In a message dated 9/24/07 12:00:49 AM, Rob writes:
This has been a fascinating thread and I hesitate to digress from the core
issue but there must be some out there who, like me, have trawler style
hulls which are run at hull speed (7kts for 1.2) but are powered by big
gasoline engines. We run our two 454 Crusaders at 1,400 to 1,600 rpm to
achieve 1.2 to 1.34 or 7 to 7.8 kts. What might the long term effect to the
life of the engine be? Should we be regularly running at WOT to "clean it
out?" We get 6 gph at 7.5 kts, and are hoping for 3,000 hours out of the big
Chevys.
I have never seen a case where a gasoline engine was injured by running it
slowly and under light load provided:
- The thermostat and cooling system permit the engine to get up to normal
operating temperature.
- Oil is changed regularly according to the manufacturers recommendations.
- The engine is not run too lean.
- The air cleaner is serviced regularly.
Most gasoline engines die of neglect rather than overuse. If you are kind to
your engines, you should get 3000 hours without trouble.
Larry Z
See what's new at http://www.aol.com
> Chevys.
1. The thermostat and cooling system permit the engine to get up to normal
2. Oil is changed regularly according to the manufacturers recommendations.
3. The engine is not run too lean.
4. The air cleaner is serviced regularly.
Larry Z
