View all threadsHi Stan,
I have attached a MATLAB script, sUSRPFullDuplex.m, that performs duplex transmission on one USRP radio. Details on my setup and code:
MATLAB R2012a
N210 baseboard, SBX daughterboard
Transmission/reception frequency = 915 MHz
The script transmits a sine wave with the SDRu Transmitter System object, then receives it with the SDRu Receiver System object and plots the spectrum. The sine wave amplitude changes as the script runs, and that change is reflected in the spectrum plot.
This script is tuned for R2012a, so let me know if you move to R2012b.
I hope the script is useful to you - thanks for your patience.
Mike
Sent: Monday, August 20, 2012 9:37 AM
To: usrp-users@lists.ettus.com
Cc: Mike McLernon; Marc Erickson
Subject: RE: [USRP-users] SBX RF board simultaneous mode with USRP Hardware Support for MATLAB
Importance: High
Hi Mike and Marc,
Using the MathWorks example file "sdruFRSGMRSTransmitter", I have attempted to create the example that I described below but have been far from successful. Therefore, without wishing to become a nuisance, could you please let me know when I can look forward to receiving a MATLAB version of the Simulink model that you sent earlier?
With many thanks,
Stan
From: usrp-users-bounces@lists.ettus.com [mailto:usrp-users-bounces@lists.ettus.com] On Behalf Of Mike McLernon
Sent: 10 August 2012 14:41
To: Stan Gamla
Cc: usrp-users@lists.ettus.com
Subject: Re: [USRP-users] SBX RF board simultaneous mode with USRP Hardware Support for MATLAB
Hi Stan,
Still working on it - I have something going for a one-radio setup, but I'd like to prove out a two-radio configuration.
Thanks for your patience,
Mike
Sent: Friday, August 10, 2012 8:38 AM
To: Mike McLernon
Cc: usrp-users@lists.ettus.com; Marc Erickson
Hi Mike,
Sorry to ask again... but I would very much appreciate the MATLAB example file.
Thanks,
Stan
From: Mike McLernon [mailto:Mike.McLernon@mathworks.com]
Sent: 03 August 2012 14:24
To: Stan Gamla
Hi Stan,
I'll work on the script and post it when it's done.
Mike
Sent: Friday, August 03, 2012 3:29 AM
To: Marc Erickson; Mike McLernon
Subject: RE: [USRP-users] SBX RF board simultaneous mode with USRP HardwareSupport for MATLAB
Hi Marc and Mike,
Further to my last message, could you please provide an equivalent example of the Simulink model that you posted earlier but this time written in MATLAB.
Thanks,
Stan
From: usrp-users-bounces@lists.ettus.com [mailto:usrp-users-bounces@lists.ettus.com] On Behalf Of Stan Gamla
Sent: 27 July 2012 15:43
To: 'Mike McLernon'
Subject: Re: [USRP-users] SBX RF board simultaneous mode with USRP HardwareSupport for MATLAB
Hi Mike,
Thanks for the responses to my questions and thanks too for the Simulink model. The latter has proved to be quite useful. To experiment with the model, I connected together the RF1 and RF2 ports of my N210 (+SBX) via a 30 dB fixed attenuator and a steppable attenuator (0-10 + 0/10/20/30/40 dB). I also modified the model and replaced the switch with a slider that controls the center frequency of both the Tx and Rx blocks, simultaneously.
The model and hardware configuration described above allows me to set fc and the attenuation in the RF path. However, the behaviour of the output (Rx) spectrum is not quite as I would have expected--instead of the amplitude of the peak changing when the RF attenuator is adjusted, it appears that the level of what could be called the noise floor of the output changes instead. Could this be due to a numerical effect in the Simulink FFT block that holds the "peak" but instead changes the "floor"? Or has it something to do with the Ettus radio--perhaps the result of some automatic gain control (AGC) circuitry?
Regardless of all of the above, I would be very happy to experiment and to study the complementary MATLAB scripts that are used to construct a system similar to the Simulink model that you so kindly posted to this forum.
Thanks,
Stan
Sent: 20 July 2012 18:32
To: Stan Gamla
Cc: Marc Erickson; usrp-users@lists.ettus.com
Hi Stan,
Responses interleaved below . . .
Sent: Friday, July 20, 2012 6:57 AM
To: Mike McLernon
Hi Mike,
With reference to the schematic of the Simulink model "mUSRPFullDuplex" that you posted earlier, could you please reveal what is in (or under) the block labeled "Receiver Processing"?
Hopefully you received my mail from earlier today with several models attached. If not, let me know.
Referring to item 5 in the list "experiment setup" (in which the SDRu Tx and SDRu Rx blocks are in the same model) would the system not perform full-duplex operation if two models were used?
If two models are used, and they are both using the same IP, they should still be performing full duplex. I have not run that case.
