B210 and Simulink sample times
MM
Mihkel M
Wed, Apr 26, 2017 10:25 AM
Hello!
I am trying to generate GPS signals with USRP B210 SDR. I have made a source "from workspace" where are values ones and zeros. There are 30690000 values, with sample time 1/1023000, which is the GPS L1 signal rate (1,023 MHz). Next block is "ideal rectangular pulse filter" with Pulse Length=4, which i have left in from examples i have found online( i'm not sure, if i really need this). Next block is BPSK modulator baseband with default settings. Next block is "Buffer" with size 1000 and final block is "SDRu Transmitter", with Fc-1575.42e6 Hz, LO offset-0 Hz, Gain-5 dB, Master Clock Rate- 20.95104e6 Hz, Interpolation- 512 and everything else is default.
When i run the model, my GPS evaluation software (U-center) receives gibberish. Intermittent signal and pseudo satellites. Occasionally, it finds the satellite code, which i generate. (In the source block there is PRN #01 and NavData for 30 seconds)
My question is, that why my simulation transmits such gibberish signal? As far as i have searched for this answer, the problem should be with mismatching sample rates? Anyone could explain me, how the DSP and SDR Tx sample times are related? How should i configure them? Also i have issues with running the simulation in real time, as i need to acquire the generated signal with u-center, where it should "see" legit GPS satellite information.
Mihkel.
Hello! I am trying to generate GPS signals with USRP B210 SDR. I have made a source "from workspace" where are values ones and zeros. There are 30690000 values, with sample time 1/1023000, which is the GPS L1 signal rate (1,023 MHz). Next block is "ideal rectangular pulse filter" with Pulse Length=4, which i have left in from examples i have found online( i'm not sure, if i really need this). Next block is BPSK modulator baseband with default settings. Next block is "Buffer" with size 1000 and final block is "SDRu Transmitter", with Fc-1575.42e6 Hz, LO offset-0 Hz, Gain-5 dB, Master Clock Rate- 20.95104e6 Hz, Interpolation- 512 and everything else is default. When i run the model, my GPS evaluation software (U-center) receives gibberish. Intermittent signal and pseudo satellites. Occasionally, it finds the satellite code, which i generate. (In the source block there is PRN #01 and NavData for 30 seconds) My question is, that why my simulation transmits such gibberish signal? As far as i have searched for this answer, the problem should be with mismatching sample rates? Anyone could explain me, how the DSP and SDR Tx sample times are related? How should i configure them? Also i have issues with running the simulation in real time, as i need to acquire the generated signal with u-center, where it should "see" legit GPS satellite information. Mihkel.
MM
Marcus Müller
Wed, Apr 26, 2017 6:04 PM
Hi Mihkel,
don't know Simulink overly well, but "ideal rectangular pulse filter"
sounds like a moving average – and that would completely destroy your data.
So, I don't think this is going to work. Not sure you need an extra
"buffer" block.
Best regards,
Marcus
On 04/26/2017 12:25 PM, Mihkel M via USRP-users wrote:
Hello!
Mihkel.
