Power supply for E-310
PJ
Prabhu Janakaraj
Thu, May 14, 2015 7:59 PM
Hi,
I am doing some mobile sensing stuff with E-310. So I am in need of using
portable power supply. Since the voltage rating id 5-15V, can I power it up
using the USB port?
Hi, I am doing some mobile sensing stuff with E-310. So I am in need of using portable power supply. Since the voltage rating id 5-15V, can I power it up using the USB port?
NP
Neel Pandeya
Thu, May 14, 2015 9:35 PM
Hello Prabhu Janakaraj:
No, the E310 cannot be run from USB bus power. It needs the external DC
power supply.
--Neel
On 14 May 2015 at 12:59, Prabhu Janakaraj via USRP-users <
Hi,
using the USB port?
USRP-users mailing list
USRP-users@lists.ettus.com
Hello Prabhu Janakaraj: No, the E310 cannot be run from USB bus power. It needs the external DC power supply. --Neel On 14 May 2015 at 12:59, Prabhu Janakaraj via USRP-users < usrp-users@lists.ettus.com> wrote: > Hi, > > > > I am doing some mobile sensing stuff with E-310. So I am in need of using > portable power supply. Since the voltage rating id 5-15V, can I power it up > using the USB port? > > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com > >
PJ
Prabhu Janakaraj
Thu, May 14, 2015 9:53 PM
What do you suggest for the using the device for mobile applications ?
Sent: Thursday, May 14, 2015 4:36 PM
To: Prabhu Janakaraj
Cc: usrp-users
Subject: Re: [USRP-users] Power supply for E-310
--Neel
On 14 May 2015 at 12:59, Prabhu Janakaraj via USRP-users <usrp-users@lists.ettus.com mailto:usrp-users@lists.ettus.com > wrote:
Hi,
USRP-users@lists.ettus.com mailto:USRP-users@lists.ettus.com
What do you suggest for the using the device for mobile applications ? From: Neel Pandeya [mailto:neel.pandeya@ettus.com] Sent: Thursday, May 14, 2015 4:36 PM To: Prabhu Janakaraj Cc: usrp-users Subject: Re: [USRP-users] Power supply for E-310 Hello Prabhu Janakaraj: No, the E310 cannot be run from USB bus power. It needs the external DC power supply. --Neel On 14 May 2015 at 12:59, Prabhu Janakaraj via USRP-users <usrp-users@lists.ettus.com <mailto:usrp-users@lists.ettus.com> > wrote: Hi, I am doing some mobile sensing stuff with E-310. So I am in need of using portable power supply. Since the voltage rating id 5-15V, can I power it up using the USB port? _______________________________________________ USRP-users mailing list USRP-users@lists.ettus.com <mailto:USRP-users@lists.ettus.com> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
NP
Neel Pandeya
Fri, May 15, 2015 3:37 PM
Later this year, sometime in the Fall, we will be releasing an E310 with an
internal battery, which would not need an external DC power supply. This
might be a good match for your mobile application. I can't provide any
specifications about the battery at the moment, but please feel free to
check back with me later this summer. I should be able to give you more
specific information then.
--Neel
Cc: usrp-users
power supply.
--Neel
Hi,
using the USB port?
Later this year, sometime in the Fall, we will be releasing an E310 with an internal battery, which would not need an external DC power supply. This might be a good match for your mobile application. I can't provide any specifications about the battery at the moment, but please feel free to check back with me later this summer. I should be able to give you more specific information then. --Neel On 14 May 2015 at 14:53, Prabhu Janakaraj <prabhu142003@gmail.com> wrote: > What do you suggest for the using the device for mobile applications ? > > > > > > > > *From:* Neel Pandeya [mailto:neel.pandeya@ettus.com] > *Sent:* Thursday, May 14, 2015 4:36 PM > *To:* Prabhu Janakaraj > *Cc:* usrp-users > *Subject:* Re: [USRP-users] Power supply for E-310 > > > > Hello Prabhu Janakaraj: > > No, the E310 cannot be run from USB bus power. It needs the external DC > power supply. > > --Neel > > > > On 14 May 2015 at 12:59, Prabhu Janakaraj via USRP-users < > usrp-users@lists.ettus.com> wrote: > > Hi, > > > > I am doing some mobile sensing stuff with E-310. So I am in need of using > portable power supply. Since the voltage rating id 5-15V, can I power it up > using the USB port? > > > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com > > >
