time-nuts@lists.febo.com
WWVB remodulator for the spectracom 8170 the schematic is to large
PS
paul swed
Sun, Jun 16, 2013 9:43 PM
OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post
to a sight or two. Can include some pictures also.
Operation is simple the msa 6180 receives wwvb and in my case I tap off of
a wwvb antenna multi-coupler.
Output of the 8160 controls inverters that select a 60 Khz clock signal to
select high amplitude or low amplitude for the bit.
The 60 Khz clock uses another 60 Khz xtal from mouser or digikey.
The system consistently allows the Spectracom 8170 to work. Also my fear of
delay due to this processing is unfounded.
Compareing the wwv audio ticks and tones to the 8170 display I can't tell
the difference. Good enough as they say.
No attempt has been made to filter or shape the cmos output. The 8170
filters do a fine job.
Use a low power regulator to drop the 8170s antenna voltage to 5 volts. The
system draws 13 ma.
Other comments you could use a ferrite rod as the app note states. Or you
could feed power to the old spectracom antenna and use it. Essentially the
remodulator sits in the middle of the coax. This project assembled in a few
hours yesterday. The hardest part is soldering the pesky 16 pin soic to an
expander board.
The 8160 chip is available in the US through a distributor. But really not
sure how thats going to work out.
Literally any wwvb clock chip should be able to do this job. But no one
seems to sell them any more.
Hopefully the schematic will get through to the Time-nuts.
As always no intent to kit anything.
Regards
Paul
WB8TSL
OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post to a sight or two. Can include some pictures also. Operation is simple the msa 6180 receives wwvb and in my case I tap off of a wwvb antenna multi-coupler. Output of the 8160 controls inverters that select a 60 Khz clock signal to select high amplitude or low amplitude for the bit. The 60 Khz clock uses another 60 Khz xtal from mouser or digikey. The system consistently allows the Spectracom 8170 to work. Also my fear of delay due to this processing is unfounded. Compareing the wwv audio ticks and tones to the 8170 display I can't tell the difference. Good enough as they say. No attempt has been made to filter or shape the cmos output. The 8170 filters do a fine job. Use a low power regulator to drop the 8170s antenna voltage to 5 volts. The system draws 13 ma. Other comments you could use a ferrite rod as the app note states. Or you could feed power to the old spectracom antenna and use it. Essentially the remodulator sits in the middle of the coax. This project assembled in a few hours yesterday. The hardest part is soldering the pesky 16 pin soic to an expander board. The 8160 chip is available in the US through a distributor. But really not sure how thats going to work out. Literally any wwvb clock chip should be able to do this job. But no one seems to sell them any more. Hopefully the schematic will get through to the Time-nuts. As always no intent to kit anything. Regards Paul WB8TSL
BC
Bob Camp
Sun, Jun 16, 2013 10:19 PM
Hi
MSA 6180 or MSA 8160 or ….
Bob
6180
8160
system draws 13 ma.
expander board.
8160
Regards
Paul
WB8TSL
Hi MSA 6180 or MSA 8160 or …. Bob On Jun 16, 2013, at 5:43 PM, paul swed <paulswedb@gmail.com> wrote: > OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post > to a sight or two. Can include some pictures also. > Operation is simple the msa 6180 receives wwvb and in my case I tap off of 6180 > a wwvb antenna multi-coupler. > Output of the 8160 controls inverters that select a 60 Khz clock signal to 8160 > select high amplitude or low amplitude for the bit. > The 60 Khz clock uses another 60 Khz xtal from mouser or digikey. > The system consistently allows the Spectracom 8170 to work. Also my fear of > delay due to this processing is unfounded. > Compareing the wwv audio ticks and tones to the 8170 display I can't tell > the difference. Good enough as they say. > No attempt has been made to filter or shape the cmos output. The 8170 > filters do a fine job. > Use a low power regulator to drop the 8170s antenna voltage to 5 volts. The > system draws 13 ma. > > Other comments you could use a ferrite rod as the app note states. Or you > could feed power to the old spectracom antenna and use it. Essentially the > remodulator sits in the middle of the coax. This project assembled in a few > hours yesterday. The hardest part is soldering the pesky 16 pin soic to an > expander board. > The 8160 chip is available in the US through a distributor. But really not 8160 > sure how thats going to work out. > Literally any wwvb clock chip should be able to do this job. But no one > seems to sell them any more. > Hopefully the schematic will get through to the Time-nuts. > As always no intent to kit anything. > Regards > Paul > WB8TSL > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
PS
paul swed
Sun, Jun 16, 2013 10:39 PM
Good catch Bob 6180.
