Veronica was built in 1974. Her fuel tanks had never been opened up.
In 2008, we started to experience some problems. We couldn't tell if
it was bad, old fuel, some bad new fuel, a fuel feed problem or an
injector problem. First, I had designed, fabricated and built a fuel
polishing system. It appears overly complex, but with it I can run
the engine and genset, bleed the engine and genset, polish the fuel,
fill the fuel filters, and vacuum check every component in the fuel
system.
The polishing system helped, but did not cure the problem.
Fortunately, access to the tops of the fuel tanks is not that
difficult, if you are slender, young and flexible. Fortunately, one
of the experienced hands at the yard was. Lucky guy. We cut big
holes in the top of the tank, one over each bay (the volume between
the baffles) after we emptied the fuel tank. That was easy with the
fuel polishing system. I would advocate using a really long hose to a
receptacle ashore so as to keep diesel fuel smell out of the boat.
Once the tanks were opened and ventilated, we sucked the black grunge
off the bottom of the tank. I think it was just 35 years of bacterial
residue. The metal on the bottom was bright, no rust, validating
Willard's bottom feed approach. The one thing I did not do that I
wish I had, was to replace the fuel shutoff valve while the tank was
empty. There is a tiny weep, which went unnoticed until recently
which could have been easily cured while the tank was empty.
Again, this did not completely cure the fuel feed problem. The only
remaining culprit was the injection system.
Bob Salmons
Veronica
Willard 40 RPH
