View all threadsHello,
Apologies if this question is too basic, but I have not been able to find a definitive answer in the N310 documentation. Is it possible to stream data or signals to or from the USRP using the GPIO ports, or is it only useful for status and triggering? Specifically, is it possible to use the GPIO to stream an arbitrary waveform to the N310, digitize it, and then modulate and transmit it? Conversely, is it possible to receive a signal, demodulate and stream it to the GPIO?
Very respectfully,
Joshua White
Precision Timing Systems Engineer
Engineering & Support Solutions Directorate
www.riversideresearch.orghttp://www.riversideresearch.org/
T: 937.986.3153 | F: 937.431.3811
This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain proprietary, confidential or privileged information or otherwise be protected by law. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please notify the sender and destroy all copies and the original message.
On 2022-06-09 11:05, White, Joshua J wrote:
Hello,
Very respectfully,
*Joshua White *
www.riversideresearch.org http://www.riversideresearch.org/
The GPIOs are intended only for low-rate status/triggers/external
hardware controls.