Thanks
Paul
On Sun, Jun 16, 2013 at 6:19 PM, Bob Camp lists@rtty.us wrote:
Hi
Bob
of
6180
to
8160
of
The
system draws 13 ma.
the
few
an
expander board.
not
8160
Regards
Paul
WB8TSL
Good catch Bob 6180. Thanks Paul On Sun, Jun 16, 2013 at 6:19 PM, Bob Camp <lists@rtty.us> wrote: > Hi > > MSA 6180 or MSA 8160 or …. > > Bob > > On Jun 16, 2013, at 5:43 PM, paul swed <paulswedb@gmail.com> wrote: > > > OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post > > to a sight or two. Can include some pictures also. > > Operation is simple the msa 6180 receives wwvb and in my case I tap off > of > > 6180 > > > a wwvb antenna multi-coupler. > > Output of the 8160 controls inverters that select a 60 Khz clock signal > to > > 8160 > > > select high amplitude or low amplitude for the bit. > > The 60 Khz clock uses another 60 Khz xtal from mouser or digikey. > > The system consistently allows the Spectracom 8170 to work. Also my fear > of > > delay due to this processing is unfounded. > > Compareing the wwv audio ticks and tones to the 8170 display I can't tell > > the difference. Good enough as they say. > > No attempt has been made to filter or shape the cmos output. The 8170 > > filters do a fine job. > > Use a low power regulator to drop the 8170s antenna voltage to 5 volts. > The > > system draws 13 ma. > > > > Other comments you could use a ferrite rod as the app note states. Or you > > could feed power to the old spectracom antenna and use it. Essentially > the > > remodulator sits in the middle of the coax. This project assembled in a > few > > hours yesterday. The hardest part is soldering the pesky 16 pin soic to > an > > expander board. > > The 8160 chip is available in the US through a distributor. But really > not > > 8160 > > > sure how thats going to work out. > > Literally any wwvb clock chip should be able to do this job. But no one > > seems to sell them any more. > > Hopefully the schematic will get through to the Time-nuts. > > As always no intent to kit anything. > > Regards > > Paul > > WB8TSL > > _______________________________________________ > > time-nuts mailing list -- time-nuts@febo.com > > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
BC
Bob Camp
Sun, Jun 16, 2013 11:20 PM
Hi
It's been at least 10 minutes since I've made a similar mistake on the list ….
Bob
Thanks
Paul
Hi
Bob
of
6180
to
8160
of
The
system draws 13 ma.
the
few
an
expander board.
not
8160
Regards
Paul
WB8TSL
Hi It's been at least 10 minutes since I've made a similar mistake on the list …. Bob On Jun 16, 2013, at 6:39 PM, paul swed <paulswedb@gmail.com> wrote: > Good catch Bob 6180. > Thanks > Paul > > > On Sun, Jun 16, 2013 at 6:19 PM, Bob Camp <lists@rtty.us> wrote: > >> Hi >> >> MSA 6180 or MSA 8160 or …. >> >> Bob >> >> On Jun 16, 2013, at 5:43 PM, paul swed <paulswedb@gmail.com> wrote: >> >>> OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post >>> to a sight or two. Can include some pictures also. >>> Operation is simple the msa 6180 receives wwvb and in my case I tap off >> of >> >> 6180 >> >>> a wwvb antenna multi-coupler. >>> Output of the 8160 controls inverters that select a 60 Khz clock signal >> to >> >> 8160 >> >>> select high amplitude or low amplitude for the bit. >>> The 60 Khz clock uses another 60 Khz xtal from mouser or digikey. >>> The system consistently allows the Spectracom 8170 to work. Also my fear >> of >>> delay due to this processing is unfounded. >>> Compareing the wwv audio ticks and tones to the 8170 display I can't tell >>> the difference. Good enough as they say. >>> No attempt has been made to filter or shape the cmos output. The 8170 >>> filters do a fine job. >>> Use a low power regulator to drop the 8170s antenna voltage to 5 volts. >> The >>> system draws 13 ma. >>> >>> Other comments you could use a ferrite rod as the app note states. Or you >>> could feed power to the old spectracom antenna and use it. Essentially >> the >>> remodulator sits in the middle of the coax. This project assembled in a >> few >>> hours yesterday. The hardest part is soldering the pesky 16 pin soic to >> an >>> expander board. >>> The 8160 chip is available in the US through a distributor. But really >> not >> >> 8160 >> >>> sure how thats going to work out. >>> Literally any wwvb clock chip should be able to do this job. But no one >>> seems to sell them any more. >>> Hopefully the schematic will get through to the Time-nuts. >>> As always no intent to kit anything. >>> Regards >>> Paul >>> WB8TSL >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@febo.com >>> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >>> and follow the instructions there. >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
BC
Bob Camp
Sun, Jun 16, 2013 11:35 PM
Hi
Next in on the same line … MSA or MAS?
