By the way if you can fit a big enough compressor, you can save lots of
room and hassle by using air powered tools-cut off saws, die grinders,
4" grinders, drills, right angle drills and others . Doesn't need to be
recharged and the "cable" is cheap. Really good for us steel boat types
who are forever grinding away rust (also can use an air powered needle
scaler). Russ Davignon S/C ASCENSION 44' Ted Brewer steel cutter.
