K
KD0GLS
Tue, Jun 21, 2011 5:44 PM
With all the discussion lately regarding DDS and CORDIC, I'm reminded of a question that came up some time ago for which I've never found an answer. Perhaps you enlightened people can enlighten me.
Given a complete DDS chip with a single output channel (e.g. AD9834, AD9835), why would one device favor a cosine LUT versus a sine LUT? On the surface, starting the roller coaster ride at the top of the hill (assuming the phase accumulator starts from zero) seems odd.
.73,
Brent, KD0GLS, Minneapolis
.73,
CA
Chris Albertson
Tue, Jun 21, 2011 6:38 PM
Are the LUTs really different? Ages ago when I made something like
this I used only 90 degrees of the table. That is all you need. The
other 270 degrees can be made by flipping or inverting. I assume that
what's stored is neither. It is data that needs to be interpeted
based on the current quadrant. But the author might choose to call it
which ever makes the most sense.
Chris Albertson
Redondo Beach, California
Chris Albertson
K
KD0GLS
Tue, Jun 21, 2011 7:03 PM
Yes, as did I and most implementations, but why a cosine quarter-table instead of the more common sine? A quick look at the data sheets (and the waveforms in the theory-of-op sections) for the two devices suggests they are clearly calling out one or the other, but without rationale regarding the choice.
.73,
.73,
L
lists@lazygranch.com
Tue, Jun 21, 2011 7:11 PM
The cordic needs to compute both sin and cos. You are right that you just need one or the other if you have one DAC.
-----Original Message-----
Sender: time-nuts-bounces@febo.com
Date: Tue, 21 Jun 2011 11:38:30
To: Discussion of precise time and frequency measurementtime-nuts@febo.com
Reply-To: Discussion of precise time and frequency measurement
time-nuts@febo.com
Subject: Re: [time-nuts] DDS - Cosine v. Sine LUT
Chris Albertson
To: Discussion of precise time and frequency measurement<time-nuts@febo.com>
Chris Albertson
LC
Luis Cupido
Tue, Jun 21, 2011 7:18 PM
Hi Brent,
A quarter table cos is exactly the same as a quarter table sin.
Only backwards, and not telling which quarter it is makes it a
quarter of either sin or cos. For one single output becomes irrelevant
as you only need one.
So I think it is just a matter of taste the name to call it.
Luis Cupido.
ct1dmk.
.73,
Hi Brent,
Luis Cupido.
ct1dmk.
> .73,
> _______________________________________________
MD
Magnus Danielson
Tue, Jun 21, 2011 7:26 PM
By the way, you can save two bits of the LUT table width by only storing
the difference of the binary phase and the sine. Add the phase
(90-degree wrapped) to the output of the LUT to get the sine. In effect
the LUT can be allowed to be shifted two bits down for improved precision.
Cheers,
Magnus
Cheers,
Magnus
RL
Robert LaJeunesse
Tue, Jun 21, 2011 7:31 PM
Brent,
For the specific case of generating a synchronous FSK signal with a fairly wide
shift there may be a reason. Such an application presumes a high enough ratio
between clock and output frequencies such that the DDS accumulator landing
adequately near zero is a certainty. If the FSK frequency is changed
synchronously - just after the point of DDS accumulator rollover - a sine LUT
would potentially show an abrupt change in dv/dt (slew rate) with the frequency
change. By using a cosine LUT the signal would be at its peak, and dv/dt would
be virtually zero both before and after the frequency change.
Bob LaJeunesse
Ann Arbor, MI
To: Time-Nuts time-nuts@febo.com
Sent: Tue, June 21, 2011 1:44:26 PM
Subject: [time-nuts] DDS - Cosine v. Sine LUT
.73,
Brent,
Bob LaJeunesse
Ann Arbor, MI
To: Time-Nuts <time-nuts@febo.com>
.73,
K
KD0GLS
Tue, Jun 21, 2011 8:09 PM
That's an interesting thought. The diagram of the 9835 (the one labeled as having the cosine ROM) also shows some sync logic associated with the select lines steering the FSK and PSK registers. If that logic syncs the select lines to the phase accumulator rollover, as you said, the slope of the signal would be near zero at that point, as opposed to at the zero-crossing with a sine-based device. An interesting theory at least.
On Jun 21, 2011, at 14:31, Robert LaJeunesse wrote:
Brent,
For the specific case of generating a synchronous FSK signal with a fairly wide shift there may be a reason. Such an application presumes a high enough ratio between clock and output frequencies such that the DDS accumulator landing adequately near zero is a certainty. If the FSK frequency is changed synchronously - just after the point of DDS accumulator rollover - a sine LUT would potentially show an abrupt change in dv/dt (slew rate) with the frequency change. By using a cosine LUT the signal would be at its peak, and dv/dt would be virtually zero both before and after the frequency change.
Bob LaJeunesse
Ann Arbor, MI
.73,
.73,
> Brent,
> Bob LaJeunesse
> Ann Arbor, MI
> From: KD0GLS <kd0gls@mninter.net>
> .73,
.73,
GH
Gerhard Hoffmann
Tue, Jun 21, 2011 11:10 PM
Am 21.06.2011 21:03, schrieb KD0GLS:
It can be the same table, and if it delivers sine or cosine is
determined only
whether you start indexing from the highest or lowest address .
(if you store only 1/4 wave)
When you split the ROM into 2 smaller ones, you can get sin and
cos at the same time, there will never be an address clash.
One ROM for 0...44.9 deg and one for 45...89.999° . Just a MUX
to select the appropriate ROM for each output and a little bit of
address massage.
Big cost saver for complex converters.
Gerhard, dk4xp
determined only
address massage.
Gerhard, dk4xp