I assume it's:
http://www.mas-oy.com/products/radio-controlled-clock-rcc/mas6180/
Which would make it a MAS 6180 or it's dual band relative the MAS6181
Bob
Thanks
Paul
Hi
Bob
of
6180
to
8160
of
The
system draws 13 ma.
the
few
an
expander board.
not
8160
Regards
Paul
WB8TSL
Hi Next in on the same line … MSA or MAS? I assume it's: http://www.mas-oy.com/products/radio-controlled-clock-rcc/mas6180/ Which would make it a MAS 6180 or it's dual band relative the MAS6181 Bob On Jun 16, 2013, at 6:39 PM, paul swed <paulswedb@gmail.com> wrote: > Good catch Bob 6180. > Thanks > Paul > > > On Sun, Jun 16, 2013 at 6:19 PM, Bob Camp <lists@rtty.us> wrote: > >> Hi >> >> MSA 6180 or MSA 8160 or …. >> >> Bob >> >> On Jun 16, 2013, at 5:43 PM, paul swed <paulswedb@gmail.com> wrote: >> >>> OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post >>> to a sight or two. Can include some pictures also. >>> Operation is simple the msa 6180 receives wwvb and in my case I tap off >> of >> >> 6180 >> >>> a wwvb antenna multi-coupler. >>> Output of the 8160 controls inverters that select a 60 Khz clock signal >> to >> >> 8160 >> >>> select high amplitude or low amplitude for the bit. >>> The 60 Khz clock uses another 60 Khz xtal from mouser or digikey. >>> The system consistently allows the Spectracom 8170 to work. Also my fear >> of >>> delay due to this processing is unfounded. >>> Compareing the wwv audio ticks and tones to the 8170 display I can't tell >>> the difference. Good enough as they say. >>> No attempt has been made to filter or shape the cmos output. The 8170 >>> filters do a fine job. >>> Use a low power regulator to drop the 8170s antenna voltage to 5 volts. >> The >>> system draws 13 ma. >>> >>> Other comments you could use a ferrite rod as the app note states. Or you >>> could feed power to the old spectracom antenna and use it. Essentially >> the >>> remodulator sits in the middle of the coax. This project assembled in a >> few >>> hours yesterday. The hardest part is soldering the pesky 16 pin soic to >> an >>> expander board. >>> The 8160 chip is available in the US through a distributor. But really >> not >> >> 8160 >> >>> sure how thats going to work out. >>> Literally any wwvb clock chip should be able to do this job. But no one >>> seems to sell them any more. >>> Hopefully the schematic will get through to the Time-nuts. >>> As always no intent to kit anything. >>> Regards >>> Paul >>> WB8TSL >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@febo.com >>> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >>> and follow the instructions there. >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
PS
paul swed
Mon, Jun 17, 2013 12:22 AM
Yes it is I would have sent the pdf but thats larger than 125 KB limit for
time nuts.
Regards
Paul.
