pjsip with alsa pcm mult
SJ
Serrano Jiménez, Jaime [ABANCE]
Mon, Jan 28, 2013 8:53 AM
Hello everybody,
I´m trying to get a virtual sound interface (ALSA pcm multi) working with pjsip2.0.
I've configured a virtual alsa device with 2 input and 2 output. The interface works properly and has been checked with the next command:
aplay -vv -D "IDinterface" wav.wav
Besides that, the interface is detected by the pjsua application but when the call is established no sound in transmitted.
When the call is established the cl command output is:
Conference ports:
Port #00[16KHz/20ms/2]                            test                                      transmitting to:                #3
Port #01[16KHz/20ms/2]                            ringback                              transmitting to:
Port #02[16KHz/20ms/2]                            ring                                      transmitting to:
Port #03[16KHz/20ms/2]                            sip:192.168.30.2              transmitting to:              #0
Thanks in advanced!
NAVANTIA
Este mensaje, y cualquier fichero anexo al mismo, contiene informacion de caracter confidencial dirigida exclusivamente a su(s) destinatario(s) y, en su caso, sometida a secreto profesional. Queda prohibida su difusion, copia o distribucion a terceros sin la previa autorizacion escrita. Si Vd. ha recibido este mensaje por error, se ruega lo comunique inmediatamente por esta misma via y proceda a su completa eliminacion.
The information in this e-mail, and in any attachments, is confidential and, if any, protected by a professional privilege, and intended solely for the attention and use of the named addressee(s). You are hereby notified that any dissemination, copy or distribution of this information is prohibited without the prior written consent. If you have received this communication in error, please notify the sender by reply e-mail and delete it.
Hello everybody, I´m trying to get a virtual sound interface (ALSA pcm multi) working with pjsip2.0. I've configured a virtual alsa device with 2 input and 2 output. The interface works properly and has been checked with the next command: aplay -vv -D "IDinterface" wav.wav Besides that, the interface is detected by the pjsua application but when the call is established no sound in transmitted. When the call is established the cl command output is: Conference ports: Port #00[16KHz/20ms/2] test transmitting to: #3 Port #01[16KHz/20ms/2] ringback transmitting to: Port #02[16KHz/20ms/2] ring transmitting to: Port #03[16KHz/20ms/2] sip:192.168.30.2 transmitting to: #0 Thanks in advanced! NAVANTIA ______________________________ Este mensaje, y cualquier fichero anexo al mismo, contiene informacion de caracter confidencial dirigida exclusivamente a su(s) destinatario(s) y, en su caso, sometida a secreto profesional. Queda prohibida su difusion, copia o distribucion a terceros sin la previa autorizacion escrita. Si Vd. ha recibido este mensaje por error, se ruega lo comunique inmediatamente por esta misma via y proceda a su completa eliminacion. The information in this e-mail, and in any attachments, is confidential and, if any, protected by a professional privilege, and intended solely for the attention and use of the named addressee(s). You are hereby notified that any dissemination, copy or distribution of this information is prohibited without the prior written consent. If you have received this communication in error, please notify the sender by reply e-mail and delete it. ______________________________
