RW
Raymond West
Tue, Dec 27, 2022 2:22 PM
Hi Ken,
If starting from an existing shape, you will need to make it smaller if
you wish to round edges using Minkowski, which is a pita for something
other than a basic box say. In your example, then replacing your last
bit of script, so that you Minkowski everything, will get probably what
you want, other than having to alter the dimensions!
The module rounder(r) that I added (not used at all in your existing
code), is what I generally use for rounding off edges of existing
objects. You have to translate and rotate and difference rounder over
each edge that you wish to round off. That also can be tedious, but it
gives selective rounding of edges, different radii, etc. without having
to recalculate the original thickness etc. For external corners, apply a
similar object made from a cube and four spheres.
With your particular tray, it may have been easier to draw the
partitions in 2d, and extrude, which would reduce the number of edges to
be rounded, but at the end of the day, whatever works for you will be
good enough. Sometimes, sandpaper is your friend, if only a few items
being produced..
On 27/12/2022 12:41, Carsten Arnholm wrote:
On 27.12.2022 10:43, Ken wrote:
Is it even possible to round the internal corners using minkowski?
Minkowski operates on a convex object. If you mean filetting concave
edges, the answer is no, but you can do it in a round-about way
create a cube enclosing the object completely
Subtract your model from the cube, creating an internal void where
the original model concave edges becoming convex.
Run Minkowski with a sphere on the difference
Subtract the result of Minkowski from the original object.
The result is rounded concave (internal) edges
Carsten Arnholm
OpenSCAD mailing list
To unsubscribe send an email todiscuss-leave@lists.openscad.org
Hi Ken,
being produced..
> 1. create a cube enclosing the object completely
> 2. Subtract your model from the cube, creating an internal void where
> 3. Run Minkowski with a sphere on the difference
> 4. Subtract the result of Minkowski from the original object.
> Carsten Arnholm
> _______________________________________________
K
Ken
Wed, Dec 28, 2022 10:48 AM
Thank you for your suggestions gentlemen.
I initially tried roundedcube, Roger's suggestion, that mostly worked
but left some edges un-rounded. But is now in my openscad library for
future use, thanks Roger.
I then tried Raymond's suggestion- Ie., the correct way of using
minkowski- thanks Raymond- that worked a charm on all the edges I wanted
rounded- at least, it did when I changed my standard $fn from 128 back
to 32- 128 just hung openscad, needing task manager to shut it down
after waiting several hours for it to complete!
It leaves me with a new problem now- when I try to difference out the
text, it appears to take out large parts of the box as well, meaning it
won't f6 any more. If I take out the comments around the outer
difference, it will f5 but not f6. In my simplistic way of seeing it, I
thought it should just difference out the text after the minkowski
finished- apparently not. This is the code in question-
/difference()
minkowski()
difference()
box();
Divider_1();
Divider_2();
Divider_3();
Finger_cutout();
sphere(Wall/3);
//Text();
A baby can be defined as an ego with a noise at one end and a smell at the other.
Our job as parents is to teach them to control all three.
/difference()
minkowski()
difference()
box();
Divider_1();
Divider_2();
Divider_3();
Finger_cutout();
sphere(Wall/3);
//Text();
Cheers, Ken
bats059@gmail.com
https://vk7krj.com/running.html
https://sstv.vk7krj.com/all_bands.html
NH
nop head
Wed, Dec 28, 2022 11:21 AM
You probably need to set convexity in the minkowski calls.
/difference()
minkowski()
difference()
box();
Divider_1();
Divider_2();
Divider_3();
Finger_cutout();
sphere(Wall/3);
//Text();
other.
To unsubscribe send an email to discuss-leave@lists.openscad.org
> /difference()
> minkowski()
> difference()
> box();
> Divider_1();
> Divider_2();
> Divider_3();
> Finger_cutout();
> sphere(Wall/3);
> //Text();
> Cheers, Ken
> bats059@gmail.com
> other.
K
Ken
Wed, Dec 28, 2022 11:44 AM
Thanks Nop head, that fixed it nicely!
wanted
back
meaning it
it, I
/difference()
minkowski()
difference()
box();
Divider_1();
Divider_2();
Divider_3();
Finger_cutout();
sphere(Wall/3);
//Text();
Cheers, Ken
bats059@gmail.com
smell at the other.
> wanted
> back
> meaning it
> it, I
> /difference()
> minkowski()
> difference()
> box();
> Divider_1();
> Divider_2();
> Divider_3();
> Finger_cutout();
> sphere(Wall/3);
> //Text();
> Cheers, Ken
> bats059@gmail.com
> smell at the other.
Cheers, Ken
bats059@gmail.com
SP
Sanjeev Prabhakar
Wed, Dec 28, 2022 1:40 PM
I have also given it a try
for details you can check the ipynb file
[image: Screenshot 2022-12-28 at 7.06.04 PM.png]
/difference()
minkowski()
difference()
box();
Divider_1();
Divider_2();
Divider_3();
Finger_cutout();
sphere(Wall/3);
//Text();
the other.
