I want to build my custom FPGA image but failed to get the license
이진세
Wed, Jul 26, 2017 12:55 AM
hello
I use e310 and try to build custom fpga image.
and i entered a trial license, including webPack, from Vivado License manager.
In the View License Status tab, the license named Synthesis and XC7Z020 is displayed.
However, i received error message saying that the license is not available.
this is error log about command 'sudo ./uhd_image_builder.py window fft -d e310 -t E310_RFNOC_sg3 -m 5 --fill-with-fifos'.
please tell me what is wrong.
thanks.
spade@spade-DREAMPRO:~/rfnoc/src/uhd-fpga/usrp3/tools/scripts$ sudo ./uhd_image_builder.py window fft -d e310 -t E310_RFNOC_sg3 -m 5 --fill-with-fifos
[sudo] password for spade:
--Using the following blocks to generate image:
* window
* fft
Adding CE instantiation file for 'E310_RFNOC_sg3'
changing temporarily working directory to /home/spade/rfnoc/src/uhd-fpga/usrp3/tools/scripts/../../top/e300
Setting up a 64-bit FPGA build environment for the USRP-E3x0...
  • Vivado: Found (/opt/Xilinx/Vivado/2015.4/bin)
  • Vivado HLS: Found (/opt/Xilinx/Vivado_HLS/2015.4/bin)
Environment successfully initialized.
make -f Makefile.e300.inc bin NAME=E310_RFNOC_sg3 ARCH=zynq PART_ID=xc7z020/clg484/-3 RFNOC=1 E310=1 EXTRA_DEFS="RFNOC=1 E310=1"
make[1]: Entering directory '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300'
BUILDER: Checking tools...
  • GNU bash, version 4.3.48(1)-release (x86_64-pc-linux-gnu)
  • Python 2.7.12
  • Vivado v2015.4 (64-bit)
BUILDER: Building IP axi_fft
BUILDER: Staging IP in build directory...
BUILDER: Reserving IP location: /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft
BUILDER: Retargeting IP to part zynq/xc7z020/clg484/-3...
BUILDER: Building IP...
****** Vivado v2015.4 (64-bit)
source /home/spade/rfnoc/src/uhd-fpga/usrp3/tools/scripts/viv_generate_ip.tcl
set xci_file        $::env(XCI_FILE)              ;
set part_name        $::env(PART_NAME)              ;
set gen_example_proj $::env(GEN_EXAMPLE)            ;
set synth_ip        $::env(SYNTH_IP)              ;
set ip_name [file rootname [file tail $xci_file]]  ;
file delete -force "$xci_file.out"
create_project -part $part_name -in_memory -ip
set_property target_simulator XSim [current_project]
add_files -norecurse -force $xci_file
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1704] No user IP repositories specified
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/opt/Xilinx/Vivado/2015.4/data/ip'.
reset_target all [get_files $xci_file]
puts "BUILDER: Generating IP Target..."
generate_target all [get_files $xci_file]
INFO: [IP_Flow 19-1686] Generating 'Instantiation Template' target for IP 'axi_fft'...
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'axi_fft'...
INFO: [Device 21-403] Loading part xc7z020clg484-3
INFO: [IP_Flow 19-1686] Generating 'Simulation' target for IP 'axi_fft'...
INFO: [IP_Flow 19-1686] Generating 'C Simulation' target for IP 'axi_fft'...
INFO: [IP_Flow 19-1686] Generating 'Test Bench' target for IP 'axi_fft'...
INFO: [IP_Flow 19-1686] Generating 'Change Log' target for IP 'axi_fft'...
generate_target: Time (s): cpu = 00:00:06 ; elapsed = 00:00:08 . Memory (MB): peak = 1134.184 ; gain = 162.906 ; free physical = 1258 ; free virtual = 6661
if [string match $synth_ip "1"] {
puts "BUILDER: Synthesizing IP Target..."
synth_ip [get_ips $ip_name]
Command: synth_design -top axi_fft -part xc7z020clg484-3 -mode out_of_context
Starting synth_design
Attempting to get a license for feature 'Synthesis' and/or device 'xc7z020'
WARNING: [Common 17-348] Failed to get the license for feature 'Synthesis' and/or device 'xc7z020'
1 Infos, 1 Warnings, 0 Critical Warnings and 1 Errors encountered.
synth_design failed
ERROR: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z020'. Please run the Vivado License Manager for assistance in determining
which features and devices are licensed for your system.
Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command.
ERROR: [Vivado 12-398] No designs are open
source /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/.Xil/Vivado-2801-spade-DREAMPRO/webtalk/labtool_webtalk.tcl -notrace
INFO: [Common 17-206] Exiting Webtalk at Wed Jul 26 09:38:41 2017...
INFO: [Vivado 12-3441] generate_netlist_ip - operation complete
if [string match $gen_example_proj "1"] {
puts "BUILDER: Generating Example Design..."
open_example_project -force -dir . [get_ips $ip_name]
close_project
if { [get_msg_config -count -severity ERROR] == 0 } {
# Write output cookie file
set outfile [open "$xci_file.out" w]
puts $outfile "This file was auto-generated by viv_generate_ip.tcl and signifies that IP generation is done."
close $outfile
} else {
exit 1
INFO: [Common 17-206] Exiting Vivado at Wed Jul 26 09:38:42 2017...
BUILDER: Releasing IP location: /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft
/home/spade/rfnoc/src/uhd-fpga/usrp3/lib/ip/axi_fft/Makefile.inc:15: recipe for target '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft/axi_fft.xci' failed
make[1]: *** [/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft/axi_fft.xci] Error 1
make[1]: Leaving directory '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300'
Makefile:56: recipe for target 'E310_RFNOC_sg3' failed
make: *** [E310_RFNOC_sg3] Error 2
hello I use e310 and try to build custom fpga image. and i entered a trial license, including webPack, from Vivado License manager. In the View License Status tab, the license named Synthesis and XC7Z020 is displayed. However, i received error message saying that the license is not available. this is error log about command 'sudo ./uhd_image_builder.py window fft -d e310 -t E310_RFNOC_sg3 -m 5 --fill-with-fifos'. please tell me what is wrong. thanks. spade@spade-DREAMPRO:~/rfnoc/src/uhd-fpga/usrp3/tools/scripts$ sudo ./uhd_image_builder.py window fft -d e310 -t E310_RFNOC_sg3 -m 5 --fill-with-fifos [sudo] password for spade: --Using the following blocks to generate image: * window * fft Adding CE instantiation file for 'E310_RFNOC_sg3' changing temporarily working directory to /home/spade/rfnoc/src/uhd-fpga/usrp3/tools/scripts/../../top/e300 Setting up a 64-bit FPGA build environment for the USRP-E3x0... - Vivado: Found (/opt/Xilinx/Vivado/2015.4/bin) - Vivado HLS: Found (/opt/Xilinx/Vivado_HLS/2015.4/bin) Environment successfully initialized. make -f Makefile.e300.inc bin NAME=E310_RFNOC_sg3 ARCH=zynq PART_ID=xc7z020/clg484/-3 RFNOC=1 E310=1 EXTRA_DEFS="RFNOC=1 E310=1" make[1]: Entering directory '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300' BUILDER: Checking tools... * GNU bash, version 4.3.48(1)-release (x86_64-pc-linux-gnu) * Python 2.7.12 * Vivado v2015.4 (64-bit) ======================================================== BUILDER: Building IP axi_fft ======================================================== BUILDER: Staging IP in build directory... BUILDER: Reserving IP location: /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft BUILDER: Retargeting IP to part zynq/xc7z020/clg484/-3... BUILDER: Building IP... ****** Vivado v2015.4 (64-bit) **** SW Build 1412921 on Wed Nov 18 09:44:32 MST 2015 **** IP Build 1412160 on Tue Nov 17 13:47:24 MST 2015 ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved. source /home/spade/rfnoc/src/uhd-fpga/usrp3/tools/scripts/viv_generate_ip.tcl # set xci_file $::env(XCI_FILE) ; # set part_name $::env(PART_NAME) ; # set gen_example_proj $::env(GEN_EXAMPLE) ; # set synth_ip $::env(SYNTH_IP) ; # set ip_name [file rootname [file tail $xci_file]] ; # file delete -force "$xci_file.out" # create_project -part $part_name -in_memory -ip # set_property target_simulator XSim [current_project] # add_files -norecurse -force $xci_file INFO: [IP_Flow 19-234] Refreshing IP repositories INFO: [IP_Flow 19-1704] No user IP repositories specified INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/opt/Xilinx/Vivado/2015.4/data/ip'. # reset_target all [get_files $xci_file] # puts "BUILDER: Generating IP Target..." BUILDER: Generating IP Target... # generate_target all [get_files $xci_file] INFO: [IP_Flow 19-1686] Generating 'Instantiation Template' target for IP 'axi_fft'... INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'axi_fft'... INFO: [Device 21-403] Loading part xc7z020clg484-3 INFO: [IP_Flow 19-1686] Generating 'Simulation' target for IP 'axi_fft'... INFO: [IP_Flow 19-1686] Generating 'C Simulation' target for IP 'axi_fft'... INFO: [IP_Flow 19-1686] Generating 'Test Bench' target for IP 'axi_fft'... INFO: [IP_Flow 19-1686] Generating 'Change Log' target for IP 'axi_fft'... generate_target: Time (s): cpu = 00:00:06 ; elapsed = 00:00:08 . Memory (MB): peak = 1134.184 ; gain = 162.906 ; free physical = 1258 ; free virtual = 6661 # if [string match $synth_ip "1"] { # puts "BUILDER: Synthesizing IP Target..." # synth_ip [get_ips $ip_name] # } BUILDER: Synthesizing IP Target... INFO: [IP_Flow 19-234] Refreshing IP repositories INFO: [IP_Flow 19-1704] No user IP repositories specified INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/opt/Xilinx/Vivado/2015.4/data/ip'. Command: synth_design -top axi_fft -part xc7z020clg484-3 -mode out_of_context Starting synth_design Attempting to get a license for feature 'Synthesis' and/or device 'xc7z020' WARNING: [Common 17-348] Failed to get the license for feature 'Synthesis' and/or device 'xc7z020' 1 Infos, 1 Warnings, 0 Critical Warnings and 1 Errors encountered. synth_design failed ERROR: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z020'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. ERROR: [Vivado 12-398] No designs are open ****** Webtalk v2015.4 (64-bit) **** SW Build 1412921 on Wed Nov 18 09:44:32 MST 2015 **** IP Build 1412160 on Tue Nov 17 13:47:24 MST 2015 ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved. source /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/.Xil/Vivado-2801-spade-DREAMPRO/webtalk/labtool_webtalk.tcl -notrace INFO: [Common 17-206] Exiting Webtalk at Wed Jul 26 09:38:41 2017... INFO: [Vivado 12-3441] generate_netlist_ip - operation complete # if [string match $gen_example_proj "1"] { # puts "BUILDER: Generating Example Design..." # open_example_project -force -dir . [get_ips $ip_name] # } # close_project # if { [get_msg_config -count -severity ERROR] == 0 } { # # Write output cookie file # set outfile [open "$xci_file.out" w] # puts $outfile "This file was auto-generated by viv_generate_ip.tcl and signifies that IP generation is done." # close $outfile # } else { # exit 1 # } INFO: [Common 17-206] Exiting Vivado at Wed Jul 26 09:38:42 2017... BUILDER: Releasing IP location: /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft /home/spade/rfnoc/src/uhd-fpga/usrp3/lib/ip/axi_fft/Makefile.inc:15: recipe for target '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft/axi_fft.xci' failed make[1]: *** [/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft/axi_fft.xci] Error 1 make[1]: Leaving directory '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300' Makefile:56: recipe for target 'E310_RFNOC_sg3' failed make: *** [E310_RFNOC_sg3] Error 2
NT
Nate Temple
Wed, Jul 26, 2017 1:06 AM
Hi,
Which OS and OS Version are you using?
Regards,
Nate
On Jul 25, 2017, at 5:55 PM, 이진세 via USRP-users usrp-users@lists.ettus.com wrote:
hello
thanks.
