelines, and no one protests
as long as the content is polite.
Mailing lists create all these questions of what is appropriate for all,
and effectively create an atmosphere of would-be censorship.
On Wed, Aug 16, 2023 at 10:18 PM Father Horton fatherhorton@gmail.com
wrote:
Turbo Pascal?
Forums let people pose questions which are sidelines, and no one protests as long as the content is polite. Mailing lists create all these questions of what is appropriate for all, and effectively create an atmosphere of would-be censorship. On Wed, Aug 16, 2023 at 10:18 PM Father Horton <fatherhorton@gmail.com> wrote: > Turbo Pascal? > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
SP
Sanjeev Prabhakar
Thu, Aug 17, 2023 12:29 AM
just want to clarify on "nothing to do with openSCAD"
I am only using python for calculating the vertices in space.
polyhedron() is an openscad feature
difference () is an openscad feature
intersection () is an openscad feature
hull() is an openscad feature
Without the above, models cannot be made. It is not like an stl file import.
Also it is not 1 large polyhedron, there are multiple of them.
Thanks
On Wed, 16 Aug, 2023, 11:14 pm Michael Möller, private2michael@gmail.com
problem?
Msquare
Jon
openscad version
sec=circle(25)
sol=prism(sec,path)
sec2=circle(15)
f.write(f'''
difference(){{
{swp_c(sol0)}
{swp(sol3)}
difference(){{
{swp_c(sol02)}
{swp(sol)}
{swp_c(fillet1)}
intersection(){{
{swp(sol3)}
filleting.
wrote:
Dear all
such
Karl
just want to clarify on "nothing to do with openSCAD" I am only using python for calculating the vertices in space. polyhedron() is an openscad feature difference () is an openscad feature intersection () is an openscad feature hull() is an openscad feature Without the above, models cannot be made. It is not like an stl file import. Also it is not 1 large polyhedron, there are multiple of them. Thanks On Wed, 16 Aug, 2023, 11:14 pm Michael Möller, <private2michael@gmail.com> wrote: > Well, that question should be debated in its own thread/subj:-line. > > I feel we have 3 subject areas: > 1) The "pure" OpenSCAD usage questions: syntax, funktion, getting data > in&out, versions, bugs ... > 2) The "add ons" - BOSL2 and Sanjeev's python frontend. > 3) Hardware related- ie on how to get a physical implementation of a model. > The list could be subdivided a bit further. > > IMHO the list should restrict itself to 1. The occasional hardware > question is not a problem, but it gets a bit strained in that many OpenSCAD > questions are answered with "use this instead". Admittedly, pure (and > simple) OpenSCAD can not solve all 3D model desires, but should that be a > problem? > > I found it nice to hear about BOSL2, but find longer problems irrelevant. > BOSL2 is bigger than OpenSCAD in the number of features and functions, i.e. > it is like a new language (perhaps like C++ is "just" an extension of C ?) > Sanjeev's python work is also a new language which only uses OpenSCAD as a > render, as it produces one large polyhedra. Fantastic, but has almost > nothing to do with OpenSCAD. > > Msquare > > > > > On Wed, 16 Aug 2023 at 18:52, jon <jon@jonbondy.com> wrote: > >> How do the forum members feel about postings like this, which have more >> to do with python than with OpenSCAD? I personally find it to be >> unnecessary and distracting, but I will defer to the feelings of the group. >> >> Jon >> >> >> On 8/16/2023 12:22 PM, Sanjeev Prabhakar wrote: >> >> openscad version >> [image: Screenshot 2023-08-16 at 9.44.44 PM.png] >> >> #python code to create this: >> >> from openscad1 import * >> sec=circle(25) >> path=cr(pts1([[0,0,0],[0,15,1],[-6,50,1],[0,18,0]]),10) >> sol=prism(sec,path) >> sol1=prism(circle(24),path) >> sol0=swp_prism_h(sol,sol1) >> sec2=circle(15) >> path2=cr_3d([[0,0,15,0],[-60,0,40,20],[0,0,30,0]],10) >> sol2=path_extrude_open(sec2,path2) >> sol3=path_extrude_open(offset(sec2,-1),path2) >> sol02=swp_prism_h(sol2,sol3) >> fillet1=ip_fillet(sol,sol2,3,3) >> >> sec3=cr(pts1([[0,0],[-2,1,.2],[2,1]]),10) >> path3=helix(14,2.5,6,5) >> sol4=path_extrude_open(sec3,path3) >> >> sol4=sol2vector([0,0,1,],sol4,[-60,0,70]) >> with open('/Users/sanjeevprabhakar/iCloud Drive >> (Archive)/Documents/Download/openscad/trial.scad','w+') as f: >> f.write(f''' >> difference(){{ >> {swp_c(sol0)} >> {swp(sol3)} >> }} >> difference(){{ >> {swp_c(sol02)} >> {swp(sol)} >> }} >> {swp_c(fillet1)} >> intersection(){{ >> color("blue"){swp(sol4)} >> {swp(sol3)} >> }} >> >> ''') >> >> #for this code to work you would need file openscad1.py >> >> On Wed, 16 Aug 2023 at 14:29, Sanjeev Prabhakar <sprabhakar2006@gmail.com> >> wrote: >> >>> This seems to me as quite a simple case although haven't tried it yet. >>> >>> As per my understanding it should be easy to do with BOSL library. May >>> be Adrian can comment. >>> >>> If you want, I can make it through my python approach. >>> >>> It is mainly 2 tubes which needs to be fused together and some easy >>> filleting. >>> >>> Threads parts maybe a little tricky, but not too difficult for sure. >>> >>> >>> >>> >>> On Wed, 16 Aug, 2023, 12:42 pm Karl Exler, <karl.exler@meinklang.cc> >>> wrote: >>> >>>> Dear all >>>> I found the enclosed adapter on Thingiverse. Unfortunately nearly all >>>> diameters are not in that size I need it. Did anyone of you created >>>> such >>>> an (similar) object in Openscad? Is it possible to get that file? >>>> Or- if not- how would an expert start with that projects? >>>> >>>> Until now I only use Openscad functions and some of the BOSL libraries. >>>> >>>> Many thanks in advance >>>> Karl >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>> >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> >
J
jon
Thu, Aug 17, 2023 12:58 AM
The scope and richness of BOSL2 always amazes me.  It is more than I can
keep in my head.  Thanks for the extensive documentation and examples.
