time-nuts@lists.febo.com
10 MHz notch filter
GH
Gerhard Hoffmann
Tue, Oct 15, 2019 2:12 PM
I have just made an experimental 10 MHz notch filter for phase noise
improvement.
input - 50 Ohm to 400 Ohm transformer----- 400 Ohm line  ----
400-to50-transformer - output.
From the 400 Ohm line to GND are 2 cheap 10 MHz crystals, one with a
35pF series trimmer,
the other with series trimmer and 4.7uH. The xtal resonances thus are 10
MHz +1.6 KHz and -1.6 KHz.
Transformers are 1:8CT  Pulse electronics CX2049LNLT   digikey
553-2287-1-nd.
That's all.
The pics are the frequency response of the filter and the effect on the
phase noise of an R&S SMIQ.
SMIQ was chosen as an easy victim.
The filter costs next to nothing. It won't turn my MV89A references into
BVAs, but gives at least some
keyhole insights . There could be easily 5 crystal pairs for
strategically chosen frequencies.
For notches closer to the carrier the impedance level must be probably
lower (1:4 or 1:2 xformers)
That makes the notches less deep, but also less wide, so they cannot
interact at the carrier frequency itself.
The filter withstands quite a lot of power because the crystals do not
resonate on the carrier frequency.
Just make sure you do not sweep them with +30 dBm accidentally.
regards, Gerhard
I have just made an experimental 10 MHz notch filter for phase noise improvement. input - 50 Ohm to 400 Ohm transformer----- 400 Ohm line  ---- 400-to50-transformer - output. From the 400 Ohm line to GND are 2 cheap 10 MHz crystals, one with a 35pF series trimmer, the other with series trimmer and 4.7uH. The xtal resonances thus are 10 MHz +1.6 KHz and -1.6 KHz. Transformers are 1:8CT  Pulse electronics CX2049LNLT   digikey 553-2287-1-nd. That's all. The pics are the frequency response of the filter and the effect on the phase noise of an R&S SMIQ. SMIQ was chosen as an easy victim. The filter costs next to nothing. It won't turn my MV89A references into BVAs, but gives at least some keyhole insights . There could be easily 5 crystal pairs for strategically chosen frequencies. For notches closer to the carrier the impedance level must be probably lower (1:4 or 1:2 xformers) That makes the notches less deep, but also less wide, so they cannot interact at the carrier frequency itself. The filter withstands quite a lot of power because the crystals do not resonate on the carrier frequency. Just make sure you do not sweep them with +30 dBm accidentally. regards, Gerhard
MD
Magnus Danielson
Tue, Oct 15, 2019 3:47 PM
Hi,
Be careful to trim this to be as balanced as possible, since inbalance
between side-bands allow for linear AM-to-PM conversion.
You could even use a AM-modulated signal and then detect the strength of
the PM/FM signal and tune for minumum leakage. You can also swap the
modulation modes between source and detector, as the leakage from PM to
AM is the same as from AM to PM.
This will not be as important in the deep notches, as to the sides of them.
Cheers,
Magnus
improvement.
553-2287-1-nd.
That's all.
regards, Gerhard
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
Hi, Be careful to trim this to be as balanced as possible, since inbalance between side-bands allow for linear AM-to-PM conversion. You could even use a AM-modulated signal and then detect the strength of the PM/FM signal and tune for minumum leakage. You can also swap the modulation modes between source and detector, as the leakage from PM to AM is the same as from AM to PM. This will not be as important in the deep notches, as to the sides of them. Cheers, Magnus On 2019-10-15 16:12, Gerhard Hoffmann wrote: > > I have just made an experimental 10 MHz notch filter for phase noise > improvement. > > > input - 50 Ohm to 400 Ohm transformer----- 400 Ohm line  ---- > 400-to50-transformer - output. > > From the 400 Ohm line to GND are 2 cheap 10 MHz crystals, one with a > 35pF series trimmer, > > the other with series trimmer and 4.7uH. The xtal resonances thus are > 10 MHz +1.6 KHz and -1.6 KHz. > > > Transformers are 1:8CT  Pulse electronics CX2049LNLT   digikey > 553-2287-1-nd. > > That's all. > > > The pics are the frequency response of the filter and the effect on > the phase noise of an R&S SMIQ. > > SMIQ was chosen as an easy victim. > > > The filter costs next to nothing. It won't turn my MV89A references > into BVAs, but gives at least some > > keyhole insights . There could be easily 5 crystal pairs for > strategically chosen frequencies. > > > For notches closer to the carrier the impedance level must be probably > lower (1:4 or 1:2 xformers) > > That makes the notches less deep, but also less wide, so they cannot > interact at the carrier frequency itself. > > The filter withstands quite a lot of power because the crystals do not > resonate on the carrier frequency. > > Just make sure you do not sweep them with +30 dBm accidentally. > > > regards, Gerhard > > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
