trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
2 10 30 Micron Filters??
JF
Jim Fisher
Mon, Dec 31, 2007 2:45 PM
According to everything I've read, the fuel flow thru ratings for all the
various Racor filters is identical. The only difference is how fast they'll
actually clog up. With clean tanks, clean fuel and installed vacuum guages to
monitor pressure, using 2 microns should be no problem at all. I've been doing
just that with my 20 year old Cummins 210's for the last 3 years (1500 engine
hours) with no problems.
Happy New Year,
Jim
@Home
According to everything I've read, the fuel flow thru ratings for all the various Racor filters is identical. The only difference is how fast they'll actually clog up. With clean tanks, clean fuel and installed vacuum guages to monitor pressure, using 2 microns should be no problem at all. I've been doing just that with my 20 year old Cummins 210's for the last 3 years (1500 engine hours) with no problems. Happy New Year, Jim @Home
RR
Ron Rogers
Mon, Dec 31, 2007 3:08 PM
Flowscan instruments wants users to stick to 10 microns or larger. That
implies that the micron size does influence the flow rate OR smaller micron
sizes clog sooner and, therefore, affect the flow rate. As I recall, DD
wants to see a 30 micron off-engine filter.
Ron Rogers
----- Original Message -----
they'll
to
doing
engine
Flowscan instruments wants users to stick to 10 microns or larger. That implies that the micron size does influence the flow rate OR smaller micron sizes clog sooner and, therefore, affect the flow rate. As I recall, DD wants to see a 30 micron off-engine filter. Ron Rogers ----- Original Message ----- From: "Jim Fisher" <magothy1@mail.com> | According to everything I've read, the fuel flow thru ratings for all the | various Racor filters is identical. The only difference is how fast they'll | actually clog up. With clean tanks, clean fuel and installed vacuum guages to | monitor pressure, using 2 microns should be no problem at all. I've been doing | just that with my 20 year old Cummins 210's for the last 3 years (1500 engine | hours) with no problems.
FB
Frank Burrows
Mon, Dec 31, 2007 3:17 PM
Ron:
Racor says the flow rate is the same. I have a vacuum gauge installed on my
Racors and the vacuum is the same for a 2 or a 30 micron filter. I would
suggest that lots of other listees have similar setup and I would ask if
anyone gets a different reading from a clean 2 or, 10 or 30 micron filter?
I think this supports Racor's contention that the flow rate is the same. I
have been using 2 microns on my Detroits for 15 years with no ill effects.
I believe that I have cleaner fuel in my tanks because the fuel is
constantly filtered and returned through 2 micron filters.
Frank Burrows    Destiny  1979  43'  Viking MY
Piney Narrows    Chesapeake Bay
Ron: Racor says the flow rate is the same. I have a vacuum gauge installed on my Racors and the vacuum is the same for a 2 or a 30 micron filter. I would suggest that lots of other listees have similar setup and I would ask if anyone gets a different reading from a clean 2 or, 10 or 30 micron filter? I think this supports Racor's contention that the flow rate is the same. I have been using 2 microns on my Detroits for 15 years with no ill effects. I believe that I have cleaner fuel in my tanks because the fuel is constantly filtered and returned through 2 micron filters. Frank Burrows Destiny 1979 43' Viking MY Piney Narrows Chesapeake Bay At 10:08 AM 12/31/2007 -0500, you wrote: >Flowscan instruments wants users to stick to 10 microns or larger. That >implies that the micron size does influence the flow rate OR smaller micron >sizes clog sooner and, therefore, affect the flow rate. As I recall, DD >wants to see a 30 micron off-engine filter.
RR
Ron Rogers
Mon, Dec 31, 2007 3:19 PM
Frank,
This is good news for me as I have a box of 2 micron filters for my Racors!
Thank you,
Ron
| Ron:
my
Frank, This is good news for me as I have a box of 2 micron filters for my Racors! Thank you, Ron ----- Original Message ----- From: "Frank Burrows" <fburrows@mail.com> | Ron: | | Racor says the flow rate is the same. I have a vacuum gauge installed on my | Racors and the vacuum is the same for a 2 or a 30 micron filter. I would | suggest that lots of other listees have similar setup and I would ask if | anyone gets a different reading from a clean 2 or, 10 or 30 micron filter? | | I think this supports Racor's contention that the flow rate is the same. I | have been using 2 microns on my Detroits for 15 years with no ill effects. | I believe that I have cleaner fuel in my tanks because the fuel is | constantly filtered and returned through 2 micron filters.
BC
Bob Clinkenbeard
Mon, Dec 31, 2007 3:23 PM
Here is what I have found at
http://www.filtercouncil.org/index.php?page=heavy-duty-diesel-fuel-filters
Q: What is the difference between a primary and secondary diesel fuel
filter?
A: The primary fuel filter must offer low restriction because it is mounted
on the suction side of the fuel pump where normally a suction pressure of
only 5-6 pounds per square inch is available. This filter has the job of
protecting the transfer pump and lightening the load of the secondary fuel
filter (if installed). Primary fuel filters typically have a nominal rating
of 10 - 30 microns.
Secondary fuel filters are mounted between the transfer pump and the
injectors. The secondary fuel filter is designed to offer full protection to
the fuel injectors. Since these filters are mounted after the transfer pump
they tend to see much higher pressures than primary filters. Secondary fuel
filters typically have a nominal rating of 2 - 10 microns.
Bob Clinkenbeard
24' custom trailer trawler
http://home.bellsouth.net/p/PWP-aboardbobbinalong
Here is what I have found at http://www.filtercouncil.org/index.php?page=heavy-duty-diesel-fuel-filters Q: What is the difference between a primary and secondary diesel fuel filter? A: The primary fuel filter must offer low restriction because it is mounted on the suction side of the fuel pump where normally a suction pressure of only 5-6 pounds per square inch is available. This filter has the job of protecting the transfer pump and lightening the load of the secondary fuel filter (if installed). Primary fuel filters typically have a nominal rating of 10 - 30 microns. Secondary fuel filters are mounted between the transfer pump and the injectors. The secondary fuel filter is designed to offer full protection to the fuel injectors. Since these filters are mounted after the transfer pump they tend to see much higher pressures than primary filters. Secondary fuel filters typically have a nominal rating of 2 - 10 microns. Bob Clinkenbeard 24' custom trailer trawler http://home.bellsouth.net/p/PWP-aboardbobbinalong
BC
Bob Clinkenbeard
Mon, Dec 31, 2007 3:29 PM
May be boring to some, but good information for the rest of us.
http://seagrant.uaf.edu/bookstore/boatkeeper/fuel-filters.pdf
Bob Clinkenbeard
May be boring to some, but good information for the rest of us. http://seagrant.uaf.edu/bookstore/boatkeeper/fuel-filters.pdf Bob Clinkenbeard 24' custom trailer trawler http://home.bellsouth.net/p/PWP-aboardbobbinalong