Jon
  • Revar
Dear all
Karl
The scope and richness of BOSL2 always amazes me.  It is more than I can keep in my head.  Thanks for the extensive documentation and examples. Jon On 8/16/2023 4:51 PM, Revar Desmera wrote: > The main difficult part of this is the fillet between the tubes.  That > should be doable with `join_prism()` (see example 12) in > rounding.scad.  The curve of the smaller tube can be done either with > turtle3d, or with `path_sweep()` in skin.scad. The threading, of > course, is available in threading.scad. > > - > https://github.com/BelfrySCAD/BOSL2/wiki/rounding.scad#functionmodule-join_prism > - > https://github.com/BelfrySCAD/BOSL2/wiki/skin.scad#functionmodule-path_sweep > - > https://github.com/BelfrySCAD/BOSL2/wiki/threading.scad#module-threaded_rod > > I am unsure if `join_prism()` can use a cone as a base, though. >  Adrian, is there a way to do that? > > - Revar > > > >> On Aug 16, 2023, at 12:11 AM, Karl Exler <karl.exler@meinklang.cc> wrote: >> >> Dear all >> I found the enclosed adapter on Thingiverse. Unfortunately nearly all >> diameters are not in that size I need it. Did anyone of you created >> such an (similar) object in Openscad? Is it possible to get that file? >> Or- if not- how would an expert start with that projects? >> >> Until now I only use Openscad functions and some of the BOSL libraries. >> >> Many thanks in advance >> Karl >> <dewalt.png>_______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
GS
Guenther Sohler
Thu, Aug 17, 2023 5:18 AM
Just want to write in behalf of Sanjeev.
I am sure that If current openscad had better and easier abilities to Work
with Arrays, He die Not choose the external python approach. Cheers
Sanjeev Prabhakar sprabhakar2006@gmail.com schrieb am Do., 17. Aug. 2023,
02:29:
import.
Thanks
    model.
problem?
Msquare
Jon
openscad version
sec=circle(25)
sol=prism(sec,path)
sec2=circle(15)
f.write(f'''
difference(){{
{swp_c(sol0)}
{swp(sol3)}
difference(){{
{swp_c(sol02)}
{swp(sol)}
{swp_c(fillet1)}
intersection(){{
{swp(sol3)}
filleting.
wrote:
Dear all
such
Karl
Just want to write in behalf of Sanjeev. I am sure that If current openscad had better and easier abilities to Work with Arrays, He die Not choose the external python approach. Cheers Sanjeev Prabhakar <sprabhakar2006@gmail.com> schrieb am Do., 17. Aug. 2023, 02:29: > just want to clarify on "nothing to do with openSCAD" > > I am only using python for calculating the vertices in space. > > polyhedron() is an openscad feature > difference () is an openscad feature > intersection () is an openscad feature > hull() is an openscad feature > > Without the above, models cannot be made. It is not like an stl file > import. > > Also it is not 1 large polyhedron, there are multiple of them. > > Thanks > > > On Wed, 16 Aug, 2023, 11:14 pm Michael Möller, <private2michael@gmail.com> > wrote: > >> Well, that question should be debated in its own thread/subj:-line. >> >> I feel we have 3 subject areas: >> 1) The "pure" OpenSCAD usage questions: syntax, funktion, getting data >> in&out, versions, bugs ... >> 2) The "add ons" - BOSL2 and Sanjeev's python frontend. >> 3) Hardware related- ie on how to get a physical implementation of a >> model. >> The list could be subdivided a bit further. >> >> IMHO the list should restrict itself to 1. The occasional hardware >> question is not a problem, but it gets a bit strained in that many OpenSCAD >> questions are answered with "use this instead". Admittedly, pure (and >> simple) OpenSCAD can not solve all 3D model desires, but should that be a >> problem? >> >> I found it nice to hear about BOSL2, but find longer problems irrelevant. >> BOSL2 is bigger than OpenSCAD in the number of features and functions, i.e. >> it is like a new language (perhaps like C++ is "just" an extension of C ?) >> Sanjeev's python work is also a new language which only uses OpenSCAD as a >> render, as it produces one large polyhedra. Fantastic, but has almost >> nothing to do with OpenSCAD. >> >> Msquare >> >> >> >> >> On Wed, 16 Aug 2023 at 18:52, jon <jon@jonbondy.com> wrote: >> >>> How do the forum members feel about postings like this, which have more >>> to do with python than with OpenSCAD? I personally find it to be >>> unnecessary and distracting, but I will defer to the feelings of the group. >>> >>> Jon >>> >>> >>> On 8/16/2023 12:22 PM, Sanjeev Prabhakar wrote: >>> >>> openscad version >>> [image: Screenshot 2023-08-16 at 9.44.44 PM.png] >>> >>> #python code to create this: >>> >>> from openscad1 import * >>> sec=circle(25) >>> path=cr(pts1([[0,0,0],[0,15,1],[-6,50,1],[0,18,0]]),10) >>> sol=prism(sec,path) >>> sol1=prism(circle(24),path) >>> sol0=swp_prism_h(sol,sol1) >>> sec2=circle(15) >>> path2=cr_3d([[0,0,15,0],[-60,0,40,20],[0,0,30,0]],10) >>> sol2=path_extrude_open(sec2,path2) >>> sol3=path_extrude_open(offset(sec2,-1),path2) >>> sol02=swp_prism_h(sol2,sol3) >>> fillet1=ip_fillet(sol,sol2,3,3) >>> >>> sec3=cr(pts1([[0,0],[-2,1,.2],[2,1]]),10) >>> path3=helix(14,2.5,6,5) >>> sol4=path_extrude_open(sec3,path3) >>> >>> sol4=sol2vector([0,0,1,],sol4,[-60,0,70]) >>> with open('/Users/sanjeevprabhakar/iCloud Drive >>> (Archive)/Documents/Download/openscad/trial.scad','w+') as f: >>> f.write(f''' >>> difference(){{ >>> {swp_c(sol0)} >>> {swp(sol3)} >>> }} >>> difference(){{ >>> {swp_c(sol02)} >>> {swp(sol)} >>> }} >>> {swp_c(fillet1)} >>> intersection(){{ >>> color("blue"){swp(sol4)} >>> {swp(sol3)} >>> }} >>> >>> ''') >>> >>> #for this code to work you would need file openscad1.py >>> >>> On Wed, 16 Aug 2023 at 14:29, Sanjeev Prabhakar < >>> sprabhakar2006@gmail.com> wrote: >>> >>>> This seems to me as quite a simple case although haven't tried it yet. >>>> >>>> As per my understanding it should be easy to do with BOSL library. May >>>> be Adrian can comment. >>>> >>>> If you want, I can make it through my python approach. >>>> >>>> It is mainly 2 tubes which needs to be fused together and some easy >>>> filleting. >>>> >>>> Threads parts maybe a little tricky, but not too difficult for sure. >>>> >>>> >>>> >>>> >>>> On Wed, 16 Aug, 2023, 12:42 pm Karl Exler, <karl.exler@meinklang.cc> >>>> wrote: >>>> >>>>> Dear all >>>>> I found the enclosed adapter on Thingiverse. Unfortunately nearly all >>>>> diameters are not in that size I need it. Did anyone of you created >>>>> such >>>>> an (similar) object in Openscad? Is it possible to get that file? >>>>> Or- if not- how would an expert start with that projects? >>>>> >>>>> Until now I only use Openscad functions and some of the BOSL libraries. >>>>> >>>>> Many thanks in advance >>>>> Karl >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>>> >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
MP
Marcus Poller
Thu, Aug 17, 2023 8:22 AM
Hi Karl,
[cylindrical Y-adapter with different diameters on each side, one of the cylinders has an inner thread]
Has your problem been solved?
If not:
(1) Do you require the inner thread of the smaller exhaust cylinder?
(2) is the angle between the two small exhaust cylinders important?
I think the model can be simplified to four cylinders - two outer cylinders add up to the y-shape, two inner cylinders to make it hollow. As a proof of concept, I have attached a sample code and a render image.
Cheers,
Marcus
Hi Karl, > I found the enclosed adapter on Thingiverse. [cylindrical Y-adapter with different diameters on each side, one of the cylinders has an inner thread] Has your problem been solved? If not: (1) Do you require the inner thread of the smaller exhaust cylinder? (2) is the angle between the two small exhaust cylinders important? I think the model can be simplified to four cylinders - two outer cylinders add up to the y-shape, two inner cylinders to make it hollow. As a proof of concept, I have attached a sample code and a render image. Cheers, Marcus
JB
Jordan Brown
Thu, Aug 17, 2023 8:43 PM
My 2¢:
Hardware, slicers, non-programmatic design tools - clearly off topic,
but this is a community; it will occasionally have side conversations
and within reason that's OK.  Like nophead, I have a delete key, an "n"
key (next unread message), and an "r" key (mark thread as read), and
filters.
BOSL2 and other OpenSCAD libraries - clearly on topic, but BOSL2 is a
large enough topic in its own right that perhaps it should get its own
mailing list for more extensive and specialized conversations.
Programmatic design tools, generically (Python tools, AngelCAD, et
cetera) - off topic, but certainly nearby.  I wouldn't want WhateverCAD
tech support conversations here, but an occasional "if you're having
problems thinking in OpenSCAD, maybe you would like XXX, here's how it
compares, for more information go over <there>" would, I think, be
entirely appropriate, as would "I just saw this cool feature in YYY, it
works like <this>, maybe we could steal it for OpenSCAD".
Math - often critical to OpenSCAD design, so sure.
Alternate languages in the OpenSCAD UI, using the OpenSCAD geometry
engines - good question.  In the short term I think they're fine; in the
long term... don't know.  Dividing into multiple mailing lists makes
sense, but then makes it unclear where UI and geometry-engine
discussions happen.  Murkier still if we get cross-language calls.