On Sun, Jun 16, 2013 at 7:35 PM, Bob Camp lists@rtty.us wrote:
Hi
I assume it's:
Bob
Thanks
Paul
Hi
Bob
post
of
6180
to
8160
fear
of
tell
The
system draws 13 ma.
you
the
few
an
expander board.
not
8160
Regards
Paul
WB8TSL
Yes it is I would have sent the pdf but thats larger than 125 KB limit for time nuts. Regards Paul. On Sun, Jun 16, 2013 at 7:35 PM, Bob Camp <lists@rtty.us> wrote: > Hi > > Next in on the same line … MSA or MAS? > > I assume it's: > > http://www.mas-oy.com/products/radio-controlled-clock-rcc/mas6180/ > > Which would make it a MAS 6180 or it's dual band relative the MAS6181 > > Bob > > > On Jun 16, 2013, at 6:39 PM, paul swed <paulswedb@gmail.com> wrote: > > > Good catch Bob 6180. > > Thanks > > Paul > > > > > > On Sun, Jun 16, 2013 at 6:19 PM, Bob Camp <lists@rtty.us> wrote: > > > >> Hi > >> > >> MSA 6180 or MSA 8160 or …. > >> > >> Bob > >> > >> On Jun 16, 2013, at 5:43 PM, paul swed <paulswedb@gmail.com> wrote: > >> > >>> OK no schematic. It was 2MB. But it was a scan of my notes. Happy to > post > >>> to a sight or two. Can include some pictures also. > >>> Operation is simple the msa 6180 receives wwvb and in my case I tap off > >> of > >> > >> 6180 > >> > >>> a wwvb antenna multi-coupler. > >>> Output of the 8160 controls inverters that select a 60 Khz clock signal > >> to > >> > >> 8160 > >> > >>> select high amplitude or low amplitude for the bit. > >>> The 60 Khz clock uses another 60 Khz xtal from mouser or digikey. > >>> The system consistently allows the Spectracom 8170 to work. Also my > fear > >> of > >>> delay due to this processing is unfounded. > >>> Compareing the wwv audio ticks and tones to the 8170 display I can't > tell > >>> the difference. Good enough as they say. > >>> No attempt has been made to filter or shape the cmos output. The 8170 > >>> filters do a fine job. > >>> Use a low power regulator to drop the 8170s antenna voltage to 5 volts. > >> The > >>> system draws 13 ma. > >>> > >>> Other comments you could use a ferrite rod as the app note states. Or > you > >>> could feed power to the old spectracom antenna and use it. Essentially > >> the > >>> remodulator sits in the middle of the coax. This project assembled in a > >> few > >>> hours yesterday. The hardest part is soldering the pesky 16 pin soic to > >> an > >>> expander board. > >>> The 8160 chip is available in the US through a distributor. But really > >> not > >> > >> 8160 > >> > >>> sure how thats going to work out. > >>> Literally any wwvb clock chip should be able to do this job. But no one > >>> seems to sell them any more. > >>> Hopefully the schematic will get through to the Time-nuts. > >>> As always no intent to kit anything. > >>> Regards > >>> Paul > >>> WB8TSL > >>> _______________________________________________ > >>> time-nuts mailing list -- time-nuts@febo.com > >>> To unsubscribe, go to > >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > >>> and follow the instructions there. > >> > >> _______________________________________________ > >> time-nuts mailing list -- time-nuts@febo.com > >> To unsubscribe, go to > >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > >> and follow the instructions there. > >> > > _______________________________________________ > > time-nuts mailing list -- time-nuts@febo.com > > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
MS
Majdi S. Abbas
Mon, Jun 17, 2013 12:24 AM
There's a copy here for those that are interested:
https://latt.net/wwvb%20remodulator%20spectracom%208170.jpg
Majdi
On Sun, Jun 16, 2013 at 05:43:18PM -0400, paul swed wrote: > OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post > to a sight or two. Can include some pictures also. There's a copy here for those that are interested: https://latt.net/wwvb%20remodulator%20spectracom%208170.jpg Majdi
BC
Bob Camp
Mon, Jun 17, 2013 12:51 AM
Hi
You could get rid of the inverter and nand gate by using an XOR (74HC86) gate. You'd save at least 5 cents ….
Bob
Majdi
Hi You could get rid of the inverter and nand gate by using an XOR (74HC86) gate. You'd save at least 5 cents …. Bob On Jun 16, 2013, at 8:24 PM, "Majdi S. Abbas" <msa@latt.net> wrote: > On Sun, Jun 16, 2013 at 05:43:18PM -0400, paul swed wrote: >> OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post >> to a sight or two. Can include some pictures also. > > There's a copy here for those that are interested: > > https://latt.net/wwvb%20remodulator%20spectracom%208170.jpg > > Majdi > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
KJ
ken johnson
Mon, Jun 17, 2013 1:08 AM
Also now on my web site,
http://www.vk7krj.com/ham_stuff.htm
at the bottom of the page, along with some other time-nut type files.
