Anybody have service, schematics or experience for one of these OCXO?
They are commonly seen in early HP 8566A spectrum analysers.
It is out of adjustable range.
Fortunately I had a spare OSC 49-61C floating about and replaced this off frequency reference with it.
However the replacement tends to wander about a fair bit.
By removing the 4 bottom screws and the 2 top screws, applying a little heat with a heat gun around the bottom to melt the glue, the oven came apart with little protest.
I was able to carefully access the top 2 boards and there is no sign of component failure there so it maybe something inside the oven itself.
I have stopped here until I get further information.
-marki
Hi Mark,
I am not sure about the design of your OCXO but recently I repaired an
Ovenaire from a Cushman 5510 service monitor.
I found that there was a bad trimmer pot in the oven control circuit.
This wasn't apparent until I started monitoring the current drawn by the
unit while trying to adjust the trimmer pot. I found that if I barely
touched the adjustment screw, the current would vary greatly. The
temperature swing of the crystal made it impossible to adjust the
oscillator trimmer cap properly. These problems disappeared after I
replaced the trimmer pot.
To get the new pot to a reasonably close starting, I measured the
setting of the old one after I removed it and duplicated that on the new
one before installing it. I had to make an extra hole in the outer case
to access the pot adjustment. Although there was a hole in the internal
foam to access the pot, there was no corresponding one in the outer
can. I adjusted the pot for the minimal variation in oven current while
monitoring the output frequency for minimal frequency swing.
Now, based on observations conducted over a few days, the OCXO barely
wanders and I would guess is within what Cushman required at the time
the 5510 was built.
Good luck with yours.
Fred
-marki
Hi Fred, Also, I neglected to ask, you wouldn't have the OXCO pin outs would you?
-----Original Message-----
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Frederick Bray
Sent: Thursday, 13 June 2013 2:01 AM
To: time-nuts@febo.com
Subject: Re: [time-nuts] Ovenaire OSC 49-61C
Hi Mark,
I am not sure about the design of your OCXO but recently I repaired an Ovenaire from a Cushman 5510 service monitor.
This wasn't apparent until I started monitoring the current drawn by the unit while trying to adjust the trimmer pot. I found that if I barely touched the adjustment screw, the current would vary greatly. The temperature swing of the crystal made it impossible to adjust the oscillator trimmer cap properly. These problems disappeared after I replaced the trimmer pot.
To get the new pot to a reasonably close starting, I measured the setting of the old one after I removed it and duplicated that on the new one before installing it. I had to make an extra hole in the outer case to access the pot adjustment. Although there was a hole in the internal foam to access the pot, there was no corresponding one in the outer can. I adjusted the pot for the minimal variation in oven current while monitoring the output frequency for minimal frequency swing.
Now, based on observations conducted over a few days, the OCXO barely wanders and I would guess is within what Cushman required at the time the 5510 was built.
Fred
-marki
time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to
time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts
