I'm still learning about my newly installed Link 10 battery monitor. I've
read and reread the manual several times but can't decide about a couple of
the setup parameters. Can you other Link 10 owners advise me?
I think I want to set the low battery alarm so that it comes on at 50%
discharge instead of the default 80%. Is that a good idea? Any
disadvantages? I'd like to never run my house battery bank below 50% if
possible.
Similarly I think I'd like to set the "bar graph" so that it represents 50%
of battery capacity, not the default 100%. Does anyone else do this?
The model I bought has the external alarm circuit (which I have not yet
connected) so the alarm function will be important to me.
Finally I wonder if the battery temperature sensor is worth the $50 price.
Does the battery temperature make an important difference in the accuracy
and usefulness of the Link 10?
Thanks in advance
Jim Fidler "Fiddlesticks"
possible.
I've been using the Link for a number of years. Regarding the low battery
alarm, this is somewhat a function of how big your battery bank is and what
your average hourly useage is. If you don't want to discharge your
batteries below 50% (good idea!) then you might want to set the alarm at a
level far enough above the 50% point so that you can charge at your
convenience. I'd hate to have the 50% alarm go off at 2300 hrs. and be
forced to decide between a couple hours charging in the middle of the night
vs. pulling another 10-15% out of my batteries before morning. You might
want to decide just how late at night you'd be willing to start charging and
then based on your bank size and avg. useage set the alarm at a level that
notifies you to charge first thing in the morning...
50%
I leave mine at the 100% level but this is a matter of personal choice - I
think in terms of not letting the batteries go below 50% so I like to know
when they're approaching the 50% level.
Depends on where the Link is located vs. where you spend your time on the
boat. If it's mounted in the pilot house and you want to be able to hear it
below decks then wire an external alarm...
The temp sensor is only important if your batteries are located in an area
(like the engine room) where the temperature varies dramatically. If
they're located in an area where temp is a function of ambient air then it's
much less important - you can just set the temperature parameter seasonally.
This comment may be controversial since the optimal charging voltage is
highly temperture dependent but if you're not charging above the 85% level
then it becomes less important than if you're charging to the float stage
every time.
Ray B.
m/v MOJO
