Hi,
There are a few things to consider when wiring a
series/parallel battery bank. The first is safety.
It may come to pass that one of the batteries
might develop a shorted cell. In that case HUGE
amounts of current would try to flow from the
non-shorted batteries into the shorted one.
The second is charging equality. This means
getting all the batteries an equal share of the
charging, and discharging currents.
Thus I have a few suggestions for setting up such
a system.
First ALL cables, regardless of length, need to
be as BIG as you can make them. Until you can't
bend them to make connections there is simply no
such thing as too thick a cable.
Second each series pair (12 volt combined
voltage) needs to be fused. This fuse needs to be
selected to allow any two of the three pairs to
provide all the current needed in the
installation.
Third the cables from each series pair to the
fuse, then on to the main junction (not the
distribution panel, a local point where the
batteries are all connected together) need to be
the same length, regardless of the distance to
each series pair. This holds true for both the
positive cables AND the negative (ground) cables.
Both the cables to the charger and to the
distribution panel also need to be connected to
these junction points.
If your charging system has remote voltage
sensing wires (please tell me it does?) these
wires should be connected to the ground (negative)
battery post of the battery at one end (physical
location) of the battery bank, the positive sense
wire should be connected to the positive post of
the battery at the other end (physical location)
of the battery bank.
Now that you have the negative battery posts all
connected at one point you can connect your
battery monitor's shunt to that point and then
from the other end of the shunt to your boat's
ground system.
Now you have wired your battery bank in such a
way as to allow for even charging, even power
usage, and the best chance of a long life for each
battery in the system.
Don't forget, charge your batteries often and
completely. The deeper you discharge a battery
bank before recharging the sooner that battery
bank will die. The more times you fail to charge
to 100% the faster sulfating will occur and the
sooner the battery bank will die.
Use smart chargers. Set them up correctly. Use
temperature sensors with that charging system to
compensate the charging voltages.
Again. There is NO SUCH THING as too thick a
battery cable!
Eric Thompson
S/V Procrastinator
South San Francisco
capteric36@sbcglobal.net
