Hello to the group. Numbers of threads running on the HP 10811. Mine is 45
Hz low. The oven is most likely ok. I did get the can open per the various
other threads and the web pix. Started testing the circuits and have found
that the regulator for the oscillator isn't. Its supposed to produce 5.7V
and is at 5.27V thats pretty significant. The transistor looks like a
shorted collector base junction. Though I do not have it out of circuit
yet. Its Q4 a 2n6429. What interesting about this transistor is its beta at
1 ma is 500 min and max is 1300. Its not a darlington. Thats pretty
amazing. I am looking through my xsistors to find something close. May just
through a 2n3904 in for a quick test. Its beta is nothing like the 6429.
But it would help to prove/disprove the point that the low V may be
offsetting the oscillator I hope.
Will also embed a K thermal couple to verify the oven really is in the
80-84C region.
Regards
Paul.
WB8TSL
Hi
The regulator should be fixed, and the OCXO will work better with it repaired. That said, shifting the regulated voltage from 5.7 to 5.27 volts should not shift that oscillator 45 Hz.
Bob
80-84C region.
Regards
Paul.
WB8TSL
I can hope
I will embed a k thermocouple also.
On Wed, Jul 24, 2013 at 7:45 PM, Bob Camp lists@rtty.us wrote:
Hi
Bob
45
various
found
at
just
80-84C region.
Regards
Paul.
WB8TSL
Well learned quite a bit Q4 does have an issue. Further there is a reason
it has such high Beta. Its must deliver 30 ma to the oscillator and buffer.
I was quite surprised by this current level. I was guessing the oscillator
was a few mils and the buffer maybe 8.
The 2n3904 simply does not cut it. Need to do some digging in the ole
transistors.
Regards
Paul.
On Wed, Jul 24, 2013 at 8:06 PM, paul swed paulswedb@gmail.com wrote:
I can hope
Hi
Bob
45
various
found
5.7V
beta at
just
80-84C region.
Regards
Paul.
WB8TSL
Sorry mate, this isn't much help, I haven't heave of any of these, must be before my time?!
Mat
Struct
Pc
Ucb
Uce
Ueb
Ic
Tj
Ft
Cc, pF
Hfe
Caps
2N6429http://alltransistors.com/transistor.php?transistor=5816
Si
NPN
0.625
55
45
6
0.2
175
100
3
400
TO92
NTE2341http://alltransistors.com/transistor.php?transistor=44370
Si
NPN
1
100
80
7
1
2000
TO92
NTE46http://alltransistors.com/transistor.php?transistor=44457
Si
NPN
0.625
100
100
12
0.5
10000
TO92
NTE48http://alltransistors.com/transistor.php?transistor=44458
Si
NPN
1
60
50
12
1
25000
TO92
SM2285http://alltransistors.com/transistor.php?transistor=45948
Si
NPN
1
0
100
0
0.2
200
150
600
TO92
STL73Dhttp://alltransistors.com/transistor.php?transistor=50901
Si
NPN
0
700
400
0
1.5
0
TO92
STX112http://alltransistors.com/transistor.php?transistor=50927
Si
NPN
0
100
100
0
2
1000
TO92
STX616http://alltransistors.com/transistor.php?transistor=50930
Si
NPN
0
980
500
0
1.5
0
TO92
-----Original Message-----
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of paul swed
Sent: Thursday, 25 July 2013 11:29 AM
To: Discussion of precise time and frequency measurement
Subject: Re: [time-nuts] HP 10811 update
Well learned quite a bit Q4 does have an issue. Further there is a reason it has such high Beta. Its must deliver 30 ma to the oscillator and buffer.
I was quite surprised by this current level. I was guessing the oscillator was a few mils and the buffer maybe 8.
The 2n3904 simply does not cut it. Need to do some digging in the ole transistors.
Regards
Paul.
On Wed, Jul 24, 2013 at 8:06 PM, paul swed <paulswedb@gmail.commailto:paulswedb@gmail.com> wrote:
I can hope
On Wed, Jul 24, 2013 at 7:45 PM, Bob Camp <lists@rtty.usmailto:lists@rtty.us> wrote:
Hi
Bob
On Jul 24, 2013, at 9:00 AM, paul swed <paulswedb@gmail.commailto:paulswedb@gmail.com> wrote:
Mine is
45
various
have
found
produce
5.7V
a shorted collector base junction. Though I do not have it out of
circuit yet. Its Q4 a 2n6429. What interesting about this
transistor is its
beta at
May
just
the 80-84C region.
Regards
Paul.
WB8TSL
time-nuts mailing list -- time-nuts@febo.commailto:time-nuts@febo.com To unsubscribe, go to
The 2N6429 crosses to an NTE123AP, in stock at Allied for $0.80.
http://www.alliedelec.com/search/productdetail.aspx?SKU=70214870&mkwid=szEc5
jMBI&pcrid=23468365337&pkw=nte123ap&pmt=e&pdv=c&gclid=CKyzu9_cybgCFWYV7AodJA
sAWQ
Good luck.
Joe
Behalf Of paul swed
Sent: Wednesday, July 24, 2013 8:29 PM
transistors.
Regards
Paul.
I can hope
Hi
Bob
Mine is
45
various
have
found
produce
5.7V
transistor is its
beta at
May
just
the 80-84C region.
Regards
Paul.
WB8TSL
time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to
I find it hard to believe that NTE spec the 123AP to replace a transistor
with min beta of 500...
This is quite entertaining:
http://www.vetco.net/catalog/product_info.php?products_id=1856
Look at the parts it's supposed to replace.
(Nothing against Vetco - they are a great source of NTE components and are
local to me. They are just quoting what NTE claim.)
Orin.
sAWQ
Good luck.
Joe
Behalf Of paul swed
it
transistors.
Regards
Paul.
I can hope
Hi
Bob
Mine is
45
various
have
found
produce
5.7V
transistor is its
beta at
May
just
the 80-84C region.
Regards
Paul.
WB8TSL
I totally agree that a 123 will not replace it. A luck would have it I have
12 X 2n3390 xsistors Beta 400-1000. These are the older TO-98s and I will
try one tonight.
Regards
Paul
WB8TSL
Orin.
sAWQ
Good luck.
Joe
Behalf Of paul swed
it
oscillator
transistors.
Regards
Paul.
I can hope
Hi
Bob
Mine is
45
various
have
found
produce
5.7V
transistor is its
beta at
May
just
the 80-84C region.
Regards
Paul.
WB8TSL
FYI, The MPSA18RLRAG is a stock item at Digi-Key, min beta 500 at 1 & 10mA, 45V & 200mA rated, TO-92. $0.33 each.
http://www.digikey.com/product-detail/en/MPSA18RLRAG/MPSA18RLRAGOSCT-ND/1139919
To: Discussion of precise time and frequency measurement time-nuts@febo.com
Sent: Wednesday, July 24, 2013 9:29 PM
transistors.
Regards
Paul.
Robert
I can't believe you found the transistor. When I pulled it out last night,
its actually a MPSA18!!! I had not had time to look it up but figured it
was a ebay leftover hunt. :-)
At that price I may order 20 of them. Like the gain.
Thanks.
On Thu, Jul 25, 2013 at 9:28 AM, Robert LaJeunesse <
buffer.
oscillator
transistors.
Regards
Paul.
