View all threadsGwen,
Wow, it was only 15 days ago too. The coincidence! Yes, that is the exact
problem. Thank you!
I have got mine compiled and I can see that it did build the converter for
the neon.
Kevin
On Fri, Nov 10, 2017 at 2:07 AM, Gwenhael Goavec-Merou via USRP-users <
Hello,
maybe this : https://github.com/EttusResearch/uhd/pull/135
will help you
Gwen
On Fri, 10 Nov 2017 00:29:25 -0600
Kevin McGuire via USRP-users usrp-users@lists.ettus.com wrote:
I was able to get the compiler flags passed in so that the check for
the header arm_neon.h passes. I added it to the CMakeList root file
with SET(CMAKE_CXX_FLAGS, "${CMAKE_CXX_FLAGS} -mfloat-abi=softfp
-mfpu=neon").
Then, it would detect neon. However, I spent considerable time
cleaning up whatever package problems I had since I ended up with a
bunch of weird errors.
Once I straightened my packages up (Debian), it is compiling with
neon! And, hopefully, it will actually use the ARM neon routines.
On Thu, Nov 9, 2017 at 3:22 AM, Kevin McGuire kmcg3413@gmail.com
wrote:
I have noticed that neon support for the converter is not enabling.
The CMakeError.log has this output. I am not certain as I am not
really familiar with ARM and NEON, but I checked my CPU and it does
support it. Also, the error message below is saying it is just a
matter of passing certain flags.
/mnt/extra/usr/lib/gcc/arm-linux-gnueabihf/4.8/include/arm_
neon.h:32:2:
error: #error You must enable NEON instructions (e.g.
-mfloat-abi=softfp -mfpu=neon) to use arm_neon.h
#error You must enable NEON instructions (e.g. -mfloat-abi=softfp
Normally, I would just fix it myself and move forward, but me and
CMake mix like oil and water. It is kind of embarrassing but I
swear it never does what I want it do - such as adding a darn flag.
I even tried to force the options, lol, and all be danged if CMake
finds some way to error.
Will work on this tomorrow, but if anyone has a solution I am all
ears. If not then no problem and I will reply when I figure it out.
This came about when I noticed what really seemed like abnormally
high CPU usage on my ARM code for a simple shuffling of data out of
the network packets. I traced what I felt like was the biggest
possible hot spot to the converter routine. Anyway, that is my plan
right now, to see if NEON might help if the converter is having to
swap byte order.
USRP-users mailing list
USRP-users@lists.ettus.com