* window
* fft
  • Python 2.7.12
synth_design failed
close_project
close $outfile
} else {
exit 1
USRP-users mailing list
USRP-users@lists.ettus.com
Hi, Which OS and OS Version are you using? Regards, Nate > On Jul 25, 2017, at 5:55 PM, 이진세 via USRP-users <usrp-users@lists.ettus.com> wrote: > > hello > > I use e310 and try to build custom fpga image. > > and i entered a trial license, including webPack, from Vivado License manager. > > In the View License Status tab, the license named Synthesis and XC7Z020 is displayed. > > However, i received error message saying that the license is not available. > > this is error log about command 'sudo ./uhd_image_builder.py window fft -d e310 -t E310_RFNOC_sg3 -m 5 --fill-with-fifos'. > > please tell me what is wrong. > > thanks. > > > spade@spade-DREAMPRO:~/rfnoc/src/uhd-fpga/usrp3/tools/scripts$ sudo ./uhd_image_builder.py window fft -d e310 -t E310_RFNOC_sg3 -m 5 --fill-with-fifos > [sudo] password for spade: > --Using the following blocks to generate image: > * window > * fft > Adding CE instantiation file for 'E310_RFNOC_sg3' > changing temporarily working directory to /home/spade/rfnoc/src/uhd-fpga/usrp3/tools/scripts/../../top/e300 > Setting up a 64-bit FPGA build environment for the USRP-E3x0... > - Vivado: Found (/opt/Xilinx/Vivado/2015.4/bin) > - Vivado HLS: Found (/opt/Xilinx/Vivado_HLS/2015.4/bin) > > Environment successfully initialized. > make -f Makefile.e300.inc bin NAME=E310_RFNOC_sg3 ARCH=zynq PART_ID=xc7z020/clg484/-3 RFNOC=1 E310=1 EXTRA_DEFS="RFNOC=1 E310=1" > make[1]: Entering directory '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300' > BUILDER: Checking tools... > * GNU bash, version 4.3.48(1)-release (x86_64-pc-linux-gnu) > * Python 2.7.12 > * Vivado v2015.4 (64-bit) > ======================================================== > BUILDER: Building IP axi_fft > ======================================================== > BUILDER: Staging IP in build directory... > BUILDER: Reserving IP location: /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft > BUILDER: Retargeting IP to part zynq/xc7z020/clg484/-3... > BUILDER: Building IP... > > ****** Vivado v2015.4 (64-bit) > **** SW Build 1412921 on Wed Nov 18 09:44:32 MST 2015 > **** IP Build 1412160 on Tue Nov 17 13:47:24 MST 2015 > ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved. > > source /home/spade/rfnoc/src/uhd-fpga/usrp3/tools/scripts/viv_generate_ip.tcl > # set xci_file $::env(XCI_FILE) ; > # set part_name $::env(PART_NAME) ; > # set gen_example_proj $::env(GEN_EXAMPLE) ; > # set synth_ip $::env(SYNTH_IP) ; > # set ip_name [file rootname [file tail $xci_file]] ; > # file delete -force "$xci_file.out" > # create_project -part $part_name -in_memory -ip > # set_property target_simulator XSim [current_project] > # add_files -norecurse -force $xci_file > INFO: [IP_Flow 19-234] Refreshing IP repositories > INFO: [IP_Flow 19-1704] No user IP repositories specified > INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/opt/Xilinx/Vivado/2015.4/data/ip'. > # reset_target all [get_files $xci_file] > # puts "BUILDER: Generating IP Target..." > BUILDER: Generating IP Target... > # generate_target all [get_files $xci_file] > INFO: [IP_Flow 19-1686] Generating 'Instantiation Template' target for IP 'axi_fft'... > INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'axi_fft'... > INFO: [Device 21-403] Loading part xc7z020clg484-3 > INFO: [IP_Flow 19-1686] Generating 'Simulation' target for IP 'axi_fft'... > INFO: [IP_Flow 19-1686] Generating 'C Simulation' target for IP 'axi_fft'... > INFO: [IP_Flow 19-1686] Generating 