Whines about how forums are better than e-mail - just go away.  Join the
Reddit community https://www.reddit.com/r/openscad/ or the Facebook
community https://www.facebook.com/groups/OpenSCADAcademy or the
Thingiverse community https://www.thingiverse.com/groups/openscad.  Or
host your own forum, and by all means ask to be linked from the web
page.  Or figure out how to cleanly unite the mailing list with a
forum.  But don't expect somebody else do to it for you and don't expect
other people to migrate.  Many or most of the active people are here
because they prefer e-mail.  If you want to talk to them, you have to be
where they like to hang out.
My 2¢: Hardware, slicers, non-programmatic design tools - clearly off topic, but this is a community; it will occasionally have side conversations and within reason that's OK.  Like nophead, I have a delete key, an "n" key (next unread message), and an "r" key (mark thread as read), and filters. BOSL2 and other OpenSCAD libraries - clearly *on* topic, but BOSL2 is a large enough topic in its own right that perhaps it should get its own mailing list for more extensive and specialized conversations. Programmatic design tools, generically (Python tools, AngelCAD, et cetera) - off topic, but certainly nearby.  I wouldn't want WhateverCAD tech support conversations here, but an occasional "if you're having problems thinking in OpenSCAD, maybe you would like XXX, here's how it compares, for more information go over <there>" would, I think, be entirely appropriate, as would "I just saw this cool feature in YYY, it works like <this>, maybe we could steal it for OpenSCAD". Math - often critical to OpenSCAD design, so sure. Alternate languages in the OpenSCAD UI, using the OpenSCAD geometry engines - good question.  In the short term I think they're fine; in the long term... don't know.  Dividing into multiple mailing lists makes sense, but then makes it unclear where UI and geometry-engine discussions happen.  Murkier still if we get cross-language calls. Whines about how forums are better than e-mail - just go away.  Join the Reddit community <https://www.reddit.com/r/openscad/> or the Facebook community <https://www.facebook.com/groups/OpenSCADAcademy> or the Thingiverse community <https://www.thingiverse.com/groups/openscad>.  Or host your own forum, and by all means ask to be linked from the web page.  Or figure out how to cleanly unite the mailing list with a forum.  But don't expect somebody else do to it for you and don't expect other people to migrate.  Many or most of the active people are here because they prefer e-mail.  If you want to talk to them, you have to be where they like to hang out.
ER
edmund ronald
Thu, Aug 17, 2023 9:13 PM
I don't want to whine, I want people to let me ask my questions regardless
of how dumb they are. And you guys don't. You censor topics and opinions
under the pretext that the mail goes out to everybody. If I wanna ask
people how to find the absolute coordinates of a corner, I don't need
anyone here telling me that I've clearly never programmed in my life etc.
Because maybe on a forum, this question won't get shut down subito, and
someone else may tale it up, and then we'll find a way to hack it. Here you
shut down any request you don't like before it can be tackled.
On Thu, Aug 17, 2023 at 10:44 PM Jordan Brown openscad@jordan.maileater.net
wrote:
My 2¢:
  • off topic, but certainly nearby.  I wouldn't want WhateverCAD tech
community https://www.reddit.com/r/openscad/ or the Facebook community
https://www.facebook.com/groups/OpenSCADAcademy or the Thingiverse
community https://www.thingiverse.com/groups/openscad.  Or host your
I don't want to whine, I want people to let me ask my questions regardless of how dumb they are. And you guys don't. You censor topics and opinions under the pretext that the mail goes out to everybody. If I wanna ask people how to find the absolute coordinates of a corner, I don't need anyone here telling me that I've clearly never programmed in my life etc. Because maybe on a forum, this question won't get shut down subito, and someone else may tale it up, and then we'll find a way to hack it. Here you shut down any request you don't like before it can be tackled. On Thu, Aug 17, 2023 at 10:44 PM Jordan Brown <openscad@jordan.maileater.net> wrote: > My 2¢: > > Hardware, slicers, non-programmatic design tools - clearly off topic, but > this is a community; it will occasionally have side conversations and > within reason that's OK. Like nophead, I have a delete key, an "n" key > (next unread message), and an "r" key (mark thread as read), and filters. > > BOSL2 and other OpenSCAD libraries - clearly *on* topic, but BOSL2 is a > large enough topic in its own right that perhaps it should get its own > mailing list for more extensive and specialized conversations. > > Programmatic design tools, generically (Python tools, AngelCAD, et cetera) > - off topic, but certainly nearby. I wouldn't want WhateverCAD tech > support conversations here, but an occasional "if you're having problems > thinking in OpenSCAD, maybe you would like XXX, here's how it compares, for > more information go over <there>" would, I think, be entirely appropriate, > as would "I just saw this cool feature in YYY, it works like <this>, maybe > we could steal it for OpenSCAD". > > Math - often critical to OpenSCAD design, so sure. > > Alternate languages in the OpenSCAD UI, using the OpenSCAD geometry > engines - good question. In the short term I think they're fine; in the > long term... don't know. Dividing into multiple mailing lists makes sense, > but then makes it unclear where UI and geometry-engine discussions happen. > Murkier still if we get cross-language calls. > > Whines about how forums are better than e-mail - just go away. Join the Reddit > community <https://www.reddit.com/r/openscad/> or the Facebook community > <https://www.facebook.com/groups/OpenSCADAcademy> or the Thingiverse > community <https://www.thingiverse.com/groups/openscad>. Or host your > own forum, and by all means ask to be linked from the web page. Or figure > out how to cleanly unite the mailing list with a forum. But don't expect > somebody else do to it for you and don't expect other people to migrate. > Many or most of the active people are here because they prefer e-mail. If > you want to talk to them, you have to be where they like to hang out. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
J
jon
Thu, Aug 17, 2023 9:18 PM
edmund:
In general, I find this forum and community to be VERY tolerant of
questions and also very helpful.  Your description does not match my
experience.