And, once again, if anyone has any other time-nut files they would like to
see hosted on a web page, I am happy to oblige. Just email me.
     Majdi
Also now on my web site, http://www.vk7krj.com/ham_stuff.htm at the bottom of the page, along with some other time-nut type files. And, once again, if anyone has any other time-nut files they would like to see hosted on a web page, I am happy to oblige. Just email me. On Mon, Jun 17, 2013 at 10:24 AM, Majdi S. Abbas <msa@latt.net> wrote: > On Sun, Jun 16, 2013 at 05:43:18PM -0400, paul swed wrote: > > OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post > > to a sight or two. Can include some pictures also. > > There's a copy here for those that are interested: > > https://latt.net/wwvb%20remodulator%20spectracom%208170.jpg > > Majdi > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
PS
paul swed
Majdi
Thanks I will take some pix tomorrow work permitting and forward. Its dead
bug style so not pretty. But it sure does work.
Regards and thanks again
Paul
On Sun, Jun 16, 2013 at 8:51 PM, Bob Camp lists@rtty.us wrote:
Hi
Bob
post
   Majdi
Majdi Thanks I will take some pix tomorrow work permitting and forward. Its dead bug style so not pretty. But it sure does work. Regards and thanks again Paul On Sun, Jun 16, 2013 at 8:51 PM, Bob Camp <lists@rtty.us> wrote: > Hi > > You could get rid of the inverter and nand gate by using an XOR (74HC86) > gate. You'd save at least 5 cents …. > > Bob > > On Jun 16, 2013, at 8:24 PM, "Majdi S. Abbas" <msa@latt.net> wrote: > > > On Sun, Jun 16, 2013 at 05:43:18PM -0400, paul swed wrote: > >> OK no schematic. It was 2MB. But it was a scan of my notes. Happy to > post > >> to a sight or two. Can include some pictures also. > > > > There's a copy here for those that are interested: > > > > https://latt.net/wwvb%20remodulator%20spectracom%208170.jpg > > > > Majdi > > _______________________________________________ > > time-nuts mailing list -- time-nuts@febo.com > > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
PS
paul swed
Mon, Jun 17, 2013 2:03 AM
Did take both lo-res and hi-res at 2 MB each. The low res are not that
useful 3-4 of the hi-res will tell you a lot. However please resist the
critiques on the dead bugs. :-)
Regards
Paul.
On Sun, Jun 16, 2013 at 9:08 PM, paul swed paulswedb@gmail.com wrote:
Majdi
Paul
Hi
Bob
post
   Majdi
Did take both lo-res and hi-res at 2 MB each. The low res are not that useful 3-4 of the hi-res will tell you a lot. However please resist the critiques on the dead bugs. :-) Regards Paul. On Sun, Jun 16, 2013 at 9:08 PM, paul swed <paulswedb@gmail.com> wrote: > Majdi > Thanks I will take some pix tomorrow work permitting and forward. Its dead > bug style so not pretty. But it sure does work. > Regards and thanks again > Paul > > > On Sun, Jun 16, 2013 at 8:51 PM, Bob Camp <lists@rtty.us> wrote: > >> Hi >> >> You could get rid of the inverter and nand gate by using an XOR (74HC86) >> gate. You'd save at least 5 cents …. >> >> Bob >> >> On Jun 16, 2013, at 8:24 PM, "Majdi S. Abbas" <msa@latt.net> wrote: >> >> > On Sun, Jun 16, 2013 at 05:43:18PM -0400, paul swed wrote: >> >> OK no schematic. It was 2MB. But it was a scan of my notes. Happy to >> post >> >> to a sight or two. Can include some pictures also. >> > >> > There's a copy here for those that are interested: >> > >> > https://latt.net/wwvb%20remodulator%20spectracom%208170.jpg >> > >> > Majdi >> > _______________________________________________ >> > time-nuts mailing list -- time-nuts@febo.com >> > To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> > and follow the instructions there. >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> > >
R
Rex
Mon, Jun 17, 2013 4:59 AM
I shrunk the schematic down to <100k and I think still quite readable.
Attempting to attach it to this posting.