'Test Bench' target for IP 'axi_fft'... > INFO: [IP_Flow 19-1686] Generating 'Change Log' target for IP 'axi_fft'... > generate_target: Time (s): cpu = 00:00:06 ; elapsed = 00:00:08 . Memory (MB): peak = 1134.184 ; gain = 162.906 ; free physical = 1258 ; free virtual = 6661 > # if [string match $synth_ip "1"] { > # puts "BUILDER: Synthesizing IP Target..." > # synth_ip [get_ips $ip_name] > # } > BUILDER: Synthesizing IP Target... > INFO: [IP_Flow 19-234] Refreshing IP repositories > INFO: [IP_Flow 19-1704] No user IP repositories specified > INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/opt/Xilinx/Vivado/2015.4/data/ip'. > Command: synth_design -top axi_fft -part xc7z020clg484-3 -mode out_of_context > Starting synth_design > Attempting to get a license for feature 'Synthesis' and/or device 'xc7z020' > WARNING: [Common 17-348] Failed to get the license for feature 'Synthesis' and/or device 'xc7z020' > 1 Infos, 1 Warnings, 0 Critical Warnings and 1 Errors encountered. > synth_design failed > ERROR: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z020'. Please run the Vivado License Manager for assistance in determining > which features and devices are licensed for your system. > Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". > ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. > ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. > ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. > ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. > ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. > ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. > ERROR: [Vivado 12-398] No designs are open > ****** Webtalk v2015.4 (64-bit) > **** SW Build 1412921 on Wed Nov 18 09:44:32 MST 2015 > **** IP Build 1412160 on Tue Nov 17 13:47:24 MST 2015 > ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved. > > source /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/.Xil/Vivado-2801-spade-DREAMPRO/webtalk/labtool_webtalk.tcl -notrace > INFO: [Common 17-206] Exiting Webtalk at Wed Jul 26 09:38:41 2017... > INFO: [Vivado 12-3441] generate_netlist_ip - operation complete > # if [string match $gen_example_proj "1"] { > # puts "BUILDER: Generating Example Design..." > # open_example_project -force -dir . [get_ips $ip_name] > # } > # close_project > # if { [get_msg_config -count -severity ERROR] == 0 } { > # # Write output cookie file > # set outfile [open "$xci_file.out" w] > # puts $outfile "This file was auto-generated by viv_generate_ip.tcl and signifies that IP generation is done." > # close $outfile > # } else { > # exit 1 > # } > INFO: [Common 17-206] Exiting Vivado at Wed Jul 26 09:38:42 2017... > BUILDER: Releasing IP location: /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft > /home/spade/rfnoc/src/uhd-fpga/usrp3/lib/ip/axi_fft/Makefile.inc:15: recipe for target '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft/axi_fft.xci' failed > make[1]: *** [/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft/axi_fft.xci] Error 1 > make[1]: Leaving directory '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300' > Makefile:56: recipe for target 'E310_RFNOC_sg3' failed > make: *** [E310_RFNOC_sg3] Error 2 > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
이진세
Wed, Jul 26, 2017 10:29 PM
Thank you for the reply.
I use Ubuntu 16.04 LTS
-----Original Message-----
To: "이진세"<ijinse1993@naver.com>;
Cc: <usrp-users@lists.ettus.com>;
Sent: 2017-07-26 (수) 10:06:47
Subject: Re: [USRP-users] I want to build my custom FPGA image but failed to get the license
Hi,
Regards,
Nate
>  hello
> thanks.