>> /difference()
>> minkowski()
>> difference()
>> box();
>> Divider_1();
>> Divider_2();
>> Divider_3();
>> Finger_cutout();
>> sphere(Wall/3);
>> //Text();
>> Cheers, Ken
>> bats059@gmail.com
>> the other.
> Cheers, Kenbats059@gmail.comhttps://vk7krj.com/running.htmlhttps://sstv.vk7krj.com/all_bands.html
RW
Raymond West
Wed, Dec 28, 2022 2:13 PM
Interesting. can you easily round the sharp edges of the semicircular
recesses?
The snag is, when you import into openscad, you do not get anything that
you can readily edit in openscad. FreeCad does similar, it produces
multmatrix iirc, which is just as tricky. Freecad is quite useful for
applying fillets, chamfers and so on, but is more or less a dead end if
you want to edit the result in openscad.
Best wishes,
Ray
mostly worked
library for
edges I wanted
128 back
it down
out the
meaning it
seeing it, I
minkowski
/difference()
minkowski()
difference()
box();
Divider_1();
Divider_2();
Divider_3();
Finger_cutout();
sphere(Wall/3);
//Text();
Cheers, Ken
bats059@gmail.com
smell at the other.
Cheers, Ken
bats059@gmail.com
recesses?
Best wishes,
Ray
>> mostly worked
>> library for
>> edges I wanted
>> 128 back
>> it down
>> out the
>> meaning it
>> seeing it, I
>> minkowski
>> /difference()
>> minkowski()
>> difference()
>> box();
>> Divider_1();
>> Divider_2();
>> Divider_3();
>> Finger_cutout();
>> sphere(Wall/3);
>> //Text();
>> Cheers, Ken
>> bats059@gmail.com
>> smell at the other.
> Cheers, Ken
> bats059@gmail.com
SP
Sanjeev Prabhakar
Wed, Dec 28, 2022 2:25 PM
Rounding semi-circular sharp edges should be easy.
You need to just cut a fillet there.
You are right it would be difficult to edit this in openscad if not
impossible.
If you can work on the JN , it will be very easy.
Unfortunately it is not that straight forward to get started on the same
and involve a series of steps.
Regards
Sanjeev
recesses?
applying fillets, chamfers and so on, but is more or less a dead end if you
Best wishes,
Ray
/difference()
minkowski()
difference()
box();
Divider_1();
Divider_2();
Divider_3();
Finger_cutout();
sphere(Wall/3);
//Text();
the other.
impossible.
Regards
Sanjeev
> recesses?
> Best wishes,
> Ray
>>> /difference()
>>> minkowski()
>>> difference()
>>> box();
>>> Divider_1();
>>> Divider_2();
>>> Divider_3();
>>> Finger_cutout();
>>> sphere(Wall/3);
>>> //Text();
>>> Cheers, Ken
>>> bats059@gmail.com
>>> the other.
SP
Sanjeev Prabhakar
Wed, Dec 28, 2022 5:22 PM
[image: Screenshot 2022-12-28 at 10.47.12 PM.png]
revised files attached
K
Ken
Thu, Dec 29, 2022 1:22 AM
Thanks Sanjeev, your revised box looks excellent. I did have a good look
at what you sent, but my skills with both python and jupiter notebook
are no-where near what they would need to be to do that sort of thing.
Cheers, Ken
bats059@gmail.com
SP
Sanjeev Prabhakar
Thu, Dec 29, 2022 2:22 AM
Thanks Ken,
Could you run the jupyter notebook file ?
Thanks Ken,
AM
Adrian Mariano
Wed, Jan 4, 2023 9:35 PM
Here's a way to make a similar model with similar rounding that doesn't
rely on generating the model externally in python. It does of course rely
on BOSL2. Basically you can make the semi-circular roundings using
offset_sweep, which can create prisms that flare out, and differencing that
away gives the desired result. (I haven't looked at Sanjeev's python to
compare code complexity.)
[image: image.png]
This model previews in 30s and renders in about a minute on my old
computer. It also has smooth rounded corners at the top of the
semi-circles, instead of the roundings meeting at a corner. In the dev
version it previews in 21s and renders in 23s.
On Wed, Dec 28, 2022 at 9:23 PM Sanjeev Prabhakar sprabhakar2006@gmail.com
[image: image.png]
On Wed, Dec 28, 2022 at 9:23 PM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
wrote:
> Thanks Ken,
K
Ken
Thu, Jan 5, 2023 5:24 AM
Thanks Adrian- I have saved the code & when my son and grandson go back
to home in a week or so I will take some time to try and understand how
you have done it. It's great to see many different ways to arrive at the
same- or similar- result.
doesn't rely on generating the model externally in python. It does
of course rely on BOSL2. Basically you can make the semi-circular
roundings using offset_sweep, which can create prisms that flare out,
and differencing that away gives the desired result. (I haven't
looked at Sanjeev's python to compare code complexity.)
dev version it previews in 21s and renders in 23s.
sprabhakar2006@gmail.com wrote:
Thanks Ken,
> <sprabhakar2006@gmail.com> wrote:
> Thanks Ken,
Cheers, Ken
bats059@gmail.com