On 6/16/2013 2:43 PM, paul swed wrote: > OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post > to a sight or two. Can include some pictures also. > I shrunk the schematic down to <100k and I think still quite readable. Attempting to attach it to this posting.
PS
paul swed
Mon, Jun 17, 2013 12:21 PM
By golly it is readable thanks. What did you use to shrink it?
By golly it is readable thanks. What did you use to shrink it? On Mon, Jun 17, 2013 at 12:59 AM, Rex <rexa@sonic.net> wrote: > On 6/16/2013 2:43 PM, paul swed wrote: > >> OK no schematic. It was 2MB. But it was a scan of my notes. Happy to post >> to a sight or two. Can include some pictures also. >> >> > I shrunk the schematic down to <100k and I think still quite readable. > Attempting to attach it to this posting. > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
CA
Chris Albertson
Mon, Jun 17, 2013 4:52 PM
Here is an even smaller version, at the same resolution.    The trick is to
remove the background.  Then all you have is mostly a plank sheet and a
small amount of ink that compresses very well.
What you do is adjust the contrast until you have only pure white and pure
black.  That alone does 90% of the work.  Save it as a monochrome file to
kill the color channels then set the JPG compression as strong as you can.
post
Chris Albertson
Redondo Beach, California
Here is an even smaller version, at the same resolution. The trick is to remove the background. Then all you have is mostly a plank sheet and a small amount of ink that compresses very well. What you do is adjust the contrast until you have only pure white and pure black. That alone does 90% of the work. Save it as a monochrome file to kill the color channels then set the JPG compression as strong as you can. On Mon, Jun 17, 2013 at 5:21 AM, paul swed <paulswedb@gmail.com> wrote: > By golly it is readable thanks. What did you use to shrink it? > > > On Mon, Jun 17, 2013 at 12:59 AM, Rex <rexa@sonic.net> wrote: > > > On 6/16/2013 2:43 PM, paul swed wrote: > > > >> OK no schematic. It was 2MB. But it was a scan of my notes. Happy to > post > >> to a sight or two. Can include some pictures also. > >> > >> > > I shrunk the schematic down to <100k and I think still quite readable. > > Attempting to attach it to this posting. > > > > > > > > _______________________________________________ > > time-nuts mailing list -- time-nuts@febo.com > > To unsubscribe, go to > > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > > and follow the instructions there. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > -- Chris Albertson Redondo Beach, California
CA
Chris Albertson
Mon, Jun 17, 2013 4:58 PM
I'm looking at the schematic.  I thought the goal was to get the 60KHz
signal from WWVB to the HP unit.  This schematic sends an approximatly
60KHz signal from the tuning fork to the HP. but copies the AM modulation
from WWVB.  So the 8170 does not look at the 60KHz carrier? and only cars
about the time code?
Maybe another way then is to bypasss the radio inside the 8170 and just
send the demodulated logic bit
post
     Majdi
Chris Albertson
I'm looking at the schematic. I thought the goal was to get the 60KHz signal from WWVB to the HP unit. This schematic sends an approximatly 60KHz signal from the tuning fork to the HP. but copies the AM modulation from WWVB. So the 8170 does not look at the 60KHz carrier? and only cars about the time code? Maybe another way then is to bypasss the radio inside the 8170 and just send the demodulated logic bit On Sun, Jun 16, 2013 at 6:08 PM, ken johnson <bats059@gmail.com> wrote: > Also now on my web site, > > http://www.vk7krj.com/ham_stuff.htm > > at the bottom of the page, along with some other time-nut type files. > > And, once again, if anyone has any other time-nut files they would like to > see hosted on a web page, I am happy to oblige. Just email me. > > On Mon, Jun 17, 2013 at 10:24 AM, Majdi S. Abbas <msa@latt.net> wrote: > > > On Sun, Jun 16, 2013 at 05:43:18PM -0400, paul swed wrote: > > > OK no schematic. It was 2MB. But it was a scan of my notes. Happy to > post > > > to a sight or two. Can include some pictures also. > > > > There's a copy here for those that are interested: > > > > https://latt.net/wwvb%20remodulator%20spectracom%208170.jpg > > > > Majdi > > _______________________________________________ > > time-nuts mailing list -- time-nuts@febo.com > > To unsubscribe, go to > > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > > and follow the instructions there. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > -- Chris Albertson Redondo Beach, California
PS
paul swed
Mon, Jun 17, 2013 6:35 PM
Thanks for the pix and to the comments.