>    * window
>    * fft
> * Python 2.7.12
> synth_design failed
> # close_project
> #    close $outfile
> # } else {
> #    exit 1
Thank you for the reply. I use Ubuntu 16.04 LTS -----Original Message----- From: "Nate Temple"&lt;nate.temple@ettus.com&gt; To: "이진세"&lt;ijinse1993@naver.com&gt;; Cc: &lt;usrp-users@lists.ettus.com&gt;; Sent: 2017-07-26 (수) 10:06:47 Subject: Re: [USRP-users] I want to build my custom FPGA image but failed to get the license Hi, Which OS and OS Version are you using? Regards, Nate &gt; On Jul 25, 2017, at 5:55 PM, 이진세 via USRP-users &lt;usrp-users@lists.ettus.com&gt; wrote: &gt; &gt; hello &gt; &gt; I use e310 and try to build custom fpga image. &gt; &gt; and i entered a trial license, including webPack, from Vivado License manager. &gt; &gt; In the View License Status tab, the license named Synthesis and XC7Z020 is displayed. &gt; &gt; However, i received error message saying that the license is not available. &gt; &gt; this is error log about command 'sudo ./uhd_image_builder.py window fft -d e310 -t E310_RFNOC_sg3 -m 5 --fill-with-fifos'. &gt; &gt; please tell me what is wrong. &gt; &gt; thanks. &gt; &gt; &gt; spade@spade-DREAMPRO:~/rfnoc/src/uhd-fpga/usrp3/tools/scripts$ sudo ./uhd_image_builder.py window fft -d e310 -t E310_RFNOC_sg3 -m 5 --fill-with-fifos &gt; [sudo] password for spade: &gt; --Using the following blocks to generate image: &gt; * window &gt; * fft &gt; Adding CE instantiation file for 'E310_RFNOC_sg3' &gt; changing temporarily working directory to /home/spade/rfnoc/src/uhd-fpga/usrp3/tools/scripts/../../top/e300 &gt; Setting up a 64-bit FPGA build environment for the USRP-E3x0... &gt; - Vivado: Found (/opt/Xilinx/Vivado/2015.4/bin) &gt; - Vivado HLS: Found (/opt/Xilinx/Vivado_HLS/2015.4/bin) &gt; &gt; Environment successfully initialized. &gt; make -f Makefile.e300.inc bin NAME=E310_RFNOC_sg3 ARCH=zynq PART_ID=xc7z020/clg484/-3 RFNOC=1 E310=1 EXTRA_DEFS="RFNOC=1 E310=1" &gt; make[1]: Entering directory '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300' &gt; BUILDER: Checking tools... &gt; * GNU bash, version 4.3.48(1)-release (x86_64-pc-linux-gnu) &gt; * Python 2.7.12 &gt; * Vivado v2015.4 (64-bit) &gt; ======================================================== &gt; BUILDER: Building IP axi_fft &gt; ======================================================== &gt; BUILDER: Staging IP in build directory... &gt; BUILDER: Reserving IP location: /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft &gt; BUILDER: Retargeting IP to part zynq/xc7z020/clg484/-3... &gt; BUILDER: Building IP... &gt; &gt; ****** Vivado v2015.4 (64-bit) &gt; **** SW Build 1412921 on Wed Nov 18 09:44:32 MST 2015 &gt; **** IP Build 1412160 on Tue Nov 17 13:47:24 MST 2015 &gt; ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved. &gt; &gt; source /home/spade/rfnoc/src/uhd-fpga/usrp3/tools/scripts/viv_generate_ip.tcl &gt; # set xci_file $::env(XCI_FILE) ; &gt; # set part_name $::env(PART_NAME) ; &gt; # set gen_example_proj $::env(GEN_EXAMPLE) ; &gt; # set synth_ip $::env(SYNTH_IP) ; &gt; # set ip_name [file rootname [file tail $xci_file]] ; &gt; # file delete -force "$xci_file.out" &gt; # create_project -part $part_name -in_memory -ip &gt; # set_property target_simulator XSim [current_project] &gt; # add_files -norecurse -force $xci_file &gt; INFO: [IP_Flow 19-234] Refreshing IP repositories &gt; INFO: [IP_Flow 19-1704] No user IP repositories specified &gt; INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/opt/Xilinx/Vivado/2015.4/data/ip'. &gt; # reset_target all [get_files $xci_file] &gt; # puts "BUILDER: Generating IP Target..." &gt; BUILDER: Generating IP Target... &gt; # generate_target all [get_files $xci_file] &gt; INFO: [IP_Flow 19-1686] Generating 'Instantiation Template' target for IP 'axi_fft'... &gt; INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'axi_fft'... &gt; INFO: [Device 21-403] Loading part xc7z020clg484-3 &gt; INFO: [IP_Flow 19-1686] Generating 'Simulation' target for IP 'axi_fft'... &gt; INFO: [IP_Flow 19-1686] Generating 'C Simulation' target for IP 'axi_fft'... &gt; INFO: [IP_Flow 19-1686] Generating 'Test Bench' target for IP 'axi_fft'... &gt; INFO: [IP_Flow 19-1686] Generating 'Change Log' target for IP 'axi_fft'... &gt; generate_target: Time (s): cpu = 00:00:06 ; elapsed = 00:00:08 . Memory (MB): peak = 1134.184 ; gain = 162.906 ; free physical = 1258 ; free virtual = 6661 &gt; # if [string match $synth_ip "1"] { &gt; # puts "BUILDER: Synthesizing IP Target..." &gt; # synth_ip [get_ips $ip_name] &gt; # } &gt; BUILDER: Synthesizing IP Target... &gt; INFO: [IP_Flow 19-234] Refreshing IP repositories &gt; INFO: [IP_Flow 19-1704] No user IP repositories specified &gt; INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/opt/Xilinx/Vivado/2015.4/data/ip'. &gt; Command: synth_design -top axi_fft -part xc7z020clg484-3 -mode out_of_context &gt; Starting synth_design &gt; Attempting to get a license for feature 'Synthesis' and/or device 'xc7z020' &gt; WARNING: [Common 17-348] Failed to get the license for feature 'Synthesis' and/or device 'xc7z020' &gt; 1 Infos, 1 Warnings, 0 Critical Warnings and 1 Errors encountered. &gt; synth_design failed &gt; ERROR: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z020'. Please run the Vivado License Manager for assistance in determining &gt; which features and devices are licensed for your system. &gt; Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". &gt; ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. &gt; ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. &gt; ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. &gt; ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. &gt; ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. &gt; ERROR: [Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command. &gt; ERROR: [Vivado 12-398] No designs are open &gt; ****** Webtalk v2015.4 (64-bit) &gt; **** SW Build 1412921 on Wed Nov 18 09:44:32 MST 2015 &gt; **** IP Build 1412160 on Tue Nov 17 13:47:24 MST 2015 &gt; ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved. &gt; &gt; source /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/.Xil/Vivado-2801-spade-DREAMPRO/webtalk/labtool_webtalk.tcl -notrace &gt; INFO: [Common 17-206] Exiting Webtalk at Wed Jul 26 09:38:41 2017... &gt; INFO: [Vivado 12-3441] generate_netlist_ip - operation complete &gt; # if [string match $gen_example_proj "1"] { &gt; # puts "BUILDER: Generating Example Design..." &gt; # open_example_project -force -dir . [get_ips $ip_name] &gt; # } &gt; # close_project &gt; # if { [get_msg_config -count -severity ERROR] == 0 } { &gt; # # Write output cookie file &gt; # set outfile [open "$xci_file.out" w] &gt; # puts $outfile "This file was auto-generated by viv_generate_ip.tcl and signifies that IP generation is done." &gt; # close $outfile &gt; # } else { &gt; # exit 1 &gt; # } &gt; INFO: [Common 17-206] Exiting Vivado at Wed Jul 26 09:38:42 2017... &gt; BUILDER: Releasing IP location: /home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft &gt; /home/spade/rfnoc/src/uhd-fpga/usrp3/lib/ip/axi_fft/Makefile.inc:15: recipe for target '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft/axi_fft.xci' failed &gt; make[1]: *** [/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300/build-ip/xc7z020clg484-3/axi_fft/axi_fft.xci] Error 1 &gt; make[1]: Leaving directory '/home/spade/rfnoc/src/uhd-fpga/usrp3/top/e300' &gt; Makefile:56: recipe for target 'E310_RFNOC_sg3' failed &gt; make: *** [E310_RFNOC_sg3] Error 2 &gt; &gt; &gt; _______________________________________________ &gt; USRP-users mailing list &gt; USRP-users@lists.ettus.com &gt; http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
