Hi Mathias,
I'm assuming you're using a coin cell for back up, so wondering if one of the diodes shouldn't be in series with the battery, with both cathodes to V_BCKP?
Nigel GM8PZR
I've updated the repository on github with the latest design files. The
breakout board is now final as far as I'm concerned.
I managed to implement all the requested features, this includes the backup
battery and also the buffered PPS output with SMA footprint.
Next step on my side will be to order a small batch of PCBs. There's not much
on them and I guess I will end up with around 25? for 5 boards fully
assembled, shipping not included.
I eventually removed the I2C pull-ups again, thanks to Patrick Tudor for the
hint. The footprints are still there, I only removed them from the BOM.
Schematic and a screenshot of the top and bottom sides attached.
BR,
Matthias
Hello to the group Nigel is correct the way the schematic is drawn the
Regulator will feed the battery and most likely cause it to burst.
It should be 1 diode in series with the regulator and 1 in series with the
battery so that the regulator can not charge the battery.
Nice design you have created.
Regards
Paul
WB8TSL
On Tue, Dec 15, 2020 at 11:55 AM Nigel gm8pzr via time-nuts <
time-nuts@lists.febo.com> wrote:
Hi Mathias,
V_BCKP?
Nigel GM8PZR
backup
much
the
BR,
Matthias
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to
http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
Yes, that's what I discussed with Nigel off-list. The two diodes in series
create a voltage difference of 1.4V, so as long the battery voltage is above
1.9V, no current will flow through the diodes at all and the battery is safe.
However, there is a greater-than-zero probability that a board will just be
dropped into a drawer with the battery in place, fully draining it eventually.
If it's then powered up again, chances are that a substantial current will
flow into the battery and potentially cause a fire, explosion, etc.
I've therefore updated the design and put a small Schottky diode in series
with the battery. I selected a part with small leakage current ( 0.5µA
typical). But of course a regular silicon diode like 1N4148WS will work as
well, at the expense of wasting some of the energy of the coin cell.
Thanks - Hopefully it will also work :-)
Regards
Paul
WB8TSL
Hi Mathias,
V_BCKP?
Nigel GM8PZR
backup
much
the
BR,
Matthias
http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com and follow
Yes you did the right thing. I am a drop it in the drawer person.
Hate when those batteries make a bang.
On Tue, Dec 15, 2020 at 5:06 PM Matthias Welwarsky time-nuts@welwarsky.de
the
above
safe.
be
eventually.
Regards
Paul
WB8TSL
Hi Mathias,
of
to
V_BCKP?
Nigel GM8PZR
backup
not
much
for
the
BR,
Matthias
follow
