GPSDO and external 10 MHz reference
WF
Wallace, Frank L CIV NSWCDD, Q41
Fri, Oct 11, 2013 5:10 PM
I have N2x0 radios and I have installed the GPSDO in several of them.
Sometimes I want use the external reference and sometimes I want to use the GPS reference.  Do I have to open them up and move the jumper when I want to switch or does it still honor the software command?
There are also times when I want the 1 PPS to come from the GPSDO and the 10 MHz to come from an external source.  Is this doable?
Thanks,
Frank
I have N2x0 radios and I have installed the GPSDO in several of them. Sometimes I want use the external reference and sometimes I want to use the GPS reference. Do I have to open them up and move the jumper when I want to switch or does it still honor the software command? There are also times when I want the 1 PPS to come from the GPSDO and the 10 MHz to come from an external source. Is this doable? Thanks, Frank