As a general question, could you please comment on how to configure the RF ports of the SBX board in which an RF switch is used to configure RF1 for either Tx or Rx.
Our R2011a and R2011b release notes state that the default antenna configurations cannot be changed. For my particular application, I did not need to perform any antenna configuration.
Finally, it would be very much appreciated if the sample Simulink model(s) could be shared in this community and it would be even more appreciated if they were to be complemented with equivalent MATLAB files. Such a system would be a useful example to include in future releases from the MathWorks.
Let me know if the models I sent earlier are helpful to you. We would want to include such models (and complementary MATLAB scripts) in future releases.
Hth,
Mike
Thanks in advance,
Stan
Sent: 19 July 2012 17:06
To: Stan Gamla
Hi Stan,
I did the following experiment to ascertain our level of full duplex support:
Experiment Setup
Results
I've attached images of the model, the block dialogs, the tx and rx spectra, and the time plot of the overrun signal with this message. Please let us know if you have additional questions.
Best,
Mike
Sent: Sunday, July 15, 2012 6:14 AM
To: Marc Erickson; usrp-users@lists.ettus.com
Hi Marc,
Thanks for the kind offer to provide support.
In order to continue this thread within the community, I would like to respond by repeating my previous request:
Could you please comment and perhaps provide an illustration of how to configure the N210/SBX using both MATLAB and Simulink so that a signal is transmitted from the RF1 port and received by the RF2. As a suggestion, slider controls could be used in Simulink to independently adjust the RF settings of both the transmitter and receiver to include at least gain and center frequency. A spectrum of the received signal should be displayed.
With many thanks,
Stan
From: Marc Erickson [mailto:Marc.Erickson@mathworks.com]
Sent: 05 July 2012 19:19
To: Stan Gamla; usrp-users@lists.ettus.com
Hi Stan,
Sorry for the confusion about our support. We have stated some limitations of our support in the product release notes which are available in the download package. Type 'help sdru' and follow the 'Help and Examples' link. Then click on the link under 'Release Notes'. The relevant limitation is stated as follows:
"Communications with USRP(tm) only supports half-duplex applications. MATLAB and Simulink applications must be receive-only or transmit-only. Full-duplex is not supported."
Our package has separate Rx and Tx blocks (for Simulink) and separate Rx and Tx System objects (for MATLAB) with their own configuration parameters. We allow binding the Rx and Tx to the same board in order to support some duplex operations. Full duplex operation might be possible when adhering to some modeling constraints.
Please feel free to contact us directly to discuss any use-cases and specific applications you might be interested in pursuing and we'd be happy to work with you.
Regards,
Marc
Sent: Friday, June 29, 2012 7:03 AM
Subject: [USRP-users] SBX RF board simultaneous mode with USRP Hardware Support for MATLAB
As far as I understand, the Ettus SBX RF board comprises a full-duplex transceiver with separate receive and transmit chains, each having its own local oscillator.
https://www.ettus.com/product#tabs-3 states that:
"The SBX is a wide bandwidth transceiver that provides up to 100 mW of output power, and a typical noise figure of 5 dB. The local oscillators for the receive and transmit chains operate independently, which allows dual-band operation. The SBX is MIMO capable, and provides 40 MHz of bandwidth. The SBX is ideal for applications requiring access to a variety of bands in the 400 MHz-4400 MHz range. Example application areas include WiFi, WiMax, S-band transceivers and 2.4 GHz ISM band transceivers."
Further, according to their website "The MathWorks USRP(r) Hardware Support from [sic] MATLAB and Simulink is compatible with UHD(tm)-based Ettus radios".
http://www.mathworks.com/discovery/sdr/usrp.html viz:
"MATLAB and Simulink support for USRP(r) devices has been tested on N210 and USRP2(r) devices with WBX, SBX, XCVR2450, TVRX, TVRX2, LFRX, LFTX, DBSRX, and DBSRX2 daughterboards. Support may also extend to other UHD(tm)-based radios and daughterboards from National Instruments(r)."
Are both of these statements correct, I wonder?
If The MathWorks is tuned in to this channel, could you please comment and perhaps provide an illustration of how to configure the N210/SBX using both MATLAB and Simulink so that a signal is transmitted from the RF1 port and received by the RF2. As a suggestion, slider controls could be used in Simulink to independently adjust the RF settings of both the transmitter and receiver to include at least gain and center frequency. A spectrum of the received signal should be displayed.
On the other hand, if I have misunderstood what is meant by the word "supported" could either Ettus or The MathWorks comment please.
Thanks,
Stan
Hi Mike,
Thanks for sending the MATLAB script file which I have run on my N210/SBX
configuration under Windows XP and MATLAB 2012a.
The script:
creates three system objects (the sine wave signal source, the SDRu
transmitter and the SDRu receiver);
2.
opens a figure window to display a spectrum of a signal (presumably
that received by the SDRu at baseband);
3.
releases the sine source object after a number of seconds; and then
exits.
