The cheap PC supply may need a load greater than the Thunderbolt to work, as a quick dirty hack I've used a 12V auto signal light on the 5 volt supply.
Stanley
----- Original Message ----
To: Discussion of precise time and frequency measurement time-nuts@febo.com
Sent: Saturday, June 14, 2008 8:31:22 AM
Subject: Re: [time-nuts] [Fwd: Re: Thunderbolt PS]
I would like to add an extra question:
How about adding an extra filter after a cheap PC power supply?
73,
Rainer
Whilst that may help with the high frequency power supply
noise, it wont help with power supply flicker noise.
Bruce
Or the lousy regulation and temperature stability, which on a cheap supply
may be worse.
If the cheap supply can be adjusted to provide 6V instead of 5 and 14V
instead of 12, both outputs could be followed by a stable low drop-out
voltage regulator (probably discrete rather than an IC) to provide stable
and clean 5V and 12V respectively.
The -12V only drives the RS-232 chip I believe, so I don't think there is
anything to gain with further regulation. If the voltage is too high (as a
result of adjusting the other outputs), use a cheap regulator or a
zener/resistor.
Didier
Stanley
To: Discussion of precise time and frequency measurement <time-nuts@febo.com>
> > 73,
> > Rainer
> Bruce
may be worse.
zener/resistor.
Didier