Jon
it can be tackled.
openscad@jordan.maileater.net wrote:
 My 2¢:
 conversations.
 for OpenSCAD".
edmund: In general, I find this forum and community to be VERY tolerant of questions and also very helpful.  Your description does not match my experience. Jon On 8/17/2023 5:13 PM, edmund ronald wrote: > I don't want to whine, I want people to let me ask my questions > regardless of how dumb they are. And you guys don't. You censor topics > and opinions under the pretext that the mail goes out to everybody. If > I wanna ask people how to find the absolute coordinates of a corner, I > don't need anyone here telling me that I've clearly never programmed > in my life etc. Because maybe on a forum, this question won't get shut > down subito, and someone else may tale it up, and then we'll find a > way to hack it. Here you shut down any request you don't like before > it can be tackled. > > On Thu, Aug 17, 2023 at 10:44 PM Jordan Brown > <openscad@jordan.maileater.net> wrote: > > My 2¢: > > Hardware, slicers, non-programmatic design tools - clearly off > topic, but this is a community; it will occasionally have side > conversations and within reason that's OK.  Like nophead, I have a > delete key, an "n" key (next unread message), and an "r" key (mark > thread as read), and filters. > > BOSL2 and other OpenSCAD libraries - clearly *on* topic, but BOSL2 > is a large enough topic in its own right that perhaps it should > get its own mailing list for more extensive and specialized > conversations. > > Programmatic design tools, generically (Python tools, AngelCAD, et > cetera) - off topic, but certainly nearby.  I wouldn't want > WhateverCAD tech support conversations here, but an occasional "if > you're having problems thinking in OpenSCAD, maybe you would like > XXX, here's how it compares, for more information go over <there>" > would, I think, be entirely appropriate, as would "I just saw this > cool feature in YYY, it works like <this>, maybe we could steal it > for OpenSCAD". > > Math - often critical to OpenSCAD design, so sure. > > Alternate languages in the OpenSCAD UI, using the OpenSCAD > geometry engines - good question.  In the short term I think > they're fine; in the long term... don't know.  Dividing into > multiple mailing lists makes sense, but then makes it unclear > where UI and geometry-engine discussions happen. Murkier still if > we get cross-language calls. > > Whines about how forums are better than e-mail - just go away.  > Join the Reddit community <https://www.reddit.com/r/openscad/> or > the Facebook community > <https://www.facebook.com/groups/OpenSCADAcademy> or the > Thingiverse community > <https://www.thingiverse.com/groups/openscad>.  Or host your own > forum, and by all means ask to be linked from the web page.  Or > figure out how to cleanly unite the mailing list with a forum.  > But don't expect somebody else do to it for you and don't expect > other people to migrate.  Many or most of the active people are > here because they prefer e-mail.  If you want to talk to them, you > have to be where they like to hang out. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
JB
Jordan Brown
Thu, Aug 17, 2023 9:37 PM
it can be tackled.
Which on-topic question got censored or shut down?
I've answered a lot of questions over the years - some of them dumb, and
some not dumb.  So have many others.  I can't think of a single time
that a question about OpenSCAD got shut down.
Sometimes the answer is "sorry, there isn't an easy way to do that, and
it wouldn't be easy to add one".  That probably isn't the answer that
you want to hear, but sometimes it's the answer.  Pretty much anything
about "finding absolute coordinates" will get that answer, because there
(mostly) isn't a way to derive them.
And if somebody else has a better answer for your question, maybe they
will speak up.
None of that is tied to e-mail versus a forum.  If anything, e-mail is
more open about it:  it's almost impossible to kill an e-mail thread,
while forums typically allow moderators to close discussion topics.
But if you want a forum style interface... go for it.  Just don't expect
me to create it for you, and don't expect me to join your forum, because
that's not the style of interface that I want.  If you want to talk to
me, you have to talk to me where and how I want to talk - just as if I
wanted your advice, and you hung out on a forum, I'd have to put up with
the forum interface.
On 8/17/2023 2:13 PM, edmund ronald wrote: > I don't want to whine, I want people to let me ask my questions > regardless of how dumb they are. And you guys don't. You censor topics > and opinions under the pretext that the mail goes out to everybody. If > I wanna ask people how to find the absolute coordinates of a corner, I > don't need anyone here telling me that I've clearly never programmed > in my life etc. Because maybe on a forum, this question won't get shut > down subito, and someone else may tale it up, and then we'll find a > way to hack it. Here you shut down any request you don't like before > it can be tackled. Which on-topic question got censored or shut down? I've answered a lot of questions over the years - some of them dumb, and some not dumb.  So have many others.  I can't think of a single time that a question about OpenSCAD got shut down. Sometimes the answer is "sorry, there isn't an easy way to do that, and it wouldn't be easy to add one".  That probably isn't the answer that you want to hear, but sometimes it's the answer.  Pretty much anything about "finding absolute coordinates" will get that answer, because there (mostly) isn't a way to derive them. And if somebody else has a better answer for your question, maybe they will speak up. None of that is tied to e-mail versus a forum.  If anything, e-mail is more open about it:  it's almost impossible to kill an e-mail thread, while forums typically allow moderators to close discussion topics. But if you want a forum style interface... go for it.  Just don't expect me to create it for you, and don't expect me to join your forum, because that's not the style of interface that I want.  If you want to talk to me, you have to talk to me where and how I want to talk - just as if I wanted your advice, and you hung out on a forum, I'd have to put up with the forum interface.
