time-nuts@lists.febo.com
Re: [time-nuts] GPS Antennas
HM
Hal Murray
Fri, Sep 6, 2019 11:57 PM
The gotcha with putting anything on top of a GPS antenna is that it impacts
the phase  shift from the sat’s. How important that is gets quickly into just
how picky you happen to be.
How picky do I have to be before that is significant?  How geeky would I have
to be to measure it?
Would a hemispherical cover provide equal delays at all elevations?  I think
the solidly mounted USGS fault/volcano monitoring setups have a round top.
https://www.usgs.gov/media/images/gps-tracks-ground-deformation
Do any antenna manufacturers advertise uniform phase delay?
Do any software vendors advertise that their software works better with
specific antennas?
These are my opinions.  I hate spam.
kb8tq@n1k.org said: > The gotcha with putting anything on top of a GPS antenna is that it impacts > the phase shift from the sat’s. How important that is gets quickly into just > how picky you happen to be. How picky do I have to be before that is significant? How geeky would I have to be to measure it? Would a hemispherical cover provide equal delays at all elevations? I think the solidly mounted USGS fault/volcano monitoring setups have a round top. https://www.usgs.gov/media/images/gps-tracks-ground-deformation Do any antenna manufacturers advertise uniform phase delay? Do any software vendors advertise that their software works better with specific antennas? -- These are my opinions. I hate spam.
BK
Bob kb8tq
Sat, Sep 7, 2019 12:54 AM
Hi
Based on the papers I have seen, there is no “magic” shape that can be ignored.
Part of the issue is that the cover is going to be in the near field of the antenna.
As noted in another post, the impact is more complex than a simple delay. ( consider
that signals bounce off the cover material …. ).
Also consider that if I’m going to 3D print the device, I have a limited number of
materials available. Teflon isn’t going to run through a 3D printer. Unless you paint
the gizmo it will not be water tight so humidity will get into the act as well.
A “good” GPS antenna should have roughly the same phase center regardless of
the angle to the sat it’s receiving. Indeed GPS antennas in general get this right.
There is a modest variation with angle, but it’s not all that great. Units of mm are not
uncommon. It will be greater on a multi band design. The impact of your cover also
will be greater on a multi band device. All the various delay /. loss / reflection parameters
are frequency dependent…..
Bob
specific antennas?
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
Hi Based on the papers I have seen, there is no “magic” shape that can be ignored. Part of the issue is that the cover is going to be in the near field of the antenna. As noted in another post, the impact is more complex than a simple delay. ( consider that signals bounce off the cover material …. ). Also consider that if I’m going to 3D print the device, I have a limited number of materials available. Teflon isn’t going to run through a 3D printer. Unless you paint the gizmo it will not be water tight so humidity will get into the act as well. ===== A “good” GPS antenna should have roughly the same phase center regardless of the angle to the sat it’s receiving. Indeed GPS antennas in general get this right. There is a modest variation with angle, but it’s not all that great. Units of mm are not uncommon. It will be greater on a multi band design. The impact of your cover also will be greater on a multi band device. All the various delay /. loss / reflection parameters are frequency dependent….. Bob > On Sep 6, 2019, at 5:57 PM, Hal Murray <hmurray@megapathdsl.net> wrote: > > > kb8tq@n1k.org said: >> The gotcha with putting anything on top of a GPS antenna is that it impacts >> the phase shift from the sat’s. How important that is gets quickly into just >> how picky you happen to be. > > How picky do I have to be before that is significant? How geeky would I have > to be to measure it? > > Would a hemispherical cover provide equal delays at all elevations? I think > the solidly mounted USGS fault/volcano monitoring setups have a round top. > https://www.usgs.gov/media/images/gps-tracks-ground-deformation > > Do any antenna manufacturers advertise uniform phase delay? > Do any software vendors advertise that their software works better with > specific antennas? > > > > -- > These are my opinions. I hate spam. > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
B
Björn
Sat, Sep 7, 2019 6:50 AM
https://www.ngs.noaa.gov/ANTCAL/#
Look at say an old Ashtech ASH700936D_M which you can find calibrations for both SCIS and “Snow” radomes and without radome for the same antenna.
I have seen more recent radomes that are hemisphere-shaped. However these are more prone to be favored bird view points.
Radomes, like the Aeroantenna SPKE with a plastic “spike” to discourage birds are less ideal for super high accuracy applications due to its non uniform signal delay impact.
See also clear acrylic domes OSOD/OSOS
http://www.euref.eu/symposia/2015Leipzig/p-02-01-Ohlsson.pdf
https://kb.unavco.org/kb/article/unavco-resources-radomes-520.html
/Björn
Sent from my iPhone
On 7 Sep 2019, at 02:54, Bob kb8tq kb8tq@n1k.org wrote:
Hi
Bob
specific antennas?
