Hi all,
I' work in APS-Direct (Symbian Version), during call between two mobiles
after 24 minute caller crash and exit by error 'kernel exe 3', what reason from
this problem?.Thanks.
News, entertainment and everything you care about at Live.com. Get it now!
http://www.live.com/getstarted.aspx
Unfortunately it will be very difficult to answer your question without more
information, such as:
cheers
Benny
On Sun, Apr 5, 2009 at 1:47 PM, mohamed hassan e-mohhassan@hotmail.comwrote:
Hi all,
from this problem?.
Thanks.
Get news, entertainment and everything you care about at Live.com. Check
it out! http://www.live.com/getstarted.aspx
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Hi benny I'm answer your questions:
what app are you using (is it symbian_ua?), I'm test symbain_ua but crashed after 24
minutes, and in command line app ua.sis not crashed.
which pjsip version (latest SVN or from the tarball), I'm used last version
stable 'PJSIP v 1.1'.
what handset are you using,
I'm used Nokia N73.
what software is running on the remote peer? In caller and callee used
PJSIP, and crash in caller.
what codec was used?,
Default codec in APS-Direct.
what exactly were you doing before the crash (were you just talking or
was there anything else)
and last but not least, it would help greatly if you can produce the
log file. You can either add logging code in the application, or if you run
symbian_ua in debug mode from Carbide (and with cable attached), and uncomment
"//#include<e32debug.h>" and "//RDebug::Print(aBuf);"
in ua.cpp lines 255 and 267, you should be able to capture the log in Carbide
Console applet.
I'm begging debugging
but not complete.
Thanks all.
Date: Mon, 6 Apr 2009 11:13:50 +0100
To: pjsip@lists.pjsip.org
Subject: Re: [pjsip] crash APS-Direct
Unfortunately it will be very difficult to answer your question without more information, such as:
what codec was used
what exactly were you doing before the crash (were you just talking or was there anything else)
and last but not least, it would help greatly if you can produce the log file. You can either add logging code in the application, or if you run symbian_ua in debug mode from Carbide (and with cable attached), and uncomment "//#include<e32debug.h>" and "//RDebug::Print(aBuf);" in ua.cpp lines 255 and 267, you should be able to capture the log in Carbide Console applet.
cheers
Benny
On Sun, Apr 5, 2009 at 1:47 PM, mohamed hassan e-mohhassan@hotmail.com wrote:
Hi all,
Get news, entertainment and everything you care about at Live.com. Check it out!
pjsip mailing list
Drag n’ drop—Get easy photo sharing with Windows Live™ Photos.
http://www.microsoft.com/windows/windowslive/products/photos.aspx
Hi benny,
Still crash problem founded, in trace problem in freeswitch
server call end by error ‘RECOVERY_ON_TIMER_EXPIRE’,and in free switch wiki ‘ http://wiki.freeswitch.org/wiki/Hangup_causes
’ error my be from error not handle in timer, I test this problem in X-Lite
client but not appear.
Date: Tue, 7 Apr 2009 07:30:39 +0000
I'm used Nokia N73.
Console applet.
but not complete.
Thanks all.
what codec was used
cheers
Benny
Hi all,
pjsip mailing list
What can you do with the new Windows Live? Find out
Hi all,
Still I’m working in call disconnect problem, tried some
tests:
First, caller and
callee PJSIP symbian_ua(last realse 23-03-2009) and call disconnect in Symbian_ua after 24.9 minutes in 5 tests.
Second, other test
callee and caller QJSimple(0.5) based PJSIP , also call disconnect in QJSimple
not after const time usually (2,10,12
minutes), callee stop send data and receive from caller, in some case callee
crashed otherwise call continue but no any voice in caller or callee in 6 tests.
Last, I try other test two X-lite client call continued up
to one hour.
Is found any person meeting same problem in call up to 30
minutes in PJSIP?
Thanks.
Date: Tue, 14 Apr 2009 09:43:50 +0000
Hi benny,
I'm used Nokia N73.
Console applet.
but not complete.