ER
edmund ronald
Thu, Aug 17, 2023 9:54 PM
After being on Arpanet for a while, and more lately on this successor
thingy, even though I don't know much about computers  I'm aware that there
is email and  other  ways to communicate which various people like more
than others. And I'm very happy about that because it means everybody gets
to use their favorite tools.  If there were a forum, I would expect it to
have an email gate-through of some sort. The reason I like forums is they
make it easier for most people to disregard stuff, including my whines, and
above all, they allow people to find old questions and replies easily, see
the state of a topic, and reopen it easily.
Regarding the absolute stuff, look I don't know much about 3D printing and
I don't know much about CAD, but I do know that I want to be able to
quickly see roughly what is going to pop out of my printer. I've had to do
horrible calculations to do this in the past, and it would be simpler if
one could just at least eg. have a fake component "pin" type, and one
places it in the  design and then it spits out its coordinates into the
debug window when rendered. And then one could figure out some critical
dimensions by looking at where those pins are.
Edmund
On Thu, Aug 17, 2023 at 11:37 PM Jordan Brown openscad@jordan.maileater.net
will speak up.
interface.
After being on Arpanet for a while, and more lately on this successor thingy, even though I don't know much about computers I'm aware that there is email and other ways to communicate which various people like more than others. And I'm very happy about that because it means everybody gets to use their favorite tools. If there were a forum, I would expect it to have an email gate-through of some sort. The reason I like forums is they make it easier for most people to disregard stuff, including my whines, and above all, they allow people to find old questions and replies easily, see the state of a topic, and reopen it easily. Regarding the absolute stuff, look I don't know much about 3D printing and I don't know much about CAD, but I do know that I want to be able to quickly see roughly what is going to pop out of my printer. I've had to do horrible calculations to do this in the past, and it would be simpler if one could just at least eg. have a fake component "pin" type, and one places it in the design and then it spits out its coordinates into the debug window when rendered. And then one could figure out some critical dimensions by looking at where those pins are. Edmund On Thu, Aug 17, 2023 at 11:37 PM Jordan Brown <openscad@jordan.maileater.net> wrote: > On 8/17/2023 2:13 PM, edmund ronald wrote: > > I don't want to whine, I want people to let me ask my questions regardless > of how dumb they are. And you guys don't. You censor topics and opinions > under the pretext that the mail goes out to everybody. If I wanna ask > people how to find the absolute coordinates of a corner, I don't need > anyone here telling me that I've clearly never programmed in my life etc. > Because maybe on a forum, this question won't get shut down subito, and > someone else may tale it up, and then we'll find a way to hack it. Here you > shut down any request you don't like before it can be tackled. > > > Which on-topic question got censored or shut down? > > I've answered a lot of questions over the years - some of them dumb, and > some not dumb. So have many others. I can't think of a single time that a > question about OpenSCAD got shut down. > > Sometimes the answer is "sorry, there isn't an easy way to do that, and it > wouldn't be easy to add one". That probably isn't the answer that you want > to hear, but sometimes it's the answer. Pretty much anything about > "finding absolute coordinates" will get that answer, because there (mostly) > isn't a way to derive them. > > And if somebody else has a better answer for your question, maybe they > will speak up. > > None of that is tied to e-mail versus a forum. If anything, e-mail is > more open about it: it's almost impossible to kill an e-mail thread, while > forums typically allow moderators to close discussion topics. > > But if you want a forum style interface... go for it. Just don't expect > me to create it for you, and don't expect me to join your forum, because > that's not the style of interface that I want. If you want to talk to me, > you have to talk to me where and how I want to talk - just as if I wanted > your advice, and you hung out on a forum, I'd have to put up with the forum > interface. > >
JB
Jordan Brown
Thu, Aug 17, 2023 11:07 PM
it easily.
Great.  You like forums.  I don't like forums.
A forum-email gateway would be fine (as long as the result on the email
side isn't awful, as many are).
Now, who is going to set up that gateway, and maintain it?  Remember
that nobody here is a paying customer, and nobody here is a paid
employee.  We all do stuff because we're interested in it, and
occasionally out of the goodness of our hearts.  Most people have only
limited time available, and so need to pick and choose which projects
they take on.
If you want a forum-email gateway... great.  Set one up.  Maintain it.
Pay for it, if necessary.  If it's workable, the nice folks who maintain
openscad.org would likely be happy to work with you to host it there.
But don't expect them to do the work to find one, set it up, and
maintain it.  They're volunteers, and they have other projects they want
to work on.
Yes, it's sometimes a pain in the neck that you can't do that.  But
agreeing that it's a pain in the neck doesn't make it any easier to
implement.
