BK
Bob kb8tq
Wed, Jul 17, 2019 4:59 PM
Hi
There seems to be a firmware update for the F9P. It is a bunch of minor looking
bug fixes. They also changed the ordering code to reflect the new firmware. That
may get Digikey to obsolete the old part and put up a new one.
Various doc’s have also been updated at the same time.
https://www.u-blox.com/en/product/zed-f9p-module#tab-documentation-resources https://www.u-blox.com/en/product/zed-f9p-module#tab-documentation-resources
For those trying to do things with the F9T, the F9P doc’s have a lot more of the
details you might be looking for.
Bob
Hi
https://www.u-blox.com/en/product/zed-f9p-module#tab-documentation-resources <https://www.u-blox.com/en/product/zed-f9p-module#tab-documentation-resources>
Bob
GE
Glen English VK1XX
Wed, Jul 17, 2019 8:57 PM
The F9T and F9P - are these interchangeable for stationary timing use
and stationary high performance position ?
From how I read the datasheets, :
the F9P has an internal RTK engine, and the F9T outputs the info RTCM
etc and that data can be run on a external RTK engine on a micro.
The P provides 1.5m standalone positional accuracy compared to the T
standalone positional accuracy of 2.0m. Not much difference there..
the F9P and F9T have their timing pulse performance shown using
different description.
The P has this as "RMS and 99%", while the T has this as '5nS','2.5ns diff'
Both can operate with companion receivers to enhance performance
but I interpret this as only the P can do a (internal, companion mode)
differential position fix and only the T can do a (internal companion
mode) differential time fix. That is , internally without using an
external engine.
So it seems, if using an external RTL etc engines, the devices can do
roughly the same thing.
How do others interpret this ? I want to do projects using positional
for one app, and timing for another, and would like to be able to
acheive the deep quantity discounts...
glen
external engine.
glen
BK
Bob kb8tq
Wed, Jul 17, 2019 9:37 PM
Hi
Having played with both, there are differences in how the P and the T do things. Both do a better job on
timing than single band modules do. The T has multiple pps outputs and should handle logging (at a
fairly coarse resolution) an input pps on two inputs.
Both will handle external correction inputs via a serial port. The P does not do SBAS, but the T does.
They now say that SBAS degrades timing on the T (as it does on all other receivers) so that may not be a plus.
I have not checked the latest firmware on the T, but with the last version, the P actually delivered better
timing performance. Indeed it was running defaults so SBAS likely running at the time.
If you are trying to do some sort of master / slave setup, it’s best to dive into just what is involved with
that task. For a system where both master and slave are mobile, the P is likely the better choice.
Bob
On Jul 17, 2019, at 4:57 PM, Glen English VK1XX glenlist@pacificmedia.com.au wrote:
The F9T and F9P - are these interchangeable for stationary timing use and stationary high performance position ?
the F9P has an internal RTK engine, and the F9T outputs the info RTCM etc and that data can be run on a external RTK engine on a micro.
The P provides 1.5m standalone positional accuracy compared to the T standalone positional accuracy of 2.0m. Not much difference there..
the F9P and F9T have their timing pulse performance shown using different description.
Both can operate with companion receivers to enhance performance but I interpret this as only the P can do a (internal, companion mode) differential position fix and only the T can do a (internal companion mode) differential time fix. That is , internally without using an external engine.
So it seems, if using an external RTL etc engines, the devices can do roughly the same thing.
How do others interpret this ? I want to do projects using positional for one app, and timing for another, and would like to be able to acheive the deep quantity discounts...
glen
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
Hi
timing than single band modules do. The T has multiple pps outputs and *should* handle logging (at a
Bob
> On Jul 17, 2019, at 4:57 PM, Glen English VK1XX <glenlist@pacificmedia.com.au> wrote:
> glen
> _______________________________________________
GE
Glen English VK1XX
Thu, Jul 18, 2019 5:23 AM
fine business.
thanks for the insight.
The dual band L1, L2 is a certain plus. At a price Hard to ignore the
benefits certainly for apps that can afford it.
I'll report back...
cheers
On 18/07/2019 7:37 AM, Bob kb8tq wrote:
Hi
Bob
glen
fine business.
I'll report back...
cheers
> Hi
> Bob
>> glen
BK
Bob kb8tq
Thu, Jul 18, 2019 12:54 PM
Hi
The price of a bare module is still a bit steep. The price of the uBlox board for the F9P still looks
like a steal though …..
At this point you still don’t seem to be able to buy F9T modules through distribution at all. Both are
priced just below $200 on the uBlox site. The F9P is priced identicallyat Digikey as at uBlox. I have
not seen either one pop up at any other distributors yet. My guess is that once more of these get out
in the wild, other distributors will come in and the price will drop a bit.
Right now the M8N is at $25 and the M8T is at $89 at Digikey. I doubt the F9P or F9T will get to
the M8N price. Getting a lot closer to the M8T price seems pretty likely. However if your system is
being designed today, the M8T is < 1/2 the price.
For a “Time Nut” sort of project where best performance is the goal, the F9P / F9T seem like the
best way to go. It’s a basement build and you aren’t going to market it to Lucent or Nokia. The
performance plus the features ( and yes … the cool factor …) make it the one to go with. Being able
to do data reduction via the various free services is a big plus.
Bob
On Jul 18, 2019, at 1:23 AM, Glen English VK1XX glenlist@pacificmedia.com.au wrote:
fine business.
The dual band L1, L2 is a certain plus. At a price Hard to ignore the benefits certainly for apps that can afford it.
I'll report back...
cheers
Hi
Bob
glen
Hi
to do data reduction via the various free services is a *big* plus.
Bob
> On Jul 18, 2019, at 1:23 AM, Glen English VK1XX <glenlist@pacificmedia.com.au> wrote:
> fine business.
> I'll report back...
> cheers
>> Hi
>> Bob
>>> glen
