Cruising America's Great Loop and other inland routes
View all threadsThe new free NOAA charts that Maptech has available
for download are BSB, not BNC.
BSB chart files are produced by scanning the paper charts and
calibrating for lat/lon. The BSB chart is much like a .jpg
file and is a picture of the paper chart. They are also
called raster charts.
The ENC's are digital files that contain codes that allow
a computer program to draw the chart. In chartplotters
that use CMap, Navionics and Garmin "chips" a similar
process is used. These are called vector charts.
I'm not sure one format is better, but apparently NOAA
thinks the ENC format is better because they are in the
process of converting everything to ENC. In time the
BSB charts will be dropped and even the paper charts
will be generated from the ENC database.
Jim Fidler "Fiddlesticks"
----- Original Message -----
To: fidlerjim@earthlink.net
Sent: Friday, November 11, 2005 11:41 AM
Subject: Re: GL: Adapting these free charts
Jim;
To the question:
"Is there anyway to adapt these free charts to a Garmin
chartploter(Bluecharts)?"
You responded:
"It would be theoretically possible for some computer genius to write
software to convert the free ENC charts..."
The free charts from Maptech are in "BNC" format. What is the difference
between "BNC" and "ENC"? Which format is better?
Thank you,
Chris Byer
1hirld302@sneakemail.com
The data in a ENC chart file is the mathematical representations of objects.
The file contains the position of the object (long/lat), type of object
(bridge, marker, shoreline, depth, etc) as well as the characteristics of
the object (color, label, etc) as well as layer information, links to
picture files, frame of reference of the chart, etc.
Upgrading the chart should be easy. For example, if the position of a marker
changes, you only need to find the object in the file and insert the new
co-ordinates. Likewise for adding and removing objects. There is no need to
download a new file. It should be possible to have the Notice to Mariners
automatically update your charts so that they are always current.
Since the object text is a separate entity from the object, when in course
up mode, the names/labels are displayed on your monitor correctly no matter
what your heading is.
Another interesting effect is that you can have lights flash in their
correct Morse code and timing since they are an independent object from the
rest of the chart.
Another neat trick is that they have tied picture files to objects. When you
click on a bridge (really just another object), a tiff file is displayed
showing the bridge as it looks from both upstream and downstream, with
clearances for each arch and a profile of the river bed under the bridge.
It's also easy to manipulate a complete class of object (ie: hide all the
depth contour lines, or all contour lines deeper than x feet, etc). You can
also set up an alarm which will go off if you cross a depth contour line.
Each ENC chart requires about 350 kb of disk space where a raster chart
takes about 3,500 kb of disk. All of the ENC and IENC for the loop will take
about 250 mb of disk. My raster charts for just Georgian Bay take up about
85 mb so you can imagine what the loop would require (mind you, you would
probably leave the charts on the CD/DVD)
Having said all that, I much prefer the look of raster charts, however, most
charting software will allow you to split the screen and put the ENC chart
on one side and the raster chart on the other.
By the way, I had an email from Jeppesen Marine (Nobeltec) this morning,
confirming that Visual Navigator version 8.0 does support NOAA S-57 ENC
charts as well as the NOAA / NDI BSB raster charts.
Steve Bottoms
42' Sealord
Midland, Ont
To: "Chris Byer" 1hirld302@sneakemail.com; "great-loop"
great-loop@lists.samurai.com
Sent: Friday, November 11, 2005 5:49 PM
Jim;
To the question:
You responded:
Thank you,
Chris Byer