This is a variation on the "measure the distance between two points"
request.  I've thought about it a bit, and except in special cases I
can't see how to do it.  You can't do it inside the language because
information doesn't flow that way in the language; there is no way to
get information out of a module.  You can't do it in the UI, because the
previewer is absolute black magic and doesn't actually know what points
are in front, what points are hidden, and what points don't exist at all
because they've been intersected or differenced away.  (And even with a
rendered model, it's not easy to find a point on the model corresponding
to a click.)  You can't even do it with a pin like you describe, because
at the time that a particular node is rendered it doesn't know where it
will be translated or how it will be rotated or scaled
.  If you
accepted some restrictions, you could carry the transformation
information down into lower nodes, but the result would be a thoroughly
unsatisfying user experience - the user would have to consume the raw
coordinates and do the distance math themselves.  (Restrictions:
wouldn't be meaningful inside an extrusion or, I think, the second child
of a minkowski.  If my geometry-object work ever goes in, it wouldn't be
able to penetrate that barrier, because it divorces the execution
context from the transformation context.)
If you're interested in some thoughts on the subject, and a
demonstration of some related tricks, you can look at
https://lists.openscad.org/empathy/thread/IUPFIPEISP2XYU3SRVFWG54TLGSXMWOT
So why hasn't anybody turned that into a built-in OpenSCAD feature?
Because nobody has been interested in doing it, especially given the
resulting poor user experience.  (I couldn't, with a straight face, call
it a solution to the "measure distance" problem.)  All volunteers,
working on projects that interest them, remember?
On 8/17/2023 2:54 PM, edmund ronald wrote: > After being on Arpanet for a while, and more lately on this successor > thingy, even though I don't know much about computers  I'm aware that > there is email and  other  ways to communicate which various people > like more than others. And I'm very happy about that because it means > everybody gets to use their favorite tools.  If there were a forum, I > would expect it to have an email gate-through of some sort. The reason > I like forums is they make it easier for most people to disregard > stuff, including my whines, and above all, they allow people to find > old questions and replies easily, see the state of a topic, and reopen > it easily. Great.  You like forums.  I don't like forums. A forum-email gateway would be fine (as long as the result on the email side isn't awful, as many are). Now, who is going to set up that gateway, and maintain it?  Remember that nobody here is a paying customer, and nobody here is a paid employee.  We all do stuff because we're interested in it, and occasionally out of the goodness of our hearts.  Most people have only limited time available, and so need to pick and choose which projects they take on. If you want a forum-email gateway... great.  Set one up.  Maintain it.  Pay for it, if necessary.  If it's workable, the nice folks who maintain openscad.org would likely be happy to work with you to host it there.  But don't expect them to do the work to find one, set it up, and maintain it.  They're volunteers, and they have other projects they want to work on. > Regarding the absolute stuff, look I don't know much about 3D printing > and I don't know much about CAD, but I do know that I want to be able > to quickly see roughly what is going to pop out of my printer. I've > had to do horrible calculations to do this in the past, and it would > be simpler if one could just at least eg. have a fake component "pin" > type, and one places it in the  design and then it spits out its > coordinates into the debug window when rendered. And then one could > figure out some critical dimensions by looking at where those pins are.  > Yes, it's sometimes a pain in the neck that you can't do that.  But agreeing that it's a pain in the neck doesn't make it any easier to implement. This is a variation on the "measure the distance between two points" request.  I've thought about it a bit, and except in special cases I can't see how to do it.  You can't do it inside the language because information doesn't flow that way in the language; there is no way to get information out of a module.  You can't do it in the UI, because the previewer is absolute black magic and doesn't actually know what points are in front, what points are hidden, and what points don't exist at all because they've been intersected or differenced away.  (And even with a rendered model, it's not easy to find a point on the model corresponding to a click.)  You can't even do it with a pin like you describe, because at the time that a particular node is rendered *it doesn't know where it will be translated or how it will be rotated or scaled*.  If you accepted some restrictions, you could carry the transformation information down into lower nodes, but the result would be a thoroughly unsatisfying user experience - the user would have to consume the raw coordinates and do the distance math themselves.  (Restrictions:  wouldn't be meaningful inside an extrusion or, I think, the second child of a minkowski.  If my geometry-object work ever goes in, it wouldn't be able to penetrate that barrier, because it divorces the execution context from the transformation context.) If you're interested in some thoughts on the subject, and a demonstration of some related tricks, you can look at https://lists.openscad.org/empathy/thread/IUPFIPEISP2XYU3SRVFWG54TLGSXMWOT So why hasn't anybody turned that into a built-in OpenSCAD feature?  Because nobody has been interested in doing it, especially given the resulting poor user experience.  (I couldn't, with a straight face, call it a solution to the "measure distance" problem.)  All volunteers, working on projects that interest them, remember?
ER
edmund ronald
Thu, Aug 17, 2023 11:29 PM
Thank you for the interesting link. However, assuming my small pin  is
"vividred" in color, when I render the file into stl, I can locate the
"vividred" rice grain  point inside the model and thereby know its
position? Or maybe just project the model in 2d, and find the point thusly?
In other words, can't OpenSCAD cause something to be written into the
export file which itself is I would assume of necessity in real physical
coordinates?
