time-nuts@lists.febo.com
Re: [time-nuts] AC cord or connector for 5061A
AT
Arnold Tibus
Sun, Jul 19, 2009 3:00 PM
MS3106A-18-22SW ?
that special type of connector will be very hard to get
(if you do not find the original cable for this unit)!
The insert is not standard:
"Not MSA/B insert arrangements and polarization"
This spec. is very old and even the US-Militaries did advice already
decades of years ago to not use them anymore in new design.
One problem with this old MIL-Spec. connectors is that these contain
a lot of cadmium for protection against corrosion on their surface.
Cadmium is known to be very toxic and is today forbidden to be applied.
The cadmium is covered by a green chromate film, which is not very
resistant when the surface is being scratched with some force.
Technical details:
It is a MIL-C-5015 Power type connector with large contacts,
threaded coupling, straight plug and shell size 18,
But this contact arrangement18-22 is not on all manufacturers lists.
I guess that only some chinese manufacturer do still have them
in the productiong line for spares, if at all.
Attention to the 'W' in the type number which does mean that
the insert is turned by 70 deg. to avoid to be connected with std.
types used for other purposes...both mating part must have this marking!
some techn. infos under
http://www.in2connect.uk.com/c2/uploads/a5015%20ms1.pdf
www.amphenol-aerospace.com/pdf/knowconnectors.pdf
I would propose in this case to exchange the original parts with
modern types fitting in this position and being qualified to be used
for mains connection.
Good luck!
regards
Arnold
On Sun, 19 Jul 2009 07:25:03 -0400, John Ackermann N8UR wrote:
I got some from Digi-key a year or so ago.  Unfortunately, I don't
recall the DK part number, but I recall I had to do a cross-reference
from the Cannon part number to another manufacturer (I think AMP) and
that's what DK had.
John
J. L. Trantham said the following on 07/18/2009 11:58 PM:
I am aware of the connection issue but I can't find the connectors.  Are
they still available or should I change both the chassis connector and
mating connector to something that I can find?
Thanks,
Joe
-----Original Message-----
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On
Behalf Of Tom Van Baak
Sent: Saturday, July 18, 2009 10:45 PM
To: Discussion of precise time and frequency measurement
Subject: Re: [time-nuts] AC cord or connector for 5061A
Does anyone know of a source for a power cord for the 5061A (or 5061B,
5065A, etc.)?  I am looking for 3 cords or the connector that mates
with AC connector on the back.
The AC Cord is HP part number 1251-2457 and the connector that mates
with the connector on the back is a Cannon MS3106A-18-22SW.
Thanks in advance.
Joe
See if this helps.
http://www.leapsecond.com/museum/hp5065a/conn.htm
Best to open the bottom to make sure your unit has pins
that match the schematic.
/tvb
To unsubscribe, go to
MS3106A-18-22SW ? that special type of connector will be very hard to get (if you do not find the original cable for this unit)! The insert is not standard: "Not MSA/B insert arrangements and polarization" This spec. is very old and even the US-Militaries did advice already decades of years ago to not use them anymore in new design. One problem with this old MIL-Spec. connectors is that these contain a lot of cadmium for protection against corrosion on their surface. Cadmium is known to be very toxic and is today forbidden to be applied. The cadmium is covered by a green chromate film, which is not very resistant when the surface is being scratched with some force. Technical details: It is a MIL-C-5015 Power type connector with large contacts, threaded coupling, straight plug and shell size 18, But this contact arrangement18-22 is not on all manufacturers lists. I guess that only some chinese manufacturer do still have them in the productiong line for spares, if at all. Attention to the 'W' in the type number which does mean that the insert is turned by 70 deg. to avoid to be connected with std. types used for other purposes...both mating part must have this marking! some techn. infos under http://www.in2connect.uk.com/c2/uploads/a5015%20ms1.pdf www.amphenol-aerospace.com/pdf/knowconnectors.pdf I would propose in this case to exchange the original parts with modern types fitting in this position and being qualified to be used for mains connection. Good luck! regards Arnold On Sun, 19 Jul 2009 07:25:03 -0400, John Ackermann N8UR wrote: >I got some from Digi-key a year or so ago. Unfortunately, I don't >recall the DK part number, but I recall I had to do a cross-reference >from the Cannon part number to another manufacturer (I think AMP) and >that's what DK had. >John >---- >J. L. Trantham said the following on 07/18/2009 11:58 PM: >> I am aware of the connection issue but I can't find the connectors. Are >> they still available or should I change both the chassis connector and >> mating connector to something that I can find? >> >> Thanks, >> >> Joe >> >> -----Original Message----- >> From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On >> Behalf Of Tom Van Baak >> Sent: Saturday, July 18, 2009 10:45 PM >> To: Discussion of precise time and frequency measurement >> Subject: Re: [time-nuts] AC cord or connector for 5061A >> >> >>> Does anyone know of a source for a power cord for the 5061A (or 5061B, >>> 5065A, etc.)? I am looking for 3 cords or the connector that mates >>> with AC connector on the back. >>> >>> The AC Cord is HP part number 1251-2457 and the connector that mates >>> with the connector on the back is a Cannon MS3106A-18-22SW. >>> >>> Thanks in advance. >>> >>> Joe >> >> See if this helps. >> >> http://www.leapsecond.com/museum/hp5065a/conn.htm >> >> Best to open the bottom to make sure your unit has pins >> that match the schematic. >> >> /tvb >> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >_______________________________________________ >time-nuts mailing list -- time-nuts@febo.com >To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >and follow the instructions there.