Thanks all.
what codec was used
cheers
Benny
Hi all,
pjsip mailing list
Show them the way! Add maps and directions to your party invites.
http://www.microsoft.com/windows/windowslive/products/events.aspx
Most probablere there's a memory leak somewhere in the code or some
counter overflowing.
To track down where the bug is please follow this information:
http://www.newlc.com/Tracking-down-memory-leaks.htm
https://developer.symbian.com/wiki/pages/viewpage.action?pageId=432l
Memory leak on symbian are one of the worst things that can be there.
Mohamed, benny, you are the only ones who can make it more stable.
Mohamed, can you provide much details by debugging the memory leaks and
at the same time report the bug with full log details?
Fabio
mohamed hassan wrote:
Hi all,
Still I’m working in call disconnect problem, tried some tests:
First, caller and callee PJSIP symbian_ua(last realse 23-03-2009) and
Second, other test callee and caller QJSimple(0.5) based PJSIP , also
call disconnect in QJSimple not after const time usually (2,10,12
callee crashed otherwise call continue but no any voice in caller or
callee in 6 tests.
Last, I try other test two X-lite client call continued up to one hour.
Is found any person meeting same problem in call up to 30 minutes in
PJSIP?
Thanks.
thanks Fabio,
in my tests, INVITE Message contain Session-Expires: 120 (Keep alive message between
client and server)
FULL MESSAGE:
INVITE sip:126@192.168.0.6:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.3;rport;branch=z9hG4bKKtD3vFZ3Qr7Fp
Max-Forwards: 70
To: sip:126@192.168.0.3;tag=mb7-7oZqmhhClf1Ug.7f9JJIG11iglYC
Call-ID: wCnoaaKG0VNZUsIu7D7mPEC2sMaN3KuO
CSeq: 113708767 INVITE
Contact:
sip:mod_sofia@192.168.0.3:5060;transport=udp
User-Agent: FreeSWITCH-mod_sofia/1.0.1-exported
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, PRACK, MESSAGE, SUBSCRIBE,
NOTIFY, REFER, UPDATE, REGISTER, INFO, PUBLISH
Supported: 100rel, timer, precondition, path, replaces
Min-SE: 120
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 344
v=0
o=- 4689126742759932103 2121988458920195298 IN IP4 192.168.0.3
s=pjmedia
c=IN IP4 192.168.0.4
t=0 0
a=X-nat:0
m=audio 4000 RTP/SAVP 102 101
a=rtpmap:102 speex/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtcp:4001 IN IP4 192.168.0.4
a=crypto:1 AES_CM_128_HMAC_SHA1_80
inline:1ahJYSwy4DYbmm9y2UG0L/drhbBNNRC9Avt8czlN
Is keep alive message response from destroy call ? because if
lost keep alive message, my be server to send bye to caller and callee.
I need some suggestions to help me solved this problem.
Date: Thu, 16 Apr 2009 21:04:13 +0200
Fabio
Hi all,
tried some
tests:
First, caller and
Second, other test
QJSimple
callee
6 tests.
continued up
to one hour.
up to 30
minutes in PJSIP?
Thanks.
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
Hi all,
I’m successful solved disconnect call after 24.9 minutes,
disable timer session in freeswitch and establish call 8 hours, problem not
occur.
Thanks all.
Date: Sun, 19 Apr 2009 12:24:53 +0000
thanks Fabio,
client and server)
FULL MESSAGE:
Max-Forwards: 70
Contact:
Min-SE: 120
Content-Length: 344
v=0
s=pjmedia
t=0 0
a=X-nat:0
a=fmtp:101 0-15
Fabio
Hi all,
tried some
tests:
First, caller and
Second, other test
QJSimple
callee
6 tests.
continued up
to one hour.
up to 30
minutes in PJSIP?
Thanks.
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy! Try it!
Hi Benny,
shouldn't the PJSUA keep the connection open with a keepalive ping?
Fabio
Hi all,
I’m successful solved disconnect call after 24.9 minutes, disable
timer session in freeswitch and establish call 8 hours, problem not occur.
Thanks all.
