TLS support in python
SH
Sebastian Hübner
Tue, Apr 6, 2010 5:19 PM
Hello,
as a part of my master thesis I'm going to implement a SIP UA using
PJSIP and python.
I'm  trying to use TLS for the communication (for every outgoing
messages - REGISTER, INVITE, ...).
Unfortunatly, I have the following problem:
imort pjsua as pj
trans_cfg = pj.TransportConfig(port=5061)
transport = lib.create_transport(pj.TransportType.TLS, cfg=trans_cfg)
returns with:
python: ../src/pjsua-lib/pjsua_core.c:2010: pjsua_transport_get_info:
Assertion `!"Unsupported transport"' failed.
Replacing pj.TransportType.TLS with pj.TransportType.UDP or
pj.TransportType.TCP it works well.
I also tried to establish the TLS connection by using C and it worked too.
How can I solve this problem in python?
Thanks in advance.
Regards,
Sebastian
Hello, as a part of my master thesis I'm going to implement a SIP UA using PJSIP and python. I'm trying to use TLS for the communication (for every outgoing messages - REGISTER, INVITE, ...). Unfortunatly, I have the following problem: imort pjsua as pj [...] trans_cfg = pj.TransportConfig(port=5061) transport = lib.create_transport(pj.TransportType.TLS, cfg=trans_cfg) [...] returns with: python: ../src/pjsua-lib/pjsua_core.c:2010: pjsua_transport_get_info: Assertion `!"Unsupported transport"' failed. Replacing pj.TransportType.TLS with pj.TransportType.UDP or pj.TransportType.TCP it works well. I also tried to establish the TLS connection by using C and it worked too. How can I solve this problem in python? Thanks in advance. Regards, Sebastian
SI
Saúl Ibarra Corretgé
Tue, Apr 6, 2010 5:30 PM
Hi,
On 6/4/10 7:19 PM, Sebastian Hübner wrote:
Hello,
PJSIP and python.
imort pjsua as pj
returns with:
Thanks in advance.
AFAIS in the code (pjsua_core.c) you can only create UDP or TCP
trnasports. Maybe you need to start a TCP transport and then do
something else, can't remember right now, sorry.
You may want to try SIPSIMPLE SDK, a high level API written in Pyton for
coding SIP clients (PJSIP based): http://sipsimpleclient.com
Regards,
AG Projects
Hi, On 6/4/10 7:19 PM, Sebastian Hübner wrote: > > Hello, > > as a part of my master thesis I'm going to implement a SIP UA using > PJSIP and python. > I'm trying to use TLS for the communication (for every outgoing > messages - REGISTER, INVITE, ...). > > Unfortunatly, I have the following problem: > > imort pjsua as pj > [...] > trans_cfg = pj.TransportConfig(port=5061) > transport = lib.create_transport(pj.TransportType.TLS, cfg=trans_cfg) > [...] > > returns with: > > python: ../src/pjsua-lib/pjsua_core.c:2010: pjsua_transport_get_info: > Assertion `!"Unsupported transport"' failed. > > Replacing pj.TransportType.TLS with pj.TransportType.UDP or > pj.TransportType.TCP it works well. > I also tried to establish the TLS connection by using C and it worked too. > > How can I solve this problem in python? > Thanks in advance. > AFAIS in the code (pjsua_core.c) you can only create UDP or TCP trnasports. Maybe you need to start a TCP transport and then do something else, can't remember right now, sorry. You may want to try SIPSIMPLE SDK, a high level API written in Pyton for coding SIP clients (PJSIP based): http://sipsimpleclient.com Regards, -- Saúl Ibarra Corretgé AG Projects