During execution of the script, the spectrum shows peaks at ±60 kHz with an
amplitude of about -35 dB/Hz and then when the sine source object is
released, their amplitude drops to a level of about -75 dB.
In my RF path from the RF1 to RF2 ports of the N210/SBX configuration, I
have two fixed attenuators connected to the RF1 and RF2 ports, each of 30
dB, and a variable stepped attenuator. However, adjusting the stepped
attenuator during the execution of the loop described above does not result
in any observable change in the spectrum--I would expect the peaks to be
reduced in unison with the attenuator adjustment. Furthermore, if I remove
one of the cables that forms part of the RF loop-back path between RF1 and
RF2 (but leave RF1 terminated in 50 ohm), I see the same spectrum as before.
If my understanding is correct, the RF1 port of the SBX RF daughter board
may be configured for either transmission or reception whereas the RF2
cannot be configured and is used for reception only. Please therefore
clarify how the RF1 port is configured for either transmission or reception
from MATLAB.
When creating the SDRu TX and SDRu RX objects, is it possible that they
could both be assigned to the same RF port (e.g. RF1)? If so, is it then
possible that they could operate on the same RF port using some form of time
sharing (TDD)?
Finally, even when the execution of the script is complete, the Ettus radio
appears to still be in the receive state (LEDs C and E (with D&F) are "on").
Why is the SDRu Tx released (LED A is "off") but not the SDRu RX? At the
command prompt, I can release the receiver with the command
"release(hSDRuRx)", thereafter LEDs C and E are off. What then is meant by
the the statement given in
"/help/methods/sdru_receiver/comm.sdrureceiver.release.html" -- "You cannot
use the release method on System objects in code generated from MATLAB"?
Thanks for your continuing support.
Kind regards,
Stan
Sent: 22 August 2012 18:21
To: Stan Gamla
Support for MATLAB
Hi Stan,
MATLAB R2012a
I hope the script is useful to you thanks for your patience.
Mike
Support for MATLAB
Importance: High
Hi Mike and Marc,
With many thanks,
Stan
Hi Marc and Mike,
MATLAB.
Thanks,
Stan
To: 'Mike McLernon'
Hi Mike,
circuitry?
Thanks,
Stan
To: Stan Gamla
Support for MATLAB
Hi Stan,
To: Mike McLernon
Support for MATLAB
Hi Mike,
either Tx or Rx.
releases.
Hth,
Mike
Thanks in advance,
Stan
To: Stan Gamla
Support for MATLAB
Hi Stan,
support:
Experiment Setup
N210/SBX
VERT900 antennas for both tx and rx
Win64 on a 12-core development machine
One MATLAB session, one Simulink model
SDRu Tx block and SDRu Rx block in same model
Model runs in accelerator mode
Spectrum Scope blocks for tx and rx waveforms, a Simulink Scope to
monitor rx overruns
Interpolation/decimation factor of 512 (maximum allowed)
Tx center frequency = 915 MHz
Rx center frequency = 915 or 915.04 MHz (controlled with a manual
switch)
Optimizations:
Use singles rather than doubles
Use accelerator rather than normal mode
Turned on compiler optimizations
Turned off all data logging
Results
Rx Spectrum Scope shows tones where they should be
Simulink Scope shows no overruns
When the SDRu Receiver block's center frequency is changed with the
manual switch shortly after the simulation starts, the rx Spectrum Scope
shows the change quickly.
As the simulation continues, it takes progressively longer for the
change to show in the Spectrum Scope.
With one scope removed, the change is reflected more quickly, but it
still takes progressively longer as the simulation continues.
Conclusion is that a data buffer is slowly filling up and taking
more time to empty out.
If the tx Spectrum Scope were removed, the model would run faster,
and the frequency changes would show more quickly.
Ive attached images of the model, the block dialogs, the tx and rx spectra,
Best,
Mike
Hi Marc,
With many thanks,
Stan
Hi Stan,
download package. Type help sdru and follow the Help and Examples link.
Then click on the link under Release Notes. The relevant limitation is
stated as follows:
Communications with USRP only supports half-duplex applications. MATLAB
is not supported.
specific applications you might be interested in pursuing and wed be happy
to work with you.
Regards,
Marc
Support for MATLAB
local oscillator.
Further, according to their website "The MathWorks USRP® Hardware Support
from [sic] MATLAB and Simulink is compatible with UHD-based Ettus radios".
"MATLAB and Simulink support for USRP® devices has been tested on N210 and
USRP2® devices with WBX, SBX, XCVR2450, TVRX, TVRX2, LFRX, LFTX, DBSRX, and
DBSRX2 daughterboards. Support may also extend to other UHD-based radios
and daughterboards from National Instruments®."
Thanks,
Stan