USRP-users mailing list
USRP-users@lists.ettus.com
Hi Mihkel, don't know Simulink overly well, but "ideal rectangular pulse filter" sounds like a moving average – and that would completely destroy your data. So, I don't think this is going to work. Not sure you need an extra "buffer" block. Best regards, Marcus On 04/26/2017 12:25 PM, Mihkel M via USRP-users wrote: > > Hello! > > > I am trying to generate GPS signals with USRP B210 SDR. I have made a > source "from workspace" where are values ones and zeros. There are > 30690000 values, with sample time 1/1023000, which is the GPS L1 > signal rate (1,023 MHz). Next block is "ideal rectangular pulse > filter" with Pulse Length=4, which i have left in from examples i have > found online( i'm not sure, if i really need this). Next block is BPSK > modulator baseband with default settings. Next block is "Buffer" with > size 1000 and final block is "SDRu Transmitter", with Fc-1575.42e6 Hz, > LO offset-0 Hz, Gain-5 dB, Master Clock Rate- 20.95104e6 Hz, > Interpolation- 512 and everything else is default. > > > When i run the model, my GPS evaluation software (U-center) receives > gibberish. Intermittent signal and pseudo satellites. Occasionally, it > finds the satellite code, which i generate. (In the source block there > is PRN #01 and NavData for 30 seconds) > > > My question is, that why my simulation transmits such gibberish > signal? As far as i have searched for this answer, the problem should > be with mismatching sample rates? Anyone could explain me, how the DSP > and SDR Tx sample times are related? How should i configure them? Also > i have issues with running the simulation in real time, as i need to > acquire the generated signal with u-center, where it should "see" > legit GPS satellite information. > > > Mihkel. > > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
MM
Mike McLernon
Wed, Apr 26, 2017 6:23 PM
Hi Mihkel,
I can confirm Marcus' suspicions.  The rectangular pulse filter will destroy your data.
The BPSK modulator block needs binary (0/1) input.
Hth,
Mike
From: USRP-users [mailto:usrp-users-bounces@lists.ettus.com] On Behalf Of Marcus Müller via USRP-users
Sent: Wednesday, April 26, 2017 2:04 PM
To: usrp-users@lists.ettus.com
Subject: Re: [USRP-users] B210 and Simulink sample times
Hi Mihkel,
don't know Simulink overly well, but "ideal rectangular pulse filter" sounds like a moving average - and that would completely destroy your data.
Best regards,
Marcus
Hello!
Mihkel.
USRP-users@lists.ettus.commailto:USRP-users@lists.ettus.com
Hi Mihkel, I can confirm Marcus' suspicions. The rectangular pulse filter will destroy your data. The BPSK modulator block needs binary (0/1) input. Hth, Mike From: USRP-users [mailto:usrp-users-bounces@lists.ettus.com] On Behalf Of Marcus Müller via USRP-users Sent: Wednesday, April 26, 2017 2:04 PM To: usrp-users@lists.ettus.com Subject: Re: [USRP-users] B210 and Simulink sample times Hi Mihkel, don't know Simulink overly well, but "ideal rectangular pulse filter" sounds like a moving average - and that would completely destroy your data. So, I don't think this is going to work. Not sure you need an extra "buffer" block. Best regards, Marcus On 04/26/2017 12:25 PM, Mihkel M via USRP-users wrote: Hello! I am trying to generate GPS signals with USRP B210 SDR. I have made a source "from workspace" where are values ones and zeros. There are 30690000 values, with sample time 1/1023000, which is the GPS L1 signal rate (1,023 MHz). Next block is "ideal rectangular pulse filter" with Pulse Length=4, which i have left in from examples i have found online( i'm not sure, if i really need this). Next block is BPSK modulator baseband with default settings. Next block is "Buffer" with size 1000 and final block is "SDRu Transmitter", with Fc-1575.42e6 Hz, LO offset-0 Hz, Gain-5 dB, Master Clock Rate- 20.95104e6 Hz, Interpolation- 512 and everything else is default. When i run the model, my GPS evaluation software (U-center) receives gibberish. Intermittent signal and pseudo satellites. Occasionally, it finds the satellite code, which i generate. (In the source block there is PRN #01 and NavData for 30 seconds) My question is, that why my simulation transmits such gibberish signal? As far as i have searched for this answer, the problem should be with mismatching sample rates? Anyone could explain me, how the DSP and SDR Tx sample times are related? How should i configure them? Also i have issues with running the simulation in real time, as i need to acquire the generated signal with u-center, where it should "see" legit GPS satellite information. Mihkel. _______________________________________________ USRP-users mailing list USRP-users@lists.ettus.com<mailto:USRP-users@lists.ettus.com> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