https://www.ngs.noaa.gov/ANTCAL/# Look at say an old Ashtech ASH700936D_M which you can find calibrations for both SCIS and “Snow” radomes and without radome for the same antenna. I have seen more recent radomes that are hemisphere-shaped. However these are more prone to be favored bird view points. Radomes, like the Aeroantenna SPKE with a plastic “spike” to discourage birds are less ideal for super high accuracy applications due to its non uniform signal delay impact. See also clear acrylic domes OSOD/OSOS http://www.euref.eu/symposia/2015Leipzig/p-02-01-Ohlsson.pdf https://kb.unavco.org/kb/article/unavco-resources-radomes-520.html /Björn Sent from my iPhone > On 7 Sep 2019, at 02:54, Bob kb8tq <kb8tq@n1k.org> wrote: > > Hi > > Based on the papers I have seen, there is no “magic” shape that can be ignored. > Part of the issue is that the cover is going to be in the near field of the antenna. > As noted in another post, the impact is more complex than a simple delay. ( consider > that signals bounce off the cover material …. ). > > Also consider that if I’m going to 3D print the device, I have a limited number of > materials available. Teflon isn’t going to run through a 3D printer. Unless you paint > the gizmo it will not be water tight so humidity will get into the act as well. > > ===== > > A “good” GPS antenna should have roughly the same phase center regardless of > the angle to the sat it’s receiving. Indeed GPS antennas in general get this right. > There is a modest variation with angle, but it’s not all that great. Units of mm are not > uncommon. It will be greater on a multi band design. The impact of your cover also > will be greater on a multi band device. All the various delay /. loss / reflection parameters > are frequency dependent….. > > Bob > >> On Sep 6, 2019, at 5:57 PM, Hal Murray <hmurray@megapathdsl.net> wrote: >> >> >> kb8tq@n1k.org said: >>> The gotcha with putting anything on top of a GPS antenna is that it impacts >>> the phase shift from the sat’s. How important that is gets quickly into just >>> how picky you happen to be. >> >> How picky do I have to be before that is significant? How geeky would I have >> to be to measure it? >> >> Would a hemispherical cover provide equal delays at all elevations? I think >> the solidly mounted USGS fault/volcano monitoring setups have a round top. >> https://www.usgs.gov/media/images/gps-tracks-ground-deformation >> >> Do any antenna manufacturers advertise uniform phase delay? >> Do any software vendors advertise that their software works better with >> specific antennas? >> >> >> >> -- >> These are my opinions. I hate spam. >> >> >> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@lists.febo.com >> To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com >> and follow the instructions there. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
JC
John C. Westmoreland, P.E.
Sat, Sep 7, 2019 10:44 AM
To the OP, Dan,
Just curious - do you use something like this:
https://endruntechnologies.com/products/antennas-accessories/lightning-arrestor
Good luck with the new antenna.
73's,
John
AJ6BC
/Björn
Sent from my iPhone
Hi
ignored.
the antenna.
delay. ( consider
number of
Unless you paint
as well.
regardless of
this right.
Units of mm are not
cover also
Bob
impacts
into just
I have
think
top.
specific antennas?
To the OP, Dan, Just curious - do you use something like this: https://endruntechnologies.com/products/antennas-accessories/lightning-arrestor Good luck with the new antenna. 73's, John AJ6BC On Sat, Sep 7, 2019 at 3:17 AM Björn <bg@lysator.liu.se> wrote: > https://www.ngs.noaa.gov/ANTCAL/# > > Look at say an old Ashtech ASH700936D_M which you can find calibrations > for both SCIS and “Snow” radomes and without radome for the same antenna. > > I have seen more recent radomes that are hemisphere-shaped. However these > are more prone to be favored bird view points. > > Radomes, like the Aeroantenna SPKE with a plastic “spike” to discourage > birds are less ideal for super high accuracy applications due to its non > uniform signal delay impact. > > See also clear acrylic domes OSOD/OSOS > > http://www.euref.eu/symposia/2015Leipzig/p-02-01-Ohlsson.pdf > > https://kb.unavco.org/kb/article/unavco-resources-radomes-520.html > > /Björn > > Sent from my iPhone > > > On 7 Sep 2019, at 02:54, Bob kb8tq <kb8tq@n1k.org> wrote: > > > > Hi > > > > Based on the papers I have seen, there is no “magic” shape that can be > ignored. > > Part of the issue is that the cover is going to be in the near field of > the antenna. > > As noted in another post, the impact is more complex than a simple > delay. ( consider > > that signals bounce off the cover material …. ). > > > > Also consider that if I’m going to 3D print the device, I have a limited > number of > > materials available. Teflon isn’t going to run through a 3D printer. > Unless you paint > > the gizmo it will not be water tight so humidity will get into the act > as well. > > > > ===== > > > > A “good” GPS antenna should have roughly the same phase center > regardless of > > the angle to the sat it’s receiving. Indeed GPS antennas in general get > this right. > > There is a modest variation with angle, but it’s not all that great. > Units of mm are not > > uncommon. It will be greater on a multi band design. The impact of your > cover also > > will be greater on a multi band device. All the various delay /. loss / > reflection parameters > > are frequency dependent….. > > > > Bob > > > >> On Sep 6, 2019, at 5:57 PM, Hal Murray <hmurray@megapathdsl.net> wrote: > >> > >> > >> kb8tq@n1k.org said: > >>> The gotcha with putting anything on top of a GPS antenna is that it > impacts > >>> the phase shift from the sat’s. How important that is gets quickly > into just > >>> how picky you happen to be. > >> > >> How picky do I have to be before that is significant? How geeky would > I have > >> to be to measure it? > >> > >> Would a hemispherical cover provide equal delays at all elevations? I > think > >> the solidly mounted USGS fault/volcano monitoring setups have a round > top. > >> https://www.usgs.gov/media/images/gps-tracks-ground-deformation > >> > >> Do any antenna manufacturers advertise uniform phase delay? > >> Do any software vendors advertise that their software works better with > >> specific antennas? > >> > >> > >> > >> -- > >> These are my opinions. I hate spam. > >> > >> > >> > >> > >> _______________________________________________ > >> time-nuts mailing list -- time-nuts@lists.febo.com > >> To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > >> and follow the instructions there. > > > > > > _______________________________________________ > > time-nuts mailing list -- time-nuts@lists.febo.com > > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > > and follow the instructions there. > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. >