Chris you can indeed hack the 8170 insides. On the 8170 its intended to be
a time receiver. So Spectracom simply re-used what they had already
developed for the other phase tracking receivers. Good business. But it
does not at all work as suggested. You have to introduce the carrier and
such so that both agc will work correctly. (Even though its fixed) and lock
comes on. Absolutely what I would do for a one off. However some folks
would prefer not to go into the operating room. Sounds like you are on your
way to a private hack. Let us all know how it turns out. It will work.
Regards
Paul.
WB8TSL
On Mon, Jun 17, 2013 at 12:52 PM, Chris Albertson <albertson.chris@gmail.com
post
Chris Albertson
Thanks for the pix and to the comments. Chris you can indeed hack the 8170 insides. On the 8170 its intended to be a time receiver. So Spectracom simply re-used what they had already developed for the other phase tracking receivers. Good business. But it does not at all work as suggested. You have to introduce the carrier and such so that both agc will work correctly. (Even though its fixed) and lock comes on. Absolutely what I would do for a one off. However some folks would prefer not to go into the operating room. Sounds like you are on your way to a private hack. Let us all know how it turns out. It will work. Regards Paul. WB8TSL On Mon, Jun 17, 2013 at 12:52 PM, Chris Albertson <albertson.chris@gmail.com > wrote: > Here is an even smaller version, at the same resolution. The trick is to > remove the background. Then all you have is mostly a plank sheet and a > small amount of ink that compresses very well. > > What you do is adjust the contrast until you have only pure white and pure > black. That alone does 90% of the work. Save it as a monochrome file to > kill the color channels then set the JPG compression as strong as you can. > > > On Mon, Jun 17, 2013 at 5:21 AM, paul swed <paulswedb@gmail.com> wrote: > > > By golly it is readable thanks. What did you use to shrink it? > > > > > > On Mon, Jun 17, 2013 at 12:59 AM, Rex <rexa@sonic.net> wrote: > > > > > On 6/16/2013 2:43 PM, paul swed wrote: > > > > > >> OK no schematic. It was 2MB. But it was a scan of my notes. Happy to > > post > > >> to a sight or two. Can include some pictures also. > > >> > > >> > > > I shrunk the schematic down to <100k and I think still quite readable. > > > Attempting to attach it to this posting. > > > > > > > > > > > > _______________________________________________ > > > time-nuts mailing list -- time-nuts@febo.com > > > To unsubscribe, go to > > > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > > > and follow the instructions there. > > > > > _______________________________________________ > > time-nuts mailing list -- time-nuts@febo.com > > To unsubscribe, go to > > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > > and follow the instructions there. > > > > > > -- > > Chris Albertson > Redondo Beach, California > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
R
Rex
Mon, Jun 17, 2013 9:10 PM
That is basically the steps I used to make my version, except the jpg
encoding. Jpg is great for photos but not ideal for line art. If you
zoom into the jpg version you will see clouds of noise around the line
features. Gif doesn't do that.
When I made my gif version last night I used 64-level grayscale. That's
more than necessary. I just tried a version with 8-level grayscale and
the file size went from 95k to 43k.
Of course the other key compression was reducing resolution. The
original was 6600 x 5100 pixels. I cut down to 1400 x 1082 which still
may be a bit more than needed.
This is a bit off-topic for the group, though.
On 6/17/2013 9:52 AM, Chris Albertson wrote: > Here is an even smaller version, at the same resolution. The trick is to > remove the background. Then all you have is mostly a plank sheet and a > small amount of ink that compresses very well. > > What you do is adjust the contrast until you have only pure white and pure > black. That alone does 90% of the work. Save it as a monochrome file to > kill the color channels then set the JPG compression as strong as you can. > That is basically the steps I used to make my version, except the jpg encoding. Jpg is great for photos but not ideal for line art. If you zoom into the jpg version you will see clouds of noise around the line features. Gif doesn't do that. When I made my gif version last night I used 64-level grayscale. That's more than necessary. I just tried a version with 8-level grayscale and the file size went from 95k to 43k. Of course the other key compression was reducing resolution. The original was 6600 x 5100 pixels. I cut down to 1400 x 1082 which still may be a bit more than needed. This is a bit off-topic for the group, though.
