View all threadsHello Vinit,
This question is much more about UHD so I'm adding the usrp-users mailing
list [1].
There is no USRP daughterboard which goes to 250 GHz so I assume you mean
250 MHz which would point towards the BasicRx daughterboard. This
daughterboard has no mixer and so the N200 will use aliasing to receive
non-baseband signals. The N200's ADC runs at 100 MSPS, but Gigabit Ethernet
isn't able to transport that much data so it is always decimated by some
factor. This means that a target frequency of 97.9 MHz (A good choice for a
first test) is in a higher Nyquist band. What you're seeing is correct
behaviour.
UHD 3.5.5 is very old and I'd recommend removing the current version and
install a newer release. I would guess that you are on Ubuntu 14.04 and
installed it using apt. If you are very unfamiliar with Linux and don't
have anyone locally who you could get some assistance from it's worth
considering using the GNU Radio Live Environment [2] which can be written
to a USB drive and booted from. This comes with up to date versions of GNU
Radio and UHD, as well as a variety of additional SDR related packages.
You can also look at PyBOMBS[3] or the build-gnuradio [4] script, either of
which will install the latest UHD and GNU Radio.
Regards,
Derek
[1] http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
[2] https://gnuradio.org/redmine/projects/gnuradio/wiki/GNURadioLiveDVD
[3] https://github.com/gnuradio/pybombs/
[4]
https://gnuradio.org/redmine/projects/gnuradio/wiki/InstallingGRFromSource#Using-the-build-gnuradio-script
On Fri, Apr 8, 2016 at 1:12 PM, Vinit Shah tug14467@temple.edu wrote:
Dear all,
I am a beginner in Linux and So far I have successfully installed gnuradio
and hardware dependencies.
The very basic program which is just connecting usrp source with WX gui
fft sink is not working correctly.
I am getting following error messaege
linux; GNU C++ version 4.8.2; Boost_105400; UHD_003.005.005-0-unknown
Using Volk machine: sse4_2_64_orc
-- Opening a USRP2/N-Series device...
-- Current recv frame size: 1472 bytes
-- Current send frame size: 1472 bytes
UHD Warning:
Unable to set the thread priority. Performance may be negatively
affected.
Please see the general application notes in the manual for
instructions.
UHD Warning:
The hardware does not support the requested RX frequency:
Target frequency: 97.900000 MHz
Actual frequency: -2.100000 MHz
Done
My daughter board has range up to 250 Gigs... but I do not know why even
with 10 M sampling frequency my system is aliasing ??
This is a common problem I found on internet but no effective solution so
far, I think.
Any help would be highly appreciated.
I request you please explain explicitly because I am novice in this field(
with linux), and if possible with example..??
Thank you very much in advance
Discuss-gnuradio mailing list
Discuss-gnuradio@gnu.org
https://lists.gnu.org/mailman/listinfo/discuss-gnuradio