On Fri, Aug 18, 2023 at 1:07 AM Jordan Brown openscad@jordan.maileater.net
implement.
particular node is rendered it doesn't know where it will be translated or
Thank you for the interesting link. However, assuming my small pin is "vividred" in color, when I render the file into stl, I can locate the "vividred" rice grain point inside the model and thereby know its position? Or maybe just project the model in 2d, and find the point thusly? In other words, can't OpenSCAD cause something to be written into the export file which itself is I would assume of necessity in real physical coordinates? On Fri, Aug 18, 2023 at 1:07 AM Jordan Brown <openscad@jordan.maileater.net> wrote: > On 8/17/2023 2:54 PM, edmund ronald wrote: > > After being on Arpanet for a while, and more lately on this successor > thingy, even though I don't know much about computers I'm aware that there > is email and other ways to communicate which various people like more > than others. And I'm very happy about that because it means everybody gets > to use their favorite tools. If there were a forum, I would expect it to > have an email gate-through of some sort. The reason I like forums is they > make it easier for most people to disregard stuff, including my whines, and > above all, they allow people to find old questions and replies easily, see > the state of a topic, and reopen it easily. > > > Great. You like forums. I don't like forums. > > A forum-email gateway would be fine (as long as the result on the email > side isn't awful, as many are). > > Now, who is going to set up that gateway, and maintain it? Remember that > nobody here is a paying customer, and nobody here is a paid employee. We > all do stuff because we're interested in it, and occasionally out of the > goodness of our hearts. Most people have only limited time available, and > so need to pick and choose which projects they take on. > > If you want a forum-email gateway... great. Set one up. Maintain it. > Pay for it, if necessary. If it's workable, the nice folks who maintain > openscad.org would likely be happy to work with you to host it there. > But don't expect them to do the work to find one, set it up, and maintain > it. They're volunteers, and they have other projects they want to work on. > > Regarding the absolute stuff, look I don't know much about 3D printing and > I don't know much about CAD, but I do know that I want to be able to > quickly see roughly what is going to pop out of my printer. I've had to do > horrible calculations to do this in the past, and it would be simpler if > one could just at least eg. have a fake component "pin" type, and one > places it in the design and then it spits out its coordinates into the > debug window when rendered. And then one could figure out some critical > dimensions by looking at where those pins are. > > > Yes, it's sometimes a pain in the neck that you can't do that. But > agreeing that it's a pain in the neck doesn't make it any easier to > implement. > > This is a variation on the "measure the distance between two points" > request. I've thought about it a bit, and except in special cases I can't > see how to do it. You can't do it inside the language because information > doesn't flow that way in the language; there is no way to get information > out of a module. You can't do it in the UI, because the previewer is > absolute black magic and doesn't actually know what points are in front, > what points are hidden, and what points don't exist at all because they've > been intersected or differenced away. (And even with a rendered model, > it's not easy to find a point on the model corresponding to a click.) You > can't even do it with a pin like you describe, because at the time that a > particular node is rendered *it doesn't know where it will be translated or > how it will be rotated or scaled*. If you accepted some restrictions, you > could carry the transformation information down into lower nodes, but the > result would be a thoroughly unsatisfying user experience - the user would > have to consume the raw coordinates and do the distance math themselves. > (Restrictions: wouldn't be meaningful inside an extrusion or, I think, the > second child of a minkowski. If my geometry-object work ever goes in, it > wouldn't be able to penetrate that barrier, because it divorces the > execution context from the transformation context.) > > If you're interested in some thoughts on the subject, and a demonstration > of some related tricks, you can look at > https://lists.openscad.org/empathy/thread/IUPFIPEISP2XYU3SRVFWG54TLGSXMWOT > > So why hasn't anybody turned that into a built-in OpenSCAD feature? > Because nobody has been interested in doing it, especially given the > resulting poor user experience. (I couldn't, with a straight face, call it > a solution to the "measure distance" problem.) All volunteers, working on > projects that interest them, remember? >
JB
Jordan Brown
Thu, Aug 17, 2023 11:56 PM
If STL could represent color, and if OpenSCAD could render with color,
maybe.  But alas STL does not represent color, and OpenSCAD cannot
currently render with color, even for export into a format that supports
it.  There's a fair amount of interest in color rendering in support of
multicolor printing, but it's hard enough that I'm not even aware of any
experimental builds that do it.  (Not that I would necessarily know.)
You might like to hang a tidbit of information on a vertex and have that
tidbit follow it out to the export, but even if the export format
supported such auxiliary information (STL doesn't), that would be a lot
of plumbing through some pretty black boxes.  I don't know enough about
CGAL to know for sure, but my bet is that there's no way to get it to
carry such a tag through its processing.
The way that I "solve" this problem is to have a module that generates a
yardstick, and position it where I need it in my model.  That's a
terrible solution, but it's been close enough for my needs.
On 8/17/2023 4:29 PM, edmund ronald wrote: > Thank you for the interesting link. However, assuming my small pin  is > "vividred" in color, when I render the file into stl, I can locate the > "vividred" rice grain  point inside the model and thereby know its > position? Or maybe just project the model in 2d, and find the point > thusly? In other words, can't OpenSCAD cause something to be written > into the export file which itself is I would assume of necessity in > real physical coordinates? If STL could represent color, and if OpenSCAD could render with color, maybe.  But alas STL does not represent color, and OpenSCAD cannot currently render with color, even for export into a format that supports it.  There's a fair amount of interest in color rendering in support of multicolor printing, but it's hard enough that I'm not even aware of any experimental builds that do it.  (Not that I would necessarily know.) You might like to hang a tidbit of information on a vertex and have that tidbit follow it out to the export, but even if the export format supported such auxiliary information (STL doesn't), that would be a lot of plumbing through some pretty black boxes.  I don't know enough about CGAL to know for sure, but my bet is that there's no way to get it to carry such a tag through its processing. The way that I "solve" this problem is to have a module that generates a yardstick, and position it where I need it in my model.  That's a terrible solution, but it's been close enough for my needs.
