In a message dated 02-04-99 1:00:31 AM Eastern Daylight Time,
owner-trawler-world-list@samurai.com writes:
<< My personal advice is that it is not easy to repair the spongy deck, and
probably not worth the effort! >>
My 34'MT when bought last year had a deck like a trampoline and water would
squirt up out of the bung holes a inch or more when walked on.
I ripped off the teak, cut out top layer of glass leaving about a one
inch lip all around. Removed the sodden and rotten plywood squares and
cleaned with grinder, wire brush, linoleum knife, whatever - until bottom
layer of old glass was clean. Then I replaced the plywood with PVC foam
bedded in thickened epoxy. Replaced the old glass after it was thoroughly
cleaned also bedded in thickened epoxy. On top of that I bedded a layer of
1/4" PVC foam board, topped with two layers of biaxial glass cloth matting.
Around the edges placed a strip of the old teak that I had milled to 3/4"
wide with a beveled edge to protect the raw edge of the PVC and cloth.
The deck is now solid, water tight, and hopefully will last. Took
all last summer to accomplish.
Charles Monroe, EBB TIDE, soon to be at the Pt. Patience Marina, Solomons, MD
I'm in the process of repairing a spongy deck, too. If the boat is a
good boat and to your liking, you can probably get a good price with the
"spongy" decks. It actually isn't that tough to repair - just takes
some basic wood working and fiberglass skills, and the willingness to
cut into your pride and joy!
Beyond that, if you've owned a teaked-deck boat long enough, it will
eventually take on water and become spongy, unless repairs have already
been made or unless it was built properly to begin with! Usually starts
happening after about 12-15 years out in the open.
Bob McLeran rmcleran@ix.netcom.com
M/V "Sanderling" Docked at Point Patience Marina
Hailing port: Wianno MA Solomons, MD
Hampton 35 Trawler